Go to Post While those ideals might exist in black and white perfection; in the real world, with very rare exception, they can only be implemented as compromises in shades of gray. - gblake [more]
Unread 21-04-2002, 17:14
157#1Driver's Avatar
157#1Driver 157#1Driver is offline
Pro E King
#0157 (AZTECHS 157)
157#1Driver is an unknown quantity at this point
Send a message via AIM to 157#1Driver
Driver's Controls
Whats does your team use to control the drive? one joy stick, 2 sticks, tank, steering wheel?
157 The Aztechs
Luck of the Irish
157 - 12 years and still going
Unread 21-04-2002, 17:18
purplehaze357's Avatar
purplehaze357 purplehaze357 is offline
OMG We're Back Again
AKA: Joe Troy Jr.
#0357 (Royal Assault)
purplehaze357 is on a distinguished road
Send a message via AIM to purplehaze357 Send a message via Yahoo to purplehaze357
two joystick tank drive system....with a third joystick for JJ....hes our mini-bot
2004 Philadelphia Regional Referee
2005 Pittsburg Regional Referee
2005 Philadelphia Regional Referee
2003 Chesapeake Regional Chairmans Award Winners
2003 Chesapeake Regional "Delphi Driving Tormorrows Technology" Recipients
Aim: smallmanjoe98
Email: jtroy@temple.edu
Unread 21-04-2002, 17:20
gniticxe's Avatar
gniticxe gniticxe is offline
B.C.O.M. Forever!
AKA: Brian Gattman
no team (FRC2910 - Jack in the Bot / FRC365 - MOE)
gniticxe will become famous soon enough
We have one joystick that controls our four wheel drive bot. Another switch panel covers everything else (wing deploy, anchors, teather...)
Unread 21-04-2002, 17:27
tjrage_25's Avatar
tjrage_25 tjrage_25 is offline
AKA: Tom McLean
FRC #0025 (Raider Robotix)
tjrage_25 is an unknown quantity at this point
Send a message via AIM to tjrage_25
1) 2 joysticks for our tank drive system. thumb and triggers are used to contol the arms
2)One joystick to release the ramp for the mini-bot(trigger), control the turret for the mini-bot(x-axis), and drive the mini-bot(y axis)
3)One little green button we use at the beginning of each match to drive our arms to a preset position.
Unread 21-04-2002, 17:47
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
1 stick to control the big bot
2 sticks buttons for our grippers
1 big red button for secret weapon
Andrew
Unread 21-04-2002, 18:09
Don's Avatar
Don Don is offline
#0288 (the RoboDawgs)
Don is an unknown quantity at this point
Send a message via AIM to Don
1 joystick tank drive for steering and a hoopla of switches used to control our hook, dampeners, and (coming soon) go home devices.
Unread 21-04-2002, 18:13
WakeZero WakeZero is offline
FIRST-a-holic Strategist
#1011 (CRUSH)
WakeZero will become famous soon enough
Send a message via AIM to WakeZero Send a message via Yahoo to WakeZero
Talking
Hehe, ready? =)
To drive our robot, we have one joystick, and one dial hooked up to a pot. The dial is used to change the orientation of our wheels by matching its pot to the pot hooked up to the steering chain on our robot. The wheels (all four of them) stay parallel to each other, thus if the dial is turned 90 degrees to the left, all the wheels would be pointing left in relation to the frame of our robot. The Joystick is mainly used for throttle, although here comes the fun part:
I programmed the power output to the wheels to respond just like a tank drive would. This allows us to easily change the orientation of our frame, which would not have been controllable otherwise. Now, if you truly understand how all that works, you would have noticed that once the wheels turn past 45 degrees in orientation, a simple left turn tank style would do nothing because the wheels would start canceling out. This is because what used to be the left side of the robot, is now actually the front or rear. To correct this, I simply swapped two of the corner outputs once the pot read that it was turned passed 45 degrees (and swap them again if it was passed 135 degrees). This corrects the problem quite nicely, and lets me have a fun time driving the thing =)
So basically... we have 360 degrees of movement, and we can 'crab' from side to side (or diagonal to diagonal) like a goalie strafing to protect the 'goal', mua ha ha. We call this complicated system of technical hoopla, Swerve Drive... how many degrees does your robot handle?
2004 Arizona Regional -- Semifinalist
2003 NAT Galileo Division -- Highest Seeded Rookie (20th)
2003 NAT Galileo Division -- 100% Autonomous Completion (7 for 7)
2003 Arizona Regional -- Rookie All-Star Award
2003 Arizona Regional -- Quarterfinalist
Alumni on Team 64, The Gila Monsters
College Mentor/Founder of Team 1011, CRUSH
Unread 21-04-2002, 18:45
fast frank fast frank is offline
FRC #0271
fast frank is an unknown quantity at this point
Send a message via AIM to fast frank
we have 2 joy sticks to drive and a control box. i'll let tim explain the "DOUBLE SECRETE OVER-RIDE BUTTON" if he wants to..
Bad Boys from Bay Shore
Unread 21-04-2002, 18:55
Chubtoad's Avatar
Chubtoad Chubtoad is offline
I'm a weirdo.
#0271 (Mechanical Marauders)
Chubtoad is an unknown quantity at this point
Send a message via AIM to Chubtoad
Well I'm the control box guy so I guess I'll explain the control box
Most of our functions or automated. We have a switch for Ball Load posistion. It brings the basket to right underneath the lip of the playerstation to load the 10 balls, then we have a base position, which is the most stable possition while still being able to grab onto a goal. Once we attach to a goal (semi-automated, but automatic in the mechanical sense of the word, not programmed) we then have the "Dump" posistion, which is very appropraite because it send the basket up the next 4 feet and out so it can dump balls. One more button press and the balls are dumped.
In case of other needed movements we have override buttons. If you hit the override button for the Basket functions it turns the LOAD posistion button into the controler for the basket tilt in/out
and the DUMP button goes to control the actual Height (extension) of the basket/arm.
BUT we thought that "What if one of the limit switches is malfuntioning, THE ROBOT WON"T WORK!!" so we Installed the INFAMOUS "DOUBLE SECRET OVERRIDE MODE!"
The simple override still listens to limit switches so you can't send things out of the extent. HOWEVER the DOUBLE SECRET OVERRIDE LISTENS TO NO LIMIT SWITCHES!!! NONE!! and the little LED's that tell you whether you are in Manual(override) or Automatic mode BLINK!! THEY BLINK!!! IT IS SOOOO COOOOL!!!
Come by our Pit at the NATS for a Demonstration of our $@#$@#$@#$@#$@#$@#$@# Control system!!!!
YEAH!!!!! 271!!!
2003 - GM Industrial Design Award @ SBPLI Regional
My Site!
Unread 21-04-2002, 18:59
Andy A. Andy A. is offline
Getting old
FRC #0095
the main driver has one stick for drive and a small switch box for the goal clamp and brake.
The second driver has a switch box that controls the hopper dump and rollers. The rollers acutally are an art to control. Not only do they have to be triggered at the right time as the bot is driven near a ball, but their speed must be adjusted. As more balls are in the hopper, it takes more power from the rollers to displace the collected balls with the ball being collected. So, as we drive down the side line the rollers must have their speed dialed up (with a pot) and constantly adjusted to keep balls going into the hopper, but not so fast that they bounce out of it. It's a real balencing act.
Thats about it. I would like to hear from two stick teams why they use two joy sticks. According to our programer, the change in the program needed to use one stick is pretty simple. So why use two? Do the drivers just prefer it? I can't stand two stick driving...
-Andy A.
Unread 21-04-2002, 19:00
Ameya's Avatar
Ameya Ameya is offline
Freelance Goon
FRC #0293 (SPIKE Robotics)
Ameya is on a distinguished road
Send a message via ICQ to Ameya Send a message via AIM to Ameya
We originally had one joystick steering, and a little control box with a switch for high/low gear, a switch for fwd/rev driving, a switch to turn on the fiberglass roller, a pot to control the speed of the roller, a switch for the Sickle of Death, and a switch for the side arms.
But, a few minutes before our first practice run at J&J, the drivers told me to change it to two joystick steering, so that's what it is now. Later in the competition, our limit switches that detect high/low gear malfunctioned, and the robot, thinking that it was in neutral, started turning to the left (that's what I've programmed it to do when it's in neutral). So I converted the roller switch to a shift-override switch.
Ameya Agaskar
Team 293 alumnus
Unread 21-04-2002, 20:45
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
Well, we made a pretty simple control system.
2 joysticks, mostly out of MY (i love being a programmer/driver) preference. i feel that with 2 joysticks, i get a lot more control over the robot, even if it is a bit harder to drive. so, on one side, we have the two joysticks.
one the otherside, we have 5 switches. one of the switchs got screwed up when i soddered them (i think i burnt it out), but that doesn't matter, cause we only use four. Switch one controls our "Super-Dooper-Kick-Butt Treads". by flipping the toggle down, it sends a signal to pop out two pistons, which deploys the treads. switch two controls a third piston on the back, which does absolutly nothing. switch three makes the robot's orientation switch. basically, front becomes back, back becomes front. useful incase we want to start backwards, or if you just get confused when driving in reverse . switch four will manually override the compressor. we thought it sucked up too much juice, so if we needed more power, we flipped it off. of course, we never bothered to program a LED to say when there was full air, but that's a minor difficulty . if the treads need to go down, you hit that switch .
that's pretty much our control system. nothing fancy, in fact, it really kinda sucks (it's too heavy). but i designed it so i'm happy with it. it also gets the job done, so i'm not complaining. if you feel like seeing it, drop by, although it's nothing special.
AIM --> Woloi
Email --> ian@woloschin.com
Unread 21-04-2002, 22:40
Matt Attallah's Avatar
Matt Attallah Matt Attallah is offline
Now at sub 14's in a 5000lb vehicle
AKA: Maher Attallah
FRC #0005 (Robocards)
Matt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond repute
Send a message via AIM to Matt Attallah Send a message via MSN to Matt Attallah Send a message via Yahoo to Matt Attallah
2 joysticks to control our 2-wheeled drive system, and buttons that are on the joysticks. Just the button & trigger. One driver for the whole thing, very, very easy to drive...
That rug really tied the room together...
Unread 22-04-2002, 01:40
#1011 (CRUSH)
For some people, two joysticks are a lot more comfortable then one joystick. If our robot was a pure tank drive, I would have programmed it for two joysticks cause that would also have to be my number one choice... but like I said, if we want to go somewhere we just 'crab'
Unread 22-04-2002, 12:30
Ken Delaney's Avatar
Ken Delaney Ken Delaney is offline
Ken Delaney is an unknown quantity at this point
Send a message via Yahoo to Ken Delaney
Since people are talking about their other controls I figured I would add to purplehaze's repsonse. Our robot has two independently controlled arms, that can extend and retract, rotate forward and back 25 degrees. Each have a claw at the end to grab or release the goal.
The operator has complete control of each arms' functions. We use a pot to pot control for the arms rotations. Momentary buttons to control the extension and retraction. A momentary button allows the operator to toggle the claw open or close. The best switch on the control box is the smart mode switch, which allows the arms to grab the goals automatically. The operator can override certain functions while in smart mode.
We also have a switch for the transmission(Hi to Lo). And another switch to activate JJ. The last switch is a reset button to put the bot back into its starting position. That is 10 digital inputs and 2 analogs inputs going through the box alone. We built the box and code well before the bot was finished. We tested and debugged in about 2 days of actual time with the robot.
Monkey controls robot with thoughts Jeff Rodriguez Math and Science 7 13-10-2003 14:29
2003 IRI: A driver's last hurrah or a new rookie driver's experience? Amanda Morrison Off-Season Events 14 23-05-2003 17:39
drivers esellers Rules/Strategy 5 24-01-2003 08:46
Wireless camera ALLOWED as driver's aide? Travis Hoffman Rules/Strategy 7 19-01-2003 02:31
Choice of Drivers archiver 2000 8 23-06-2002 22:36
