Go to Post Once we know how magic works it's no longer magic; it becomes science. - Karthik [more]
Unread 14-01-2005, 18:00
magical hands magical hands is offline
Jigar Patel
AKA: Jigar Patel
FRC #2185 (Etobicoke CI)
magical hands is on a distinguished road
Exclamation Gyro
Can anyone tell me from where I can buy good gyro at fairly good price. I know that the gyro that they used at Kick off was around $200 or something. So if anyone knows where I can buy good gyro's from please tell me thanks!
Unread 14-01-2005, 18:14
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Gyro
In the past teams have ordered ones from digikey made by Analog Systems. Do a search on these forums and you should be able to find some exact part numbers.
Unread 14-01-2005, 20:57
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Gyro
This is one of the questions answered in the magical Gyro Frequently-Asked-Questions. I've also started an Encoder Frequently-Asked-Questions. Both will be updated over the coming days and weeks.
-Kevin
Kevin Watson
http://kevin.org
No Signal From Gyro colt527 Programming 12 19-10-2004 07:30
ADXRS150 gyro yaw rate sensor Brian M. Electrical 13 17-10-2004 02:28
Wierd gyro code problems...pls help Salik Syed Programming 4 14-03-2004 01:29
gyro code odin892 Programming 2 08-04-2003 14:50
Have YOU used the gyro chip? FotoPlasma Technical Discussion 10 31-01-2002 13:26
