Go to Post Just so you don't spend too much time on non-clues ... now you can all go back to the real one! :D - Libby K [more]
Unread 15-01-2005, 21:40
SteveO SteveO is offline
SteveO will become famous soon enoughSteveO will become famous soon enough
Will the tetras spin?
Does anyone know if the tetras will spin when they are grabbed? If I am gripping a pipe hard enough, will it slip/twist in its endcap? I know FIRST doesn't use endcaps, but will they do this?
Unread 15-01-2005, 21:41
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Will the tetras spin?
I think this was answered on the FIRST Q&A. The ends are going to be glued, so they shouldn't spin.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 15-01-2005, 22:22
Elgin Clock's Avatar
FRC #0237 (Black Magic)
From the end caps to the pipes, probably no movement. But, we experienced that law knows as the weakest link, when we glued the caps to the pipes, and thus now the nuts and screws turn themselves loose inside the pipes..
Now what, should they make it a huge threaded rod from one end to the other to attach the clovers to the pipes now instead of a small screw and nut assembly?
Or, hey.. What about using Loc-tite on the nuts.. Maybe that would work. Then it may still twist, but not unthread itself??
I'm not sure.
Unread 15-01-2005, 22:44
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
We've had bolts spinning in the clovers even with split washers. Anyone know if the real ones will have this problem?
Team 1257
Unread 15-01-2005, 22:53
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Yes, FIRST has said that the tetra pipes will be glued to the end caps. And in the part drawings, they indicate that the end caps will be attached to the LDPE tetra clovers with a bolt and t-nut (presumably, based on the drawing, a t-nut with spines that will grip the interior of the end cap to prevent rotation).
However, recognize that if you grip them by the lower horizontal edge pipe (as it is positioned when sitting on the floor) and lift it, you will be putting about 10 ft-lbs of torque on the connections at the ends of the pipe assembly. And if you bump into things and transmit shocks, the loading may be considerably higher. Given that the only thing that will prevent the entire end cap-pipe-end cap assembly from spinning around on the bolt will be the little spines on the t-nut, I am willing to put down a small wager (hey Dr. Joe! How about a case of Mt. Dew?!) that by the second weekend of competitions those pipes will be spinning like mad. I would recommend that you do not count on the pipes as rock-solid, we-will-never-spin, don't-play-me-like-a-LP structures. Devise a way to grip them so if the pipes does spin, it will not riun your day.
-dave
Unread 15-01-2005, 23:02
Fold em oval!
I think the bolt heads/washers will be spinning in the clover long before the spines of the t-nut cut through the PVC, but regardless, would field staff try to fix this as best they can (Tighten or replace hardware and clovers, etc)?
Team 1257
Unread 16-01-2005, 00:32
dlavery's Avatar
Curmudgeon
Unless the tetra actually comes apart, I doubt it. They make it pretty clear in the Q&A system that we can expect the tetra pipes to rotate:
Q 1180: We made a scoring tetra. When lifting by one of the legs the leg with the leg horizontal it rotates in spite of being tightened and glued. (we have rounded caps) Will the competition scoring tetra's legs rotate?
A: Yes, they may rotate depending on friction, etc.
Q 1182: PVC caps are glued to the PVC. Does the fastening of the cap to the tetra connector keep the PVC cap from rotating on the bolt?
A: No.
-dave
Unread 16-01-2005, 03:25
Thanks for clarifying that. We're not sure how *exactly* we're going to be gripping the pipes, but this just adds to the team's desire to grab the tetra at two points for better control.
Unread 16-01-2005, 04:04
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
Is there a rule against dismantling tetras? Like giving your robot a wrench or whatever and having it actually undo the bolts? I am not sure why one would want to do this, but some teams are talking about how many tetras they can fit on their bot, and if they could quickly assemble/dissassemble the tetras it would be a lot easier to store them.
Unread 16-01-2005, 04:17
I'm guessing this wouldn't be allowed... I know its illegal to intentionally damage the field <S09> and probably the tetras too, though some tetras are bound to be accidentally damaged. Hats off to any team that is able to give their robot a wrench and dismantle and reassemble a tetra though
Unread 16-01-2005, 09:58
Aignam's Avatar
Aignam Aignam is offline
This Space For Sale
AKA: Anthony Mangia
Team Role: Scout
Aignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant future
Send a message via AIM to Aignam Send a message via Yahoo to Aignam
That's definitely illegal. 100%. Maybe you weren't around for it last year, but FIRST stressed that when reading and interpreting the rules, we always let gracious professionalism and common sense prevail. This falls under common sense, I believe.
Basically, if something *seems* extremely illegal, but there is no specific rule against it, count on it being made indirectly illegal by some other rule (in this case the "no damaging the field or field components" rule), or just being so lacking in common sense that it is assumed to be illegal.
Know what is and is not illegal, but also know what is and is not in the spirit of the rules.
This isn't focused just on you---lots of other people should probably take notice. Here, have some positive reputation for thinking outside the box.
Some Thoughts to Ponder
How does a sign turn into a lady friend? Don't optional stop signs ruin the purpose? What are pneumatics? Am I really banned from 229 for life? Can walls get bigger?
Aignam. Pronounced A-Num. Mangia backwards.
NJFIRST.org | Best Thread. Ever.
AIM: Aignam | ICQ: 265237569 | E-mail: AnthonyMangia@aol.com | HTTP: www.aignam.com
Unread 16-01-2005, 14:18
Collmandoman Collmandoman is offline
Post-A-Holic
Collmandoman has a spectacular aura aboutCollmandoman has a spectacular aura aboutCollmandoman has a spectacular aura about
oh my goodness =/ people need to be practical-- this is the downfall of many teams - Think of what is possible, and go with it.... taking apart tetras only to reassemble them(for space)... is .... you know.... not bright at all(NOT EFFICIENT or anything)~ Even with an EXTEMELY sophisticated robot.. you'll have time to do this once during a match. MAYBE TWICE..
I'm gonna get flamed
Unread 17-01-2005, 16:48
Spikey's Avatar
Spikey Spikey is offline
Its NOT a Camera
AKA: College Advisor
FRC #0293 (SPIKE)
Spikey is just really niceSpikey is just really niceSpikey is just really niceSpikey is just really nice
After reading the first Q&A it does specify in one post that if one of the PVC pipes rotates thats okay, so even if they are glued rotation is something that is not out of the question.
It's not a bug it's a feature!
"No, you may not drill holes in the air tanks to lighten them." -FIRST Q&A Repsonse to a question about lightening air tanks.
I'm the Not a Camera Kid at the New Jersey Regional But Not This Year, I am at Syracuse University Class of 2009
Uncrowned Champions of the 2005 Philadelphia Regional
SPIKE X NJ Xerox Creativity Award. Chesapeake Regional CHAMPIONS, and Motorola Quality Award
2006 Semi-Finalist at NJ Regional & Semi-Finalist at Chesapeake Regional, winners of the 2006 Xerox Creativity Award, and Judges Award
"Looks like SPIKE is doing its Batman thing again, that team looked like it was going to score, but SPIKE was not going to allow that to happen" -Play by play call at the Chesapeake Regional
Unread 19-01-2005, 09:00
Digo's Avatar
Digo Digo is offline
AKA: Rodrigo Ribeiro
#0383 (Brazilian Machine)
Digo is on a distinguished road
Send a message via MSN to Digo
Thumbs down It should be different
I know now itīs done, but I would like to share my point of view. Itīs not useful now, but may be for next year.
The tetra should be made to spin for sure or not to spin for sure. This doubt prevents you from thinking in many possibilities. You will not design a claw/arm counting that the tetra does/doesnīt spin knowing that this situation may change later, or that the tetras may be different from each other. So you need to give up thinking both ways and think about something that works both ways. I guess that limitation could have been avoided.
And I donīt think "thatīs part of the challenge", because this way you donīt know what the challenge is.
Rodrigo Ribeiro
Team #383 - The Brazilian Machine
Mechanical Engineering student at UFRGS - Porto Alegre - RS - Brazil
Unread 19-01-2005, 09:07
Fold em oval!
Re: It should be different
Our design definitley was affected by the tetras spinning, but I don't see how its different than any other "part of the challenge." Not knowing the exact parameters of the problem is definitley a common challenge in the real engineering world.
Team 1257
Q/A questions so far.. AmyPrib Rules/Strategy 49 28-01-2005 08:39
Question: Missing Tetras in Human Loading Zone? tribotec_ca88 Rules/Strategy 7 15-01-2005 15:26
How to Stack Tetras in Inventor petek Inventor 0 13-01-2005 11:47
Just where are vision "bonus" tetras placed? David Brinza Rules/Strategy 17 10-01-2005 20:50
Manipulating tetras from the ground. Petey Rules/Strategy 4 08-01-2005 23:19
