Go to Post Physical items will be lost along the way eventually but memories will never be forgotten. - Connor McBride [more]
Unread 15-01-2005, 12:14
HolyOne207's Avatar
HolyOne207 HolyOne207 is offline
Domo arigato, Mr. Roboto
AKA: Brian & Peter
#0207 (MetalCrafters)
HolyOne207 is an unknown quantity at this point
Send a message via AIM to HolyOne207
Error - section 'InterruptVectorLow'
Ok, we have yet to change to code, just moved it's whereabots off the desktop so that it would not exceed the character alotment.
My question is: why, then, do I get this error?
Executing: "C:\mcc18\bin\mplink.exe" /l"C:\mcc18\lib" "18f8520user.lkr" "C:\Documents and Settings\sferron\Desktop\FrcCode2005v2.4\main.o" "C:\Documents and Settings\sferron\Desktop\FrcCode2005v2.4\user_Seri alDrv.o" "C:\Documents and Settings\sferron\Desktop\FrcCode2005v2.4\user_rout ines.o" "C:\Documents and Settings\sferron\Desktop\FrcCode2005v2.4\user_rout ines_fast.o" "C:\Documents and Settings\sferron\Desktop\FrcCode2005v2.4\ifi_utili ties.o" "C:\Documents and Settings\sferron\Desktop\FrcCode2005v2.4\ifi_start up.o" "C:\Documents and Settings\sferron\Desktop\FrcCode2005v2.4\user_came ra.o" "C:\FrcCode2005v2.4\main.o" "C:\FrcCode2005v2.4\user_SerialDrv.o" "C:\FrcCode2005v2.4\user_routines.o" "C:\FrcCode2005v2.4\user_routines_fast.o" "C:\FrcCode2005v2.4\ifi_utilities.o" "C:\FrcCode2005v2.4\ifi_startup.o" "C:\FrcCode2005v2.4\user_camera.o" "C:\FrcCode2005v2.4\FRC_library.lib" /o"FrcCode.cof"
[^that was all one line, btw.]
MPLINK 3.90, Linker
Copyright (c) 2004 Microchip Technology Inc.
Error - section 'InterruptVectorLow' type is non-overlay and absolute but occurs in more than one input file.
Errors : 1
thank you
Legends. Do you want to be one?
Unread 15-01-2005, 12:46
HolyOne207's Avatar
AKA: Brian & Peter
Re: Error - section 'InterruptVectorLow'
Another thing:
The execution finds code in Documents and Settings and/or Desktop. I don't think any code should even be trying to be found there, since I moved it.
Once, again,
Thank you
Unread 15-01-2005, 16:22
Jay Lundy Jay Lundy is offline
Programmer/Driver 2001-2004
Jay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to all
It's linking together 2 user_routines_fast objects, each of which have a definition for a section named InterruptVectorLow. It links
and
You need to make sure it only links one of each .o file or you'll run into lots of errors.
Unread 15-01-2005, 18:02
HolyOne207's Avatar
AKA: Brian & Peter
Talking Re: Error - section 'InterruptVectorLow'
can i say just delete the user-routines located at C:\FrcCode2005v2.4\user_routines_fast.o and it will work? i guess ill try it, thanks.
