Go to Post So measure not by the masses, but by the sparks that you generate. - Kims Robot [more]
Unread 14-01-2005, 07:19
Re: Hall Effect Sensor.
Originally Posted by gwross
Al, there's a problem with your graph. The way you've drawn it. Each sensor is always low whenever the other sensor goes high. Without keeping track of time intervals between pulses, it won't be possible to tell the direction of rotation.
To reliably get direction information, you would need to position the sensors just far enough out of phase that the pulses overlap as illustrated below. Then when you see one of the lines go high, you can just check the other one, and immediately know the direction.
Greg,
Thanks for the correction. I need to stop trying to rush a post before I leave work. You don't get a chance to go back and look at what you've done.
Making a Sensor Board SpaceOsc Technical Discussion 11 15-05-2004 12:46
Banner Sensor Programming Problem 2Crisis Programming 4 24-02-2004 13:40
IR sensor trouble D.Viddy Electrical 2 30-01-2004 09:49
Quick Optical Sensor Question zorro Technical Discussion 10 21-01-2003 06:39
