Go to Post 5:20 - Lots of discussion about how FIRST pretty much wipes out the world of at least one object every year. - Andy Grady [more]
Unread 14-01-2005, 15:31
Derek t Derek t is offline
Derek t is an unknown quantity at this point
MPLab build error
I can't seem to find out why this error is occurring. Does anyone know how to fix this? when I try to build the code it gives me this:
Executing: "C:\Program Files\Microchip\MPASM Suite\MPLink.exe" /l"C:\mcc18\lib" "18f8520user.lkr" "C:\Documents and Settings\bishop\My Documents\robot code\2005\Navigation_FRC\FrcCode\main.o" "C:\Documents and Settings\bishop\My Documents\robot code\2005\Navigation_FRC\FrcCode\user_routines_fas t.o" "C:\Documents and Settings\bishop\My Documents\robot code\2005\Navigation_FRC\FrcCode\user_routines.o" "C:\Documents and Settings\bishop\My Documents\robot code\2005\Navigation_FRC\FrcCode\printf_lib.o" "C:\Documents and Settings\bishop\My Documents\robot code\2005\Navigation_FRC\FrcCode\ifi_utilities.o" "C:\Documents and Settings\bishop\My Documents\robot code\2005\Navigation_FRC\FrcCode\ifi_startup.o" "C:\Documents and Settings\bishop\My Documents\robot code\2005\Navigation_FRC\FrcCode\robot.o" "C:\Documents and Settings\bishop\My Documents\robot code\2005\Navigation_FRC\FrcCode\encoder.o" "C:\Documents and Settings\bishop\My Documents\robot code\2005\Navigation_FRC\FrcCode\gyro.o" "C:\Documents and Settings\bis
hop\My Documents\robot code\2005\Navigation_FRC\FrcCode\pid.o" "C:\Documents and Settings\bishop\My Documents\robot code\2005\Navigation_FRC\FrcCode\FRC_library.lib" /m"C:\DOCUME~1\bishop\MYDOCU~1\ROBOTC~1\2005\output \FrcCode.map" /o"FrcCode.cof"
MPLINK 3.90, Linker
Copyright (c) 2004 Microchip Technology Inc.
Error - Could not find linker command file '18f8520user.lkr'.
Errors : 1
BUILD FAILED: Fri Jan 14 13:27:30 2005
Unread 14-01-2005, 15:34
Re: MPLab build error
The directory where you are storing your code is too long for the compiler to handle. Move your stuff to a shorter directory such as c:\code\
The limit is 63 characters, if I remember correctly.
Unread 16-01-2005, 00:10
ah.... yes. Why didn't I think of that before? had that problem with the last compiler too.... thanks for finding that out! I would have never... the last compiler actually told you that the line was too long.... too bad this one doesnt.
Unread 16-01-2005, 00:21
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
Yeah I was just waiting for someone to answer my post about this.
Unread 16-01-2005, 00:24
russell's Avatar
#1430 (WRONG)
wait no. That still didnt do it. My message is a little differnt too. Mine says
MPLINK 3.90, Linker
Error - could not find file 'clib.lib'.
Errors : 1
Unread 16-01-2005, 20:03
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Mine said this for a while, too. Go into the project build options (Project > Build Options... > Project), then hit "Suite Defaults". This should fix the problem.
Unread 17-01-2005, 00:16
russell's Avatar
#1430 (WRONG)
sweet! People in another thread have been giving me a million different paths to type in there, and all this time all I had to do was hit default. Of course the name is still too long, but I can fix that! Thanks!
Unread 17-01-2005, 09:33
Sorry about that, I thought you'd already tried Jamie's suggestion.
MPLAB build error cabbagekid2 Programming 7 12-01-2005 13:36
MPLAB IDE 6.60 Error mchan1111 Programming 8 08-11-2004 20:17
MPlab error ryan_f Programming 9 24-05-2004 07:30
Error message in MPLAB IDE dddriveman Programming 11 18-03-2004 06:34
Mplab startup error Team 869 Programming 6 25-01-2004 10:41
