How to Make MS joystick work/has anyone used it in past?
I wanted to know if anyone knows how to make a Microsoft Sidewinder Precision Pro joystick work on the robot> and if anyone has doen it in the past. Thank You
Re: How to Make MS joystick work/has anyone used it in past?
is this the controller you were talking about?
if so, it looks like it has a game port end (db15) so it looks like it would work fine with the operator interface. The best way to tell would be to try it |
Yes that's the joystick. Well i brought into our meeting today and we didn't get to try yet because we didn't have the electronics hooked up yet and i had to leave, but i read some other threads saying that this joystick wouldn't work for some people, because it needed to be ms-dos base--- you need to install the software to use it.
If the joystick uses a regular game port connection (and it looks like it does) then it shouldnt need any software. If on the other hand it processes data internally then sends it to the computer somehow utilizing the game port to communicate with onboard software then you might have trouble. I have never heard of such a thing, but then again I never thought about it before either.
I have this joystick (I am also planning to use to for robot control!)
IIRC it uses some proprietary drivers for dealing with that "shift" key they have. I'm not sure if we will need to do some hacking to get the 3rd axis to work or not, though. |
If a controller has a 15-pin connector like that, it's going to be an analog device, and it most likely conforms to the DB-15 standard. Plug it into the Operator Interface, pull up Dashboard, and see what kind of outputs you get. Even if the PC driver is "proprietary", you can still write your own FRC code with a minimal amount of effort. See what outputs you get when you do x with the controller, and make your code do y in response.
#7
we were thinking of doing the exact same thing!
the 3rd axis could have many applications! plus, if you can get it to shake, or better yet - if you can use the force feedback system, you would get an amazing feedback system for the driver! what is this dashboard you speak of? |
#8
http://www.ifirobotics.com/dashboard_viewer.shtml I don't know how I could program without it. |
#9
Thanks guys.. that helped alot... I'm going to try it out on Monday...
#11
Wow. The thing that I guessed wasnt right actually was. Thats cool stuff with the joystick. So what you need to do really (if that joystick does this stuff) is write your own program to interpret the signals you get on the digital pins. Good luck. Its doable (assuming the RC is fast enough) but you are going to need a serious software genius. This is one of those things you play with in the off season.
#13
I'm thinking this will require some rewiring... it will probally require multiple db 15 connections to accomodate all the axies and buttons...
#15
I've opened up the MS Sidewinder Presicion Pro, and it is really, really digital, from what I can tell.... not even a potentiometer... a whole lot of optics, it seems... maybe we can convert the digital signal to multiple joystick inputs? i.e.: have xy, and some buttons on one port, and z and some more buttons on the other port...
| Joystick questioin, FIRST response | Justin Stiltner | Electrical | 0 | 20-01-2003 14:03 |
| Please help make the Nationals in Houston AWESOME ... You be the Tournament Director | Natchez | General Forum | 42 | 13-12-2002 18:50 |
| Does anyone have an idea on how to make a joystick program for an operating board? | necroprime | Programming | 8 | 09-11-2002 19:04 |
| Programming the second joystick in PBASIC | archiver | 2001 | 2 | 24-06-2002 00:25 |
| How do you make objects shine??? | Ydnar | 3D Animation and Competition | 7 | 07-01-2002 21:13 |
