Go to Post The more women we have as 'rock stars' in FIRST, the more girls we'll see celebrating math and science and the doors they can open. - JaneYoung [more]
Unread 11-01-2005, 09:02
Electrical Engineer
Rookie Year: 1995
Software Development System Installation
There have been numerous threads and posts concerning the new MPLAB, C18 compiler and problems with compiling default code. The purpose of this post/thread is to document my journey…
First of all, I am running XP home SP2 with the firewall ON in its default configuration. I am also running AVG 7.03 resident shield and Spybot 1.3 with inoculations resident.
First, I uninstalled old versions of MPLAB, C18 and IFI Loader, in that order. Uninstall of C18 was notable in that XP reported that C18 was already uninstalled and asked me if I wanted the icons removed. I said yes and moved on…
I downloaded the full version of MPLAB 7.00 from Microchip. I also downloaded C18 2.40 (via the FIRST link). I also downloaded IFI Loader 1.0.10 from IFI. Note that I did not use any files from the CDROM included in the 2005 kit.
I performed a full install of MPLAB 7.00 and answered NO to installation of ICD and ICE support. No issues.
I then performed a full install of C18 2.40 with, apparently, no issues. During the install, I checked all boxes involving the addition of C18 to my PATH, et cetera.
After the C18 install, XP complained "Application Has Failed to Start Because Framedyn.dll Was Not Found" when I started Spybot. I reinstalled Spybot which had no effect.
After reviewing information at http://support.microsoft.com/default.aspx?scid=kb;en-us;319114, I verified that framedyn.dll was not corrupted. However, I did find a problem in my PATH.
I corrected by PATH to be: C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\system32 \wbem;C:\mcc18\mpasm;C:\mcc18\bin;<and more PATH variables not relevant to FIRST> and that problem went away.
The IFI Loader installation went uneventfully except for it complaining that there were shared files in use. I told it to continue and the rest of the installation was normal.
Whew!
After all of that, I was able to build Team 177’s 2004 robot code, FRC’s 2005 default code, Kevin Watson’s 2005 navigation demonstration code and FRC’s 2005 camera code with no errors.
I will not be able to test on a robot until this afternoon. If I have problems, I’ll let everyone know…
I hope this information saves some of you some grief and frustration. Please feel free to post your experiences.
Regards,
Mike
P.S.: Moderator, please make this thread a sticky for the next week or two… Thanks.
Mike Betts
As easy as 355/113...
Unread 11-01-2005, 09:37
Re: Software Development System Installation
Somebody else reported on FIRST Q/A that the new compiler corrupted the PATH environment variable on XP (ID967).
This is definitely something people need to watch out for.
Unread 11-01-2005, 10:10
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
XP Home SP1
I uninstalled the old versions of MPLAB and C18. However the C18 icon did not go away in the add/remove programs list, but further attempts to remove only told me it couldn't find it. This happens with some uninstallers, so I ignored it.
Then I rebooted.
Then I installed MPLAB 7.0, which went smoothly. Without rebooting I installed C18 2.4, checking all 6 of the check boxes when prompted, which also went smoothly. I then rebooted.
On boot my optical mouse didn't work, it was all lit up but wouldn't move the cursor. I rebooted and the same thing. Unplugging and replugging the mouse at the Welcome Screen fixed it.
Everything seems to be working perfectly.
Unread 11-01-2005, 20:57
Terry Sherman's Avatar
Terry Sherman Terry Sherman is offline
Mentor -- Software
FRC #0093 (NEW Apple Corps.)
Terry Sherman is an unknown quantity at this point
We've installed IFI Loader 1.0.10 and attempted to download the new FRC_2005 default code. It says that it loads but the LED on thr controller that describes program failure/fault blinks. We tried the same 2005 FRC Default code with the 1.0.2 IFI Loader and it loaded and ran correctly. We also updated the Main FRX code (*.bin file) from Innovation First.
Has anyone else seen this issue?
Thanks!
Unread 11-01-2005, 21:03
Electrical Engineer
Rookie Year: 1995
Thanks!
I would most definately post this to IFI: http://www.ifirobotics.com/forum/
Mike Betts
Unread 11-01-2005, 21:08
CJO's Avatar
CJO CJO is offline
Emeritus Pain in the $@#$@#$@#
AKA: Christopher J. O'Connell
None #1097 (Site 3 Engineering)
CJO will become famous soon enoughCJO will become famous soon enough
I think that these *may* be SP2 problems. I have setup the whole system on three SP1 machines running Pro, and had no problem, however, I am using a multipurpose loader/diagnostics tool that one of the IFI guys gave us at the nationals last year instead of the IFI loader.
Team 1097 -- Site 3 Engineering
2003 Sacramento Rookie All Star
2003 Silicon Valley Rookie All Star
2004 Sacramento Engineering Inspiration Award
2004 Sacramento Visualization Award
2004 Outstanding Volunteer Award (G. Glasser)
2004 Silicon Valley Sportsmanship Award
2004 National Visualization Runner Up
2004 Cal Games Finalist
2005 Sacramento Sportsmanship Award
2005 Sacramento #1 seed
2005 Sacramento Finalist
2005 Silicon Valley Sportsmanship Award
2005 Silicon Valley #1 Seed
2005 Silicon Valley Finalist
Unread 11-01-2005, 21:45
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Hey CJO, is there any way you can upload that "multipurpose loader/diagnostics tool"?
I would much appreciate it,
Thanks,
Dan
Unread 11-01-2005, 22:02
CJO's Avatar
CJO CJO is offline
It is on a machine at school, but I'll try tomorrow. The real beauty of it (and the reason we got it) is it allows you to read programs out of the memory . . . so, if you forget to backup beofre you re-compile, and you are in the middle of a match, you can always restore back to where you were.
Unread 11-01-2005, 22:37
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
Send me a PM if you need somewhere to upload it
Unread 11-01-2005, 22:40
CJO's Avatar
CJO CJO is offline
Actually, I think I have it here, it is in a backup file, so, as soon as I finish restoring that particular disc, i'll post.
Unread 12-01-2005, 00:40
CJO's Avatar
CJO CJO is offline
I found the source, I cannot find an .exe so I am compiling, will post later.
Unread 12-01-2005, 00:51
CJO's Avatar
CJO CJO is offline
Ok, here you go,
un-tar and run.
USE AT YOUR OWN RISK
I'll post the source tomorrow. I also have source for the PIC18 firmware uploader, I am building that right now. I just put out the exe, I do not think that you will need any other files if you are running XP pro full install, I have tried it out on one machine. If it is the case that I am missing .dll's etc, I post, and I will include them. IFI loader should install all neccessary files.
Also, DO NOT HIT THE RUN BUTTON
Unread 12-01-2005, 10:44
CJO's Avatar
CJO CJO is offline
Ok, upon the advice of a couple of people I have decided not to post the bootstrap, firmware uploader, etc. because as someone put it "it is too much like leaving a loaded gun lying around." Also it is big. If anyone wants source/the other stuff, PM and I will e-mail you a link.
Unread 15-01-2005, 20:29
Rookie Year: 1234
Just a question, is there a helpfile for this anywhere?
Wondering what:
RD PRG and RD EE do, BLK ERASE, will that wipe the program code or _everything_
Also, whats going to happen if I hit the run button? If its going to screw stuff up, I'm taking the button out with resource editor
Unread 15-01-2005, 22:17
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
I too am having issues with MPLAB. At school when we tried to install v 7.00 on our laptop it flashed up a bunch of error messages right as it finished the install, so I just hit ok on all of them, then tried to run it. It flashed up another error message, but we had to leave then. Another guy took the laptop home and is trying everything he can think of to get it to work, but he is currently installing it for the third time and it still isnt working. So meanwhile I came home to try to compile the rev-3 camera code (I havent compiled anything at home yet) and it said it couldnt find about a million things, so I changed some settings and fixed that, but now the only error left is this:
MPLINK 3.90, Linker
Copyright (c) 2004 Microchip Technology Inc.
Error - could not find file 'clib.lib'.
Errors : 1
I reinstalled the IDE and C18 both and it still flashes up this message. Anyone have any ideas? I have located this clib.lib file but I cannot find any way to tell MPLAB where it is.
Attention engineers...What type are you and why? Paul H Career 95 05-04-2007 14:38
<R14> and Software Development Joe Johnson Rules/Strategy 12 10-01-2005 02:24
control system worth more than $500 archiver 2001 8 24-06-2002 02:00
software software software archiver 2001 5 24-06-2002 00:21
