Go to Post I need to start using "ThunderChickens!" as an exclamation - Jessica Boucher [more]
Unread 15-01-2005, 14:52
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
Re: Who Owns This Goal
Originally Posted by Dr.Bot
We were messing around, putting tetras on two at a time, and they got tangled. This is unlikely to happen during competition, but we need to thank about all the 'angles.'
It probably will as we did the exact same thing while testing.
We do not stop playing because we grow old;
we grow old because we stop playing.
Unread 15-01-2005, 16:32
Petey's Avatar
Petey Petey is offline
Strategy & Gaming
AKA: Chris Peterson
None #1073 (Team F.O.R.C.E.)
Petey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond repute
A check of the definition of "scored" and "stacked" proves that neither the red nor the blue tetras are stacked on the black tetra.
--Petey
Bio:
Team 1073 alumnus, now Admissions Officer at MIT.
Thanks to all those who have helped me through FIRST over the years.
Unread 15-01-2005, 16:35
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
So then the only way more points could be scored on this goal, or that the goal can change ownership is by removing these two tetras which would now be legal?
Team 1257
Unread 15-01-2005, 16:36
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Either that, or this is a very effective way to block a tetra goal from being scored upon.
Unread 15-01-2005, 17:00
663.keith 663.keith is offline
FRC #1493 (Falcons)
663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all
Send a message via AIM to 663.keith
--Petey
SCORED - a tetra is scored when it is contained within a goal or stacked on top of a goal
STACKED - a tetra is stacked when it is placed on top of a goal or on top of another stacked tetra. to be considered stacked, the tetra must be properly seated on the subordinate goal or tetra such that all four apex connectors are within six inches of the supporting structure. Due to the goal and tetra geometries, a tetra may occasionally not completely "seat" on the goal or subordinate tetra, and remain precariously positioned on top of the structure. such tetras are not considered stacked. A tetra is not considered stacked if it is touching a robot of the same alliance.
SUPPORTED - if the "supporting object" is removed, the tetra would not remain scored or stacked
According to the stacked definition, the blue tetra is not considered stacked (because all four apexes are not within 6 inches of the goal) and would thus be disregarded . considering that, one only needs to look at the red tetra is comparison to the goal, which would become its supporting object. All four red apexes are within six inches of the goal, and their by, red owns the goal.
http://www.wcsrobotics.com
team 663
team 1493
Unread 15-01-2005, 18:15
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Our team discovered the same configuration potential a few days ago. You can create it easily in the following manner: stack a red tetra on a blue tetra; rotate the assembly 90 degrees so that is it on its "side"; and place the resulting rotated assembly on top of a goal. The configuration shown in Alan's picture will result.
With regard to the interpretation of ownership, I believe that Keith is correct, and for the reasons (and specific rules) that he cited. The blue tetra is invalid. The red tetra is "STACKED," and "OWNS" the goal.
-dave
Unread 15-01-2005, 20:36
DrShadowSML's Avatar
DrShadowSML DrShadowSML is offline
Salmon River HS Student
AKA: Steven Lauzon
#0229
Team Role: Student
DrShadowSML will become famous soon enough
Send a message via AIM to DrShadowSML
Exclamation Re: Who Owns This Goal
I can see that this thread is creating some problems. Maybe I can contact some higher ups and see what they say. I'll reply when I have an answer.
Unread 15-01-2005, 22:05
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Steven,
If you look up 1 post, you'll notice "Mr. Lavery" responded.
He's about as high up as you get these days.
If a ruling is necessary (I'm not convinced it is) I'm positive we'll see a response in the Q/A or in a team update.
JV
FIRST and Success: A Question of Definition Madison General Forum 70 27-11-2002 08:42
Small balls in 2001 competition archiver 2001 10 24-06-2002 03:59
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
Just curious, how many robots could shoot or toss balls into the goal? Alan Ing General Forum 7 13-05-2002 19:09
How hard is it to pull a goal? Ken Leung General Forum 19 17-01-2002 20:09
