Go to Post FIRST involves school, parents, family etc etc....at least it does at our house! - MrForbes [more]
Unread 14-01-2005, 16:41
Dr.Hibbert Dr.Hibbert is offline
Team Role: Electrical
Dr.Hibbert is an unknown quantity at this point
Question About Robot Power Distribution Diagram
How do you connect multiple CIM motors to the Robot Controller
from my point of view of the diagram it seems that to connect the motors from one victor speed controller
is it possible to use just 1 speed controller for multiple CIM motors or do you need multiple speed controllers?
-if I need more speed controllers where will I connect the speed controllers to?
thank you! Any help will be appreciated!
PS. is any of the diagrams(ie. speed controller, Robot contoller,etc.) on the Robot Power Distribution diagram available to make a custom diagram?
thanks again for any help!
Unread 14-01-2005, 16:54
Ryan Foley Ryan Foley is offline
FRC #5687 (The Outliers)
Ryan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond repute
Re: About Robot Power Distribution Diagram
<R77> No more than 1 motor may be connected to each speed controller.
If I remember correctly, the robot controller should have 16PWM outputs on the top (you can see them at the top of the RC in the diagram), meaning you can connect 16 speed controllers to those outputs.
Ryan
FRC #5687: The Outliers [2015-?]
FRC #1995: Fatal Error [2007-2009]
FRC #350: Timberlane Robotics [2001-2004]
FRC/FLL volunteer since 2005
Unread 14-01-2005, 21:26
Connecting two motors to the same speed controller can result in damge to the controller, hence the rule R77. Some teams have reported using a PWM "Y" cable, that is the PWM output from the RC is split to two controller PWM inputs. My team has not used this method, and prefers to have each motor fed from it's own PWM. It is essential that the controllers for both motors in a dual motor transmission be calibrated, so that efficient operation can be accomplished. (one motor does not fight the other resulting in reduced speed and power and increased current.)
Unread 14-01-2005, 21:59
Sscamatt's Avatar
Sscamatt Sscamatt is offline
AKA: Matt Syska
FRC #0195 (Cyber Knights)
Sscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud of
Send a message via AIM to Sscamatt
FIRST puts only 1 of each kind of motor to show what it should be connected for the sake of keeping the diagram uncluttered. Repeat how each device is connected if your using more than one.
2006 Championship Finalist, Thanks 25 + 968!
2006 Newton Division Winner
2006 International Innovation In Control Award
2006 Radio Shack Innovation in Control Award, UTC Regional
RIT Class of 2011
Unread 14-01-2005, 22:53
thank you for your help!
Winning Robot or Quality Robot? Eric Bareiss General Forum 30 09-02-2006 13:19
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
A Question on Sportsmanship Steve M General Forum 31 25-05-2004 23:52
Operator Interface power ISSUE kacz100 Technical Discussion 11 27-02-2004 13:46
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
