#16
Re: usb to db15
I was wondering about using an xbox controller, and I know where I can get my hands on some xbox controller ports. Is there any way that someone can think of that I can use the wiring from the controller to connect to the D-15 port? |
#17
Re: usb to db15
Good luck |
#18
Re: usb to db15
From what I've seen about it, xbox controllers are usb controllers. Their pinout is a bit weird, but there's definitely usb in the xbox (For more info about that, look up modding your xbox to include a usb hub, its a simple hardware mod)
#19
Re: usb to db15
Our team is intrested in using an XBOX controler.
I'll see what I can find on these sites. |
#20
Re: usb to db15
Here's how this would have to work:
(I'm working with USB for a senior project.) USB is a serial bus. This means that it has 2-way data communication over a balanced signal. The usb connector also happens to have +5 and GND. I'm assuming that the XBox controllers have some kind of 'smarts' in them to multiplex (that's assemble) the button pushes into a serial data stream for the USB. So, first off... they require power. I wouldn't recommend trying to draw power off of the OI joystick ports without talking to IFI about current limits, which I don't think are published as such. Secondly, since you aren't allowed a 'computer' at the player station ... well, you can see where I'm going with that. Now other issues aside the techy details... A PIC18F4550 appears to have USB support and is in a PDIP package, which means you could actually solder to a IC socket. (It's not a surface mount) Then you need to write the pic code to decode the probably custom data stream from the XBOX controller and demultiplex it into a set of digital outputs. Then you need to D to A the outputs for the analog sticks because the pic doesn't have built in D to As. Now how I would do it: I'd disassemble the xbox controller and see what's inside... I'd try to re-wire it so that each of the buttons has a direct output line to a DB-15 connector. I'm rusty on my rules, but I don't think you are allowed to do this. (Check) |
#21
Re: usb to db15
Re: usb to db15
| Using USB with Serial Tower | Mick | Lego Mindstorm Discussion | 11 | 07-11-2006 09:54 |
| USB to Serial -- Working Device Found! | Eko | Programming | 10 | 23-02-2004 12:56 |
| USB to 9-pin serial port (HELP!!) | n00b | Technical Discussion | 10 | 01-02-2004 21:25 |
| Connecting USB webcam to pbasic stamp? | JasonStern | Programming | 15 | 14-02-2003 23:45 |
| DB15, Male 15 pin connector. | AdamT | Technical Discussion | 8 | 06-02-2002 17:17 |
