Go to Post And then I learned how to use the lathe...long story short, I ditched my plans to become a music major and became an engineering student. - Karibou [more]
Unread 13-01-2005, 14:14
james james is offline
james is an unknown quantity at this point
Re: Shop tools, any suggestions?
Originally Posted by DivideByZero
I'm part of a second year team that got by with a drill and a drill press as our only power tools (everything else was hand tools last year, and we still placed 15th out of 75 at our regional). Having some debate on what to get this year. Would a jig/sabre saw be of any use, in order to cut framing and large sheet metal (I'd imagine a miter saw to be too difficult if the metal is more than 2x the cutting range, and space/cost are major concerns).
Dude The saber is ok but you need to get a chop saw and an 82 tooth carbide blade it will cut aluminum up to 4 in . Jim
Unread 13-01-2005, 18:08
Jeffel Jeffel is offline
AKA: Jeff Ellis
#0269 (Cooney Tech Robotics)
Jeffel can only hope to improve
Send a message via Yahoo to Jeffel
how bout a decent welder..... essential for putting the robot together!
Jeff
Unread 15-01-2005, 22:12
Smrtman5's Avatar
Smrtman5 Smrtman5 is offline
Dr. Bridgeport
AKA: Jon H
FRC #0041 (Robo-wariors)
Smrtman5 is on a distinguished road
Send a message via AIM to Smrtman5
In my oppinion, a mill and a lathe are the two most useful and versitile machines in a shop. They cover the two basic shapes, round and square, and with some skill can be used to make or modify close to any part (any part our team has ever needed). Dont forget about befriending people who own machine shops, you can never go wrong with that!
Btw, I would be very interested to see pictures of your tool carts or know what tools, other than the basics, you guys take to the competitions. I usually end up packing the day before and my forgetfulness almost put us in a bad spot a time or two. And our 'tool cart' looks more like roll behind lugage anyway.
Art is just an excuse for poor craftsmanship.
- Jon H
Team 41
Rowan University '10 Mechanical Engineering
Unread 17-01-2005, 19:21
Bob Steele's Avatar
AKA: Bob Steele
Just a few comments regarding shop tools.
You need to distiguish between precision tools and general tools.
Precision can be gained by using general tools to cut to shape and various less expensive means such as grinding or filing or reaming to get to final shape. This, of course, takes a great deal of time. It used to be that apprentice machinists were given a file first and various pieces of metal to shape to size... this gave them a great appreciation for the ways of metal. It is still a valuable exercise. The larger precision tools (metal lathe, mill, shaper, etc.) require skill to operate them properly. If you have a machinist that will work with you to teach you, they can yield tremendous results. They are not easy machines to learn to use without a teacher.
General tool work can be done with simpler tools. They are much easier to master because the tolerance in the cutting/shaping mechanisms are greater.
A lathe and a mill are wonderful tools but please don't just look them up in the catalog and then budget for them and expect to use them...
Figure on doubling the cost ( for less expensive models ) just for the tooling, collets, mills, tables, vises, hold-downs...etc...and find someone to teach you how to use them safely.
If you wish to get a single beginning precision tool that is reasonably well made...and fairly easy to use...but in a smaller size... you might take a serious look at a tool called the Mill-Drill... it functions as both a limited vertical mill and a drill press for about the cost of a better drill press... a mini mill drill runs in the neighborhood of $500 and you can expect to spend about 500- 700 on small rotary table , precision vise...tooling etc... its not a bad place to start... this type of tool is also small enough to carry with you to events... if that matters to you...
One set of items that no one seems to be mentioning are measuring tools...get a couple of good sets ... when we work in metal or plastic we should be thinking in the neighborhood of 1000's of an inch...and this requires specific and quality measuring equipment. At the very least get a couple of the cheaper digital calipers... they will last about a season of hard use..
Well I hope this helps. Many of us have a "catalog" mentality when it comes to machines and tools.. It is much better to acquire a single good tool and then get the necessary accessories to use it, AND to acquire the knowledge from a teacher....then to have a whole shop full of fancy machinery.
thanks
Unread 17-01-2005, 21:15
[527]phil's Avatar
[527]phil [527]phil is offline
Alumni
AKA: Phil
FRC #0527 (red dragons)
[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light
Send a message via AIM to [527]phil
we'll in our shop we just got a mill table for a drill press(which sucks). but i have a small max nc mill in my basement which is very versatile and the only limitation is the travel, i do believe it's 5 inches on the x-axis and 4 inches on the y-axis. i also have an old lathe that might be donated to the school if we can get approval by the Board of education. but the machine i would like is the Star Ecas 20 with an automatic barfeeder *drools. but honestly all you need is a lathe and a mill, my uncle had a machine shop for about 20 years before going under and all he really used was a lathe with a tool turret and a mill with digital readout. also if your buying machines old is not bad, the lathe that i have is at least 30 years old and was the original lathe in my uncles shop, it's still as accurate as it needs to be.
Whats the difference between mechanical engineers and civil engineers?
Mechanical engineers build weapons, civil engineers build targets
Unread 18-01-2005, 19:15
jpyro jpyro is offline
AKA: john edwards
FRC #1108 (Panthers Robotics)
jpyro is an unknown quantity at this point
Don't invest money in a metal band saw if you can get a wood band saw. From there go to a hardware store and buy a metal blade. Much cheaper
Originally Posted by NoodleKnight
Hi,
I know it's already build season, but now we have the ability to possibly get a grant for some machine tools.
So far, I read some old threads and decided to try and get a Rong-Fu desktop mill/drill machine. For those who have one, how is it? Would you recommend buying it?
Also, we're looking for a metal band saw, preferably vertical. I found a few but I have no idea how good it is. For year's we've been using a wood bandsaw with a metal cutting blade... it isn't pretty.
We have a drill press, it's old but it still works well. Hand tools are not an issue.
Are there any other tools which would be useful for a robotics team? Note, we do have a price limit, not sure what it is, but we can't ask for radical things like a bridgeport CNC.
Thanks in advance,
Jonathan
Unread 18-01-2005, 19:19
AKA: john edwards
i sugest a table saw or a circulal saw along with a saber saw, only because they are more durable
Unread 18-01-2005, 19:33
SpikeZilla2K6's Avatar
SpikeZilla2K6 SpikeZilla2K6 is offline
User Registered
AKA: Dustin Merritt
#1369 (MINOTAUR)
Team Role: Driver
SpikeZilla2K6 is an unknown quantity at this point
Send a message via AIM to SpikeZilla2K6 Send a message via Yahoo to SpikeZilla2K6
hammer!
2004 Peachtree Regional Winners
2004 Xerox Creativity Award
Unread 18-01-2005, 20:11
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
That's what we have, it takes plenty of skill to cut straight lines.
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 18-01-2005, 23:29
UlTiMaTeP UlTiMaTeP is offline
UlTiMaTeP will become famous soon enoughUlTiMaTeP will become famous soon enough
check out harbor freight www.harborfreight.com its basicly chinese copys of all the american tool companys for a 1/3 of the price. (note- do not buy hand tools from HF, but machine tools and air tools work great) They do have a horizontal/verticle metal bandsaw for i think 160 dollars which sounds like you could use it, as well as mill lathe combos for people with small budgets
Hows my searching? Call 1-800-Green-Dots
Unread 18-01-2005, 23:53
Andy A. Andy A. is offline
Getting old
FRC #0095
I would highly recommend you invest in a good belt/wheel sander and some replacement belts and disks. While you won't make parts with it, you will make parts better with it. I find that regardless of what tool I use to make a part, I'll often finish it on the sander. The mill make get the part shaped right, but the sander gets it to fit right. It also gives me a little comfort knowing that I can cut the part large and sand it to fit. With a little practice, you can produce very accurate and attractive parts.
It's probably my favorite tool in the shop. So consider investing some money on a powerful unit that can take abuse and allows for easy belt changes. Nothing is worse the struggling to get a stubbern belt back on track thats keeping you from finishing a critical piece.
-Andy A.
Unread 19-01-2005, 12:00
coreyjon's Avatar
coreyjon coreyjon is offline
Flight Engineer
FRC #0250 (Team 250 Dynamos)
coreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nice
Send a message via AIM to coreyjon
I was the lead machinist and I've also been involved with drive train/chassis since the beginning. I'm now in college, and a mentor, but I still take part with machining some of the harder bits, and at the same time teaching the kids how to use such tools. we do just about all of our machining in house, so we use the lathe and mill a lot. We have some old lathes, and one new one that the school bought for its pre--engineering class (project lead the way). Although the lathe wasn't a very expensive one, and so not that great,so you can still find me on the wade 8a toolmakers lathe that did it's duty during ww2 making machine gun barrels. So it's not always a bad idea to pick up the local want ad's and look and see what people are selling. Old used equipment can sometimes be better than cheap brand new. As for the band saw talk. We used to have to deal with a old vertical band saw that would take years to cut anything with no precision. Last year however we acquired a new horizontal band saw that can stand up and be used as a vertical band saw. I think we've used that set up only once or twice. But it makes very clean cuts that are very square, and with the ability to dump cutting fluid onto the part,you can actually handle the part without burning your finger prints off. I must suggest Harbor Freight: http://www.harborfreight.com/ . Ok, let me second the suggestion as I just read that someone already suggested it) They have pretty good prices. CNC is a nice capability to have but I find that for most of the things, the time it takes to draw it up in cad, put it into master cam, then post it out to the machine, with set up takes longer than just making a part by hand. The only reason we normally use CNC is if either the part is extreamly complex, or if we need a lot of one part, then we got to the cnc lab.
"Jack of all trades, master of none, though offtimes better than master of one".
Unread 19-01-2005, 12:04
DDRAngelKurumi's Avatar
DDRAngelKurumi DDRAngelKurumi is offline
AKA: Rumi
None #1258 (Celetor)
Team Role: Webmaster
DDRAngelKurumi will become famous soon enoughDDRAngelKurumi will become famous soon enough
Send a message via AIM to DDRAngelKurumi Send a message via MSN to DDRAngelKurumi Send a message via Yahoo to DDRAngelKurumi
Hmmmm... Well, make sure to have something like a jigsaw to make extra clovers!
Unread 19-01-2005, 14:09
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
we are definitely representing all the rookies out their with no tools
right now we have a small hand held tool box that contains all of our tools
hoping for donations of more power tools (drill press, band saw, belt sander, miter saw, etc.)
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Shop Safety Training Resources Andrew Schuetze General Forum 4 14-12-2004 13:28
Shipping Tools falconmaster Technical Discussion 9 30-03-2004 08:02
Choosing a machine shop (Re: How important is a machine shop archiver 2001 9 24-06-2002 04:20
How important is a machine shop? archiver 2001 13 24-06-2002 04:14
