Go to Post In real life (IE when you go to apply your engineering skills to tasks in industry) there will be constraints on all sorts of things - many of which may or may not be "fair" or even "intelligent". You must learn to either work around them or use them to your advantage - preferably a bit of both. - OScubed [more]
Unread 15-01-2005, 18:18
Damian Manda's Avatar
Damian Manda Damian Manda is offline
The Damian
Damian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud of
Send a message via AIM to Damian Manda
Re: Problems and questions about programming
Originally Posted by hedgehogger
Hey again
um... did they give us a new default code this year and if so where is it at???
thanks
-chris
The code is located at: http://www.ifirobotics.com/rc.shtml#Programming
Make sure you have downloaded the new master code (also located there) and installed the new C compiler and MPLAB development environment. MPLAB can be found at: http://www.microchip.com/stellent/id...&part=SW007002 and the compiler has a link on the FIRST website.
This has also been discussed here: http://www.chiefdelphi.com/forums/sh...ad.php?t=32842 see that thread for more information.
FRC Volunteer, FLL regional planning committee member for Colorado
Former Programmer, Web Designer, Communications Director of Alpine Robotics Team 159.
Add your team to the FIRST Teams Google Map
2 questions (programming) Brawler006 Programming 20 22-02-2004 23:15
A few questions on programming the Control System Avarik Control System 21 08-02-2004 11:42
Questions regarding textures in 3D Studio Max Ryan Dognaux 3D Animation and Competition 6 16-02-2003 14:26
Pneumatics parts list questions archiver 2000 1 23-06-2002 22:48
Problems rendering Tyler Olds 3D Animation and Competition 8 24-01-2002 22:34
