Go to Post I GET that FIRST is about more than winning on the field. BUT... ...it is my experience that the great programs of the FIRST world almost always build on a foundation of competitive robots. Success on the field begets success in other realms. - Joe Johnson [more]
Unread 14-01-2005, 13:44
Re: Viewing Angle of Camera
Originally Posted by Joe Johnson
60 Degrees both in the UP/DOWN and LEFT/RIGHT direction?
Joe J.
Joe,
The lens is listed as a 4.9 mm, F2.8 lens(I had to search but found it on one of the CMUII sites). The target area is 4.86 mm x 3.64 mm. for a diagonal of nearly 1/4", the listed specification for this device. Plug in the numbers for the diagonal and the focal length and it comes out to about 60 degrees. Since the aspect ratio for this camera is 4:3, the horizontal look angle is less than 60 degrees and the vertical is even smaller. This of course is in a perfect world and the lens in this camera is not self compensating for focus, distance to pickup, etc. so the FOV (field of view) will vary from camera to camera. According to my lens calculator (fudging for the tiny pickup area, my calc only goes down to 1/2") FOV (horizontal) is 22-25 ft. at 20 ft from the camera.
Unread 14-01-2005, 14:11
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
Originally Posted by Al Skierkiewicz
Joe,
...According to my lens calculator (fudging for the tiny pickup area, my calc only goes down to 1/2") FOV (horizontal) is 22-25 ft. at 20 ft from the camera.
That correllates well with my measurement of about 9 ft (left:right) at a radius of 9 ft. If the aspect ratio is 4:3, then you should expect about 60 degrees horizontally x 45 degrees vertically. I wasn't trying to measure the FOV to high accuracy - figure 9 ft. +/- 3 in. - but somehow I doubt that FOV accuracy is going to be that critical a factor with these cameras...
Pete Kieselbach
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Kevin Watson's Kick-off Demo Code! Mr. Lim Programming 27 22-01-2005 03:38
Calc. Triangle Angle or Side Based on Ellipses? indieFan Math and Science 1 07-06-2004 21:25
PBASIC ARCTAN function Greg Ross Programming 14 11-05-2003 12:28
Webcast camera angle... Joe Johnson Regional Competitions 13 11-03-2002 16:35
