Go to Post Awesome doesn't even scratch the surface here folks. - DonRotolo [more]
Unread 13-01-2005, 10:12
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
Re: 2005 FP Pinion
Originally Posted by Joe Johnson
This is bad... ...will you please post a picture of you motor -- especially the sticker on the side, a close up of the gear would be good too.
Joe J.
I have pictures of one of our F-P motors that has a 15 tooth pinnion. I need to check if the other is the same tonight. I'm not sure how to post a picture. The part number on the motor is 74550-0642.
Matt B
Unread 13-01-2005, 10:16
UCGL_Guy's Avatar
UCGL_Guy UCGL_Guy is offline
AKA: Ken YorK
None #0476 (Wildcats)
UCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to all
Send a message via AIM to UCGL_Guy
Re: 2005 FP Pinion
Ours are 13 tooth - did not check the numbers though -
will look tonight.
Ken
Ken York
Mentor/Coach Team 476 Ponca City OK
An ignorant person is one who doesn't know what you have just found out.
Will Rogers
Unread 13-01-2005, 11:05
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: 2005 FP Pinion
How would you handle this if you were FIRST?
This is a pretty tricky situation. Do you let teams basically use whatever Fisher Price transmission they want? Do you give teams options (pick from one of these model)?
I swear that I recall a debate in years past between Bill Beatty and I that more or less ran along the line of "my motor has N teeth," "mine has N+1" "F-P sent me replacements with N-1 teeth" and so on.
I didn't know what to make of this then, but perhaps this type of thing has been going on for years.
Anyone have any thoughts on this?
My thought would be that you get what you get as far as what is in the kit for you to use. If you want to go to the bother of getting one of the other parts that other folks got in the kit, feel free to work with F-P dealer/service or trade with another team.
I think this keeps FIRST out of it and it makes it fair if you REALLY need that extra power motor that some other team got.
It will be interesting to see what the variation in performance is on the various motors, but I think for the most part, it won't matter that much. As with so much in FIRST, we will adjust and move on*.
Joe J.
*of course, this is easy for me to say, I have already made the following statement before the House Committee on Unfair Activities: "I am not now, nor have I ever been a member of the Life-Should-Be-Fair Party" ;-)
Team #88, TJ2
Unread 13-01-2005, 11:55
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: 2005 FP Pinion
Are we sure that these are different motors, or could they possibly be the same motor, with a different gear? After all, the spec. sheet (from Mabuchi, not F-P) deals only with the motor characteristics--the pinion itself is apparently reflected in the F-P (and likely not the Mabuchi) part number.
To see if this theory is correct, it would be useful if team members were to post the tooth count of their F-P pinion (i.e. 13, 14, 15, or something else), the F-P model number (e.g. 74550-0642) and the Mabuchi date code (e.g. TD034701) for their motors, so we can see if the proper motors (per Paul's data sheet) can come with different gears, but still under one F-P part #.
Unread 13-01-2005, 15:11
Electrical Engineer
Rookie Year: 1995
Re: 2005 FP Pinion
Originally Posted by Tristan Lall
This is worse: 188 has counted teeth, and the number is 13. I've just got off the phone with those involved, and they had separate people count it (twice!). For reference, the identifying marks on the motor are as follows:
74550-0642
TD034701
All,
Team 177 has the number of teeth and markings as Team 188. 13 teeth (and I had two people check it).
Can Dr. Johnson or Mr. Copioli post a (hopefully small) spreadsheet or list of different motors and their relevant specs?
Mike Betts
As easy as 355/113...
Unread 13-01-2005, 15:39
Electrical Engineer
Rookie Year: 1995
Re: 2005 FP Pinion
...If I were you, I would a stall the motor (for a short period of time) at 0.8 volts or so and accurately measure the voltage accross the motor and the current. If the current is not about 10 Amps at 0.8V (i.e. the Resistance should be 0.08 Ohms per the spec) ,you have confirmation that you have a different motor than the rest of us...
I will measure at 0.8V tonight and report on our 13 tooth version...
Mike Betts
Unread 13-01-2005, 17:57
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Re: 2005 FP Pinion
Our motors also have 13 tooth pinions. This seems very strange.
It would be if we could gather the specs on all of the motors, regardless of the pinion tooth count, so that it becomes less confusing for us all.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 13-01-2005, 21:44
AKA: Matt
Re: 2005 FP Pinion
Matt B
I just checked the other F-P motor that came in our kit. it has the same part number on the motor and the motor looks the same, but it has a 13 tooth pinnion. So, we have one 15 tooth pinnion and one 13 tooth pinnion. Makes it kinda tough to use them as a set.
Unread 13-01-2005, 22:03
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: 2005 FP Pinion
Looks like I beat Mike to logging on.
Our results were 10amps at 2.5V. Signifigantly different than Joe's.
Unread 14-01-2005, 07:15
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
Re: 2005 FP Pinion
74550-0642
TD034701
I checked our motors last night.
13 tooth
74550-0642
TD014602 - this is different, but what does that mean?
Andy Brockway
Team 716, The Who'sCTEKS
Unread 14-01-2005, 08:01
President, VEX Robotics, Inc.
Re: 2005 FP Pinion
Do not worry about this number. It is the date code used by Mabuchi to indicate when (and where, I think) the motor was manufactured. If you have the same number on the top line, then it is the same motor.
-Paul
Unread 14-01-2005, 09:14
Electrical Engineer
Rookie Year: 1995
Re: 2005 FP Pinion
-Paul
Paul,
Dr. J measured 10A at 0.8V stall current on his 14T motor.
Team 177 measured 10A at 2.5V stall current on our 13T motor.
While I will admit that we did not measure the voltage right at the motor, I refuse to believe that we dropped 1.7V in the wires and connectors. I would guess more in the 200 to 400 mV range which puts our 12V stall current closer to the 60A indicated for 12V FP motors in the past. Whereas Team 47's motor has a 12V stall current closely matching the 150A specified for the 6V model.
I submit that we have different motors.
Regards,
Mike Betts
Unread 14-01-2005, 09:29
Re: 2005 FP Pinion
Well,
I certainly did confuse the issue. My previous post stated my pinion size was 14 teeth. Well, all the gearboxes I have (two from FIRST that I received to do the study in December) and the two team 217 received in their kit all have 13 tooth pinions.
I can only confirm what the engineers from Mabuchi tell me are facts. One of those facts is that the part number on the sticker that is placed on the motor is the number on the top line. If the number is the same, Mabuchi insists that the motor is the same.
-Paul
Unread 14-01-2005, 09:35
Electrical Engineer
Rookie Year: 1995
Re: 2005 FP Pinion
I will further muddy the water and point out that Guidelines_C.pdf give a stall current of 148A for the motor alone and 70.3 A for the motor/gearbox assembly (which is how I measured stall).
While I admit I may not be the sharpest pencil on the desk, how could the gearbox affect the stall current measurement?
Mike Betts
Unread 14-01-2005, 09:41
Re: 2005 FP Pinion
The gearbox specs in the guidelines is wrong. The motor specs are the only items I verified with Mabuchi.
**FIRST EMAIL**/Important 2005 Competition Manual Information Sscamatt FIRST E-Mail Blast Archive 1 06-01-2005 18:50
rack and pinion. greencactus3 Pneumatics 17 04-11-2004 23:24
[Official 2005 Game Design] OK, so YOU design the 2005 game... dlavery FRC Game Design 37 26-10-2004 23:15
Your Thoughts on the 2005 Championship Eligibility Criteria! dez250 Championship Event 57 10-09-2004 14:59
Converting the Bosch Metric Pinion into an English- Specification Pinion evolution Motors 3 28-08-2004 16:30
