Go to Post I feel like I need to rinse out my brain with drain cleaner - dlavery [more]
Unread 15-01-2005, 15:25
CatchRothy22's Avatar
CatchRothy22 CatchRothy22 is offline
MORT//Team11
AKA: PJ
FRC #0011 (MORT)
Team Role: Webmaster
CatchRothy22 is infamous around these partsCatchRothy22 is infamous around these parts
Send a message via AIM to CatchRothy22
Loading Zone Questions? What needs to be in...
When a robot reaches the loading zone to get a tetra from a human player, what needs to be in the zone? Does something need to overhang, or does the chassis need to be over hanging? Or does the wheel base itself need to be in? Thanks in advance.
Unread 15-01-2005, 15:34
DrShadowSML's Avatar
DrShadowSML DrShadowSML is offline
Salmon River HS Student
AKA: Steven Lauzon
#0229
Team Role: Student
DrShadowSML will become famous soon enough
Send a message via AIM to DrShadowSML
Thumbs up Re: Loading Zone Questions? What needs to be in...
I believe the whole robot needs to be in the zone but a claw can overhang to pick up a tetra.
Haldir 122690's Avatar
Haldir 122690 Haldir 122690 is offline
Haldir 122690 is an unknown quantity at this point
Only some of the robot has to be in the loading station, BUT it has to be physically touching the loading station triangle on the field. This means that if you only have an arm over the triangle, you can't load it until a part actually touches the triangle on the floor.
Unread 15-01-2005, 15:37
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
<G12> The purpose of the LOADING ZONE is to allow ROBOTS to quickly and safely receive TETRAS without interference while HUMAN PLAYERS and/or field attendants are in close proximity, and then return to play. The LOADING ZONE is not intended to serve as a “perpetual safety zone” to prevent interaction with opponent ROBOTS for the entire match. Tethers, tape measures, long extension arms, and other devices intended to contact the LOADING ZONE to maintain the “non-interference constraint” defined in <G15> while the ROBOT drives around the remainder of the field are against the spirit of the rule and will not be permitted.Such devices must be removed before the ROBOT will be permitted to play in the match.
For reference:
<G15> A ROBOT may not interfere with an opposing ROBOT while any part of the opposing ROBOT is touching its LOADING ZONE and the ROBOT is in the process of retrieving/receiving a TETRA. It is intended that TETRAS be introduced into play as rapidly as the alliance ROBOTS are able to retrieve and utilize them. Violations will result in a 30-point penalty (i.e. three 10-point penalty flags will be thrown) to the offending alliance.
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 15-01-2005, 15:39
MORT//Team11
AKA: PJ
FRC #0011 (MORT)
Read my post again.
Unread 15-01-2005, 15:50
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
a piece of your robot needs to be touching the triangle on the floor for you to be able to pick up a tetra
2001-2004: Team 100
2006-Present: Team 254
Unread 15-01-2005, 15:53
Read my post again.
If you still have questions about what needs to be in the zone, try reading Section 4, Rules <G01> to <G26>.
http://www2.usfirst.org/2005comp/Section_4-The_Game.pdf
All the answers you need should be there. If you still have questions after that, try submitting them to the official FIRST Q&A.
http://www.usfirst.org/robotics/2005/qa.htm
Student - 2001-2004
Mentor - 2006-2009
Unread 18-01-2005, 11:59
AmyPrib's Avatar
AmyPrib AmyPrib is offline
AmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond repute
Q:Regarding <G17>: What are the parameters for being "in" a loading zone?
A:The robot base and / or drive train must be touching the loading zone. The intent of this rule is that you must be in the loading zone. By making it blatantly obvious that you are in the loading zone, you will draw far less attention from the referees.
So, I'm not expecting it to be allowed that you have just an arm touch the loading zone base.
Edit - Sorry, just saw it's further discussed http://www.chiefdelphi.com/forums/sh...ad.php?t=32797
Would be great if there weren't 20 different threads for the same topic....
Sounds like there's still questions as what all could be considered "the robot base".
Co-Chair Boilermaker Regional Planning Committee 2004-2011
2008 St. Louis Regional Finalists and Engineering Inspiration Award
2007 St. Louis Regional Champions - Thanks 1444 & 829! / St. Louis and Boilermaker Quality Award
2006 Boilermaker Chairman's Award
Referee - IRI - 2005, 2006, 2007, 2008
2005 Midwest Regional - Semifinalist, Engineering Inspiration Award, and Safety Award / Boilermaker Regional - Judges Award
2004 Midwest Regional Champions - Thanks 269 and 930! / IRI Runner-Up - Thanks to 234 and 447!!!
2004 Championship: Archimedes Finalist - Thanks 716 and 1272!
"We are going to be praised and criticized more than we deserve. We are not to be affected by either." ~ co-worker
Q/A questions so far.. AmyPrib Rules/Strategy 49 28-01-2005 08:39
Tetra auto loading zone clarification... Gary C Rules/Strategy 21 24-01-2005 13:03
Question: Missing Tetras in Human Loading Zone? tribotec_ca88 Rules/Strategy 7 15-01-2005 15:26
Pushing robots out of loading zone jgannon Rules/Strategy 24 09-01-2005 18:01
Automated Loader without being in loading zone geeknerd99 Rules/Strategy 3 08-01-2005 21:57
