Go to Post Sloppy thinking leads to sloppy designs... - Joe Johnson [more]
Unread 14-01-2005, 17:04
Majin_Neko's Avatar
Majin_Neko Majin_Neko is offline
#1394 (Juggernaut/IRC)
Majin_Neko is an unknown quantity at this point
Send a message via AIM to Majin_Neko Send a message via Yahoo to Majin_Neko
Motor Rules
What is the limit for the amount of motors we can dump into our robot??? we are a 2nd yr rookie team and we cant find in the rule book the amount of motors we can use.....
Unread 14-01-2005, 17:07
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Motor Rules
I won't bother looking up the rule at the moment, but you're limited to the number of motors provided in your kit and listed on the kit parts checklist. Thus, you may have up to 4 Chiaphua motors on your robot, etc. you're not allowed to buy extra motors and put those on your robot as well.
Aside from this, you're only limited by the space, control, and power requirements of the motors.
Unread 14-01-2005, 17:30
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: Motor Rules
From memory:
4 CIM motors (Chiaphua motors to me) 300+ Watts
2 Fisher Price motor/transmissions 400+ Watts (But not likely to survive long if you actually USE 400Watts)
1 PSD motor about 60 Watts
1 Mabuchi motor about 7 Watts
1 Globe Motor about 50 Watts
1 Denso Window Motor guessing about 20-30 Watts
1 Jideco Window Motor again, guessing about 20-30 Watts
11 motors TOTAL
+ As many Hitec 322 Servos as you can account for.
Joe J.
P.S. I do not have the time, but I wish SOMEONE would make a chart of the following data at 12V: Freespeed, Stall Torque, Stall Current, Peak Power
FYI: Peak Power = Stall Torque (N-m) * Free Speed (RPM) / 38 (Rev - sec / Radian - Min)
Please please please.... ...I've got some positive reputation points for you if you do ;-)...
Team #88, TJ2
Unread 14-01-2005, 17:47
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Re: Motor Rules
See page 7 of the "Guidelines" document from the Documents/Rules section on the FIRST web site.
Do I get the rep points for pointing to the answer?
-dave
Unread 14-01-2005, 18:00
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Motor Rules
Working on one as I speak
edit: Dave is the man
double edit: just looking at the section of the chart for the Mabuchi motor, FIRST's chart shows stall current at 3.6 amps while the actual Mabuchi spec sheet shows it at 5.2 amps
2001-2004: Team 100
2006-Present: Team 254
Unread 14-01-2005, 20:15
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
Re: Motor Rules
If you don't want to open up the .pdf file each time, I've made the motor chart available here.
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 14-01-2005, 20:34
pakrat pakrat is offline
Rich Ross
no team (The Rat Pack)
pakrat is just really nicepakrat is just really nicepakrat is just really nicepakrat is just really nicepakrat is just really nice
Send a message via AIM to pakrat
Re: Motor Rules
of course, you might want to think about buying extra motors just in case some blow out at competition
