Go to Post So when a team leader decides to give all their heart to a team, it is true love that they exhibit towards it. - Anton Abaya [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 13-01-2005, 18:26
coastertux coastertux is offline
Penn State Class of 2010!
AKA: Steve
FRC #1640 (sab-BOT-age)
coastertux is just really nicecoastertux is just really nicecoastertux is just really nicecoastertux is just really nicecoastertux is just really nice
Send a message via AIM to coastertux
Center Goal Hardware
Is there any way to build the center goal w/ PVC with out spending $125 on the IFI Center Goal Hardware Kit?
Unread 13-01-2005, 18:31
sojouner06's Avatar
sojouner06 sojouner06 is offline
None #0294 (Beach Cities Robotics)
Team Role: Student
sojouner06 has a spectacular aura aboutsojouner06 has a spectacular aura about
Send a message via Yahoo to sojouner06
Re: Center Goal Hardware
you can make it your self
Yeah I know... , This is the real world...
Pardon; the grammar, problem?
Unread 13-01-2005, 18:33
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Please see the UPDATED Field Elements Material Lists, Team Components [Rev. 9] document. This has a material list on how to make the center goal for about $80 with all the items coming from Home Depot.
-Michael Dessingue
Unread 13-01-2005, 18:37
AKA: Steve
That is out of wood though...
Unread 13-01-2005, 18:51
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
As it is now, I haven't seen any way of making the center goal out of PVC without going through IFI.
If making it out of PVC is worth that much to your team, I'd spend the extra cash and buy the materials from IFI. If you're on a budget, go with "Home Depot" wood version.
$0.02
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 13-01-2005, 22:46
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
An alternate technique:
- Get 10 metal (not HDPE) tetra "clovers" used to make the tetras.
- Take six of the clovers and bend one lobe of the clover to approximately 110 degrees. Let's call these the "bent over clovers." With three of these, attach PVC end caps to each lobe, and set them aside.
- For the remaining three bent-over clovers, attach a PVC end cap to the bent lobe. Leave the other two lobes open on each clover. Call these the "left-over bent over clovers."
- Bend the remaining four of the clovers into the standard apex shapes.
- Take three regular clovers and the three left over bent over clovers and pair them up. Put a bolt through the lobe of one bent-over clover, then through the lobe of a regular clover, then into a PVC end cap. Repeat for a second lobe of each. Add PVC end caps to the two open lobes. When you are done, you should have a clover assembly that has four lobes, one of which is bent at a 110 degree angle, with an end cap on each.
- Make a "standard" tetra from 48" lengths of PVC, using the standard metal clover with PVC end caps at the top apex, and the modified 4-lobe clovers at each apex along the base. When you are done, the tetra will stand on the three end caps at the corners, each of which will face down.
- Make another tetra, with 48" lengths of PVC for the three base edges, and 40" lengths of PVC for the rising edges. Do not connect the three rising edges into an apex. Bend the clovers on the base corners of the tetra so the rising edges stick straight up (i.e. do not angle toward each other).
- Lift up the first tetra and plug each of the rising edges of the second tetra into the open end caps on the bottom of the first tetra.
You might have to fiddle with the exact angles of the modified clovers a little to make everything fit, but it is possible to make a center goal out of PVC this way.
-dave
Unread 14-01-2005, 06:18
Tinsky's Avatar
Tinsky Tinsky is offline
AKA: Chad Potinsky
FRC #4003 (FRC 4003 TriSonics / FTC 7023 HexaSonics)
Tinsky is an unknown quantity at this point
If you have the ability to get parts lasercut we have the three different connectors on our site in AutoCAD DWG or DXF formats.
The connectors drawings have perforations on the bend lines making it easy to form them either by hand or in a vice with pliers (depending on the gague material).
Unread 14-01-2005, 09:43
Remember that while wood is only an approximation of the goal, so is pvc. The real goals are made out of aluminum.
Unread 14-01-2005, 15:59
dtengineering's Avatar
AKA: Jason Brett
The centre goal hardware pieces can be manufactured from a piece of wood (even 2x4 should do) using just a band saw and drill. Rather than using a bolt to hold the end caps to the clover, you use a good size (#12 or so) wood screw.
Hopefully this photo will show you what we are using... works great and saves $125 of bent metal. (Sorry IFI...)
Jason
Teacher/Leader Team 1346 "Trobotics"
General Motors Canada and David Thompson Secondary
"The FIRST team from British Columbia."
Name:	wood corners.jpg
Center goal hardware specs CSWilken Technical Discussion 0 13-01-2005 03:26
Two vision tetra on center goal? Guido470 Rules/Strategy 8 09-01-2005 17:50
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
Full list of teams & competitions archiver 2001 14 24-06-2002 00:52
KSC Results archiver 2000 2 23-06-2002 22:19
