Go to Post There is no shame in playing the best match you can play. - sanddrag [more]
  #31   Spotlight this post!
Unread 14-01-2005, 09:45
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: 2005 FP Pinion
We've got another pair of
74550-0642
TD034701
13 tooth pinion
Haven't measured resistance.
We really need to get this cleared up soon because we've all got to buy some gears and sprockets and we need the correct torque/power/speed data...
Team 1257
  #32   Spotlight this post!
Unread 14-01-2005, 09:46
Re: 2005 FP Pinion
Originally Posted by Joe Johnson
If I were you, I would a stall the motor (for a short period of time) at 0.8 volts or so and accurately measure the voltage accross the motor and the current. If the current is not about 10 Amps at 0.8V (i.e. the Resistance should be 0.08 Ohms per the spec) ,you have confirmation that you have a different motor than the rest of us.
Dr. Joe, did you measure it already, or is this a calculated value?
  #33   Spotlight this post!
Unread 14-01-2005, 10:16
Joe P Joe P is offline
Joe P will become famous soon enoughJoe P will become famous soon enough
Re: 2005 FP Pinion
Originally Posted by Andy Brockway
I checked our motors last night.
13 tooth
74550-0642
TD014602 - this is different, but what does that mean?
Just checked our FP motors.
13 tooth
74550-0642
TD034701
Made in China
Joe P
Team 647 Shoemaker Cyberwolves
  #34   Spotlight this post!
Unread 14-01-2005, 10:45
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: 2005 FP Pinion
I will try to get to this over the weekend. Sadly, the power supply I need to do this is back here at Delphi and the parts are in Pontiac (about 1/2 hour away).
Joe J.
Team #88, TJ2
  #35   Spotlight this post!
Unread 16-01-2005, 13:50
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
Re: 2005 FP Pinion
Joe J.
Checked ours, 13 teeth
Read the Friday Email about the Typo in the kit for the FP's. I also had the kids measure the free speed with the transmission. 144 rpm, battery fully charged, fuse, no victor. which is no surprise as last years was 130 same conditions.
Cheers
Tom Cooper
1227
  #36   Spotlight this post!
Unread 18-01-2005, 13:51
DGiandomenico DGiandomenico is offline
Mentor Elec & Cntrl Sys
FRC #0846 (The Funky Monkeys)
DGiandomenico is on a distinguished road
Re: 2005 FP Pinion
Here are a couple measurements on our 2005 Fisher Price Motor
13 teeth; 1/2" O.D. pinion
Part ID# 74550-0642
Code: TD034701
Measured RPM*:
24,500 @ ~12V (voltage approx)
12,000RPM @ 6.0V
-11,600RPM @ -6.0V (reverse direction)
* Measured using R/C airplane hobby tach & transparent disc w/stripe
Motor Resistance**:
0.069 - 0.074 ohms
**Measured with 10A current source; 4 point measurement of 0.69-0.74 V while turning rotor between fingers
Calculated stall current from above:
162 - 173A (12V/0.069ohms; 12V/0.074ohms)
All these measurements agree well enough by those provided by Paul Copiola at
http://www.chiefdelphi.com/forums/sh...ad.php?t=32442
-David
  #37   Spotlight this post!
Unread 22-01-2005, 19:10
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
Question Re: 2005 FP Pinion
To take this question to the next level;
Does anyone know or want to hazard a gues as to what the pressure angle is on the gears used in the FP transmission?
Matt B
  #38   Spotlight this post!
Unread 23-01-2005, 13:09
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: 2005 FP Pinion
20° (at least, that's what the old ones were). The new gears look like they have the characteristic "sharp" teeth, so short of taking measurements, I'd definitely say that that's what they are.
  #39   Spotlight this post!
Unread 23-01-2005, 13:25
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: 2005 FP Pinion
From history, I'd say you are pretty safe in saying it is a 20 Degree Pressure angle.
They typically use standard DP and pretty standard gears (no enlargements or thickening of teeth, etc.).
Joe J.
Team #88, TJ2
  #40   Spotlight this post!
Unread 23-01-2005, 15:23
rmmlg's Avatar
rmmlg rmmlg is offline
#0900 (Infinity)
rmmlg is on a distinguished road
Re: 2005 FP Pinion
So is this 32 DP like the others?
Ryan
Team 900 (Infinity)
  #41   Spotlight this post!
Unread 23-01-2005, 22:51
Re: 2005 FP Pinion
Definitely. And I tested the mesh today with some good quality 20° PA gears, and I'm even more confident that nothing has changed.
13 T, 32 P, 20° PA
**FIRST EMAIL**/Important 2005 Competition Manual Information Sscamatt FIRST E-Mail Blast Archive 1 06-01-2005 18:50
rack and pinion. greencactus3 Pneumatics 17 04-11-2004 23:24
[Official 2005 Game Design] OK, so YOU design the 2005 game... dlavery FRC Game Design 37 26-10-2004 23:15
Your Thoughts on the 2005 Championship Eligibility Criteria! dez250 Championship Event 57 10-09-2004 14:59
Converting the Bosch Metric Pinion into an English- Specification Pinion evolution Motors 3 28-08-2004 16:30
