Go to Post The highest seeded alliance is always placed in the red zone by the computer. In fact, its a great communist conspiracy to mold the mind of teenagers into equating Reds with winners. - Btower [more]
Unread 15-01-2005, 00:19
LBK Rules's Avatar
LBK Rules LBK Rules is offline
1467 '06 Alumni
AKA: Anthony Rinaldi
no team (HSRO)
LBK Rules will become famous soon enoughLBK Rules will become famous soon enough
3ds max 6 problems
I'm having a problem with 3ds max 6.
Every time I start the program, it locks-up whenever I get to the mentalray.dlz plugin. I've updated to SP1, reinstalled max, and made more disk space. What makes me angry is that it stopped working without any warning!
Has this happened to anyone else? What can I do to fix it?
Specs:
Toshiba Satellite A65-S126
XP Home SP2
2.8 GHz Celeron
256MB RAM - 64 for ATI M-Rage 7000
55GB Harddrive - 6.8GB Free
Anthony Rinaldi
Team 1132: 2003
Team 1467: 2004 - 2006
Unread 15-01-2005, 07:07
Jaime65's Avatar
Jaime65 Jaime65 is offline
AKA: Jaime
FRC #3398
Jaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud of
Re: 3ds max 6 problems
Specs:
XP Home SP2
2.8 GHz Celeron
The same problem happen to be but with 3ds max 7. I've tried everything to fix it, but nothing works.
Unread 15-01-2005, 08:27
Alexander McGee's Avatar
Alexander McGee Alexander McGee is offline
Hoonigan
AKA: Alexander S. McGee
no team (no team)
Alexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond repute
Send a message via AIM to Alexander McGee Send a message via Yahoo to Alexander McGee
I have a solution.
Open the max install directory c:/3dsmax7/plugins and delete the faulty plugin. Next, go back to the max directory c:/3dsmax7 and delete the file called "3dsmax.ini". This will reset the plugin loader, as well as anything else you may have changed in max. If you really need that plugin, try re-installing again. But, it should work just fine without it.
AIM me if you need more help.
-axe
-Alexander S. McGee
Intellectual Property Attorney, Mechanical Engineer, Gear-head
Unread 15-01-2005, 22:46
LBK Rules's Avatar
1467 '06 Alumni
no team (HSRO)
Yeah, I just added an "_" to the end of the mentalray plug-in file.
Now my problem is that I can't move the license back to my desktop. On my desktop, every time I run the Portable License Utility, it gives me this error:
Invalid License Information
Error code:[14.1.10]
I think it's because I tried installing the ADA software, and I installed AutoCAD out of sequence. (Nobody told me the it was in the Revit case. )
Oh, well. I'll try installing SP1, and if that doesn't work, I'll just uninstall all Autodesk and Discreet software, and reinstall 3ds max.
I just need to start modeling.
Anthony Rinaldi
Team 1132: 2003
**FIRST EMAIL**/Gear Up with Live Inventor and 3ds max Trainings! Billfred FIRST E-Mail Blast Archive 0 22-12-2004 16:30
Problems with 3DS Max Licensing jlewellen 3D Animation and Competition 10 24-11-2004 14:58
3ds max problems.. cgDynasty00 3D Animation and Competition 9 26-03-2003 07:36
Text effects in 3DS Max... Ranma 3D Animation and Competition 6 28-02-2002 21:56
Autodesk Inventor -> 3ds Max (File Format) Adrian Wong Inventor 1 22-01-2002 23:06
