Go to Post Remind me to wear my kevlar vest to any event you're at. - Andrew Schreiber [more]
Unread 16-01-2005, 00:29
Anchi Anchi is offline
nekura
#1288
Anchi can only hope to improve
Send a message via AIM to Anchi Send a message via MSN to Anchi Send a message via Yahoo to Anchi
Re: Gracious Professionalism at your local hardware store
it would be prety funny if corprate knowtesed and uped the number all stores have in stock then all the sudden noone needs them. heh
"If knowlage is power, dose that make me a weapon of mass destruction?"
"Everyone is entitled to their own worthless opinion, only mine is important."
Unread 16-01-2005, 00:53
Roland's Avatar
Roland Roland is offline
Post-A-Holic
#1466
Team Role: Webmaster
Roland is infamous around these partsRoland is infamous around these partsRoland is infamous around these parts
Could be worse, remember the fiasco with the balls last year.
Unread 16-01-2005, 01:26
elknise's Avatar
elknise elknise is offline
AKA: Erik Knise
FRC #1318 (Issaquah Robotics)
elknise will become famous soon enoughelknise will become famous soon enough
We found our in the plumbing section. We are going to look at an electrical supply house to see if we can find the flat end caps similar to what is going to be used at the competition.
If your local home depot doesn't have them, try an electrical or plumbing supply place. They are sure to have a lot more in stock than a hardware store.
Elknise
Issaquah Robotics
Unread 16-01-2005, 21:02
MisterX's Avatar
MisterX MisterX is offline
Alumni
AKA: Mr. X
FRC #0521
MisterX is a splendid one to beholdMisterX is a splendid one to beholdMisterX is a splendid one to beholdMisterX is a splendid one to beholdMisterX is a splendid one to beholdMisterX is a splendid one to behold
There is really only 1 other team in eastern connecticut and they are 30 minutes west of us ( our sister team) and it took us going to I think 6 different hardware stores before we could get enough end caps to put just 1 smaller tetra together so we have had to order some which we hope to have by tuesday.
Unread 17-01-2005, 14:36
dhitchco's Avatar
dhitchco dhitchco is offline
Awards/Photo/Video "wizard"
AKA: Doug Hitchcock
FRC #1511 (Rolling Thunder)
dhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant future
Gracious (workrounds) at your local hardware store
As discussed elsewhere in this forum, if you're still struggling to find PVC endcaps for the practice field tetras or goals, here's a couple of hints.....especially for the goal units.
1) Use plastic tie-wraps to hold together the corners of the goals. Just drill holes through both ends of all six (6) goal pieces and "thread" the tie-wrap through three poles at each corner. leave the tie wraps loose until the goal is assembled, then "cinch" them up.
2) If you have the PVC end caps but not enough "clovers" to hold the corners together, go look for "pipe strap" in the plumbing section. It is soft metal, comes in a roll and is perforated every 1/2" or so. Just cut into short segments and bolt through three pieces of the pipe strap, connecting each corner of the goal. Bend down the sharp ends too.
Unread 17-01-2005, 15:49
CJO's Avatar
CJO CJO is offline
Emeritus Pain in the $@#$@#$@#
AKA: Christopher J. O'Connell
None #1097 (Site 3 Engineering)
CJO will become famous soon enoughCJO will become famous soon enough
Re: Gracious (workrounds) at your local hardware store
If (like us) you are in a rural area, try irrigation supply places, home depot was nearly out, the local irrigation place had like 300 in stock.
Team 1097 -- Site 3 Engineering
2003 Sacramento Rookie All Star
2003 Silicon Valley Rookie All Star
2004 Sacramento Engineering Inspiration Award
2004 Sacramento Visualization Award
2004 Outstanding Volunteer Award (G. Glasser)
2004 Silicon Valley Sportsmanship Award
2004 National Visualization Runner Up
2004 Cal Games Finalist
2005 Sacramento Sportsmanship Award
2005 Sacramento #1 seed
2005 Sacramento Finalist
2005 Silicon Valley Sportsmanship Award
2005 Silicon Valley #1 Seed
2005 Silicon Valley Finalist
Unread 18-01-2005, 15:13
james james is offline
james is an unknown quantity at this point
Dudes you dont go to a hardware store for plumbing supplies DUH..
Unread 18-01-2005, 15:21
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
We went to home depot for supplies to build vision targets yesterday. We ended up getting the last can of flourecent green paint. I suspect that other teams paid them a visit before us - who else would use it? And to any teams planning to visit the Cupertino, CA Home Depot some time soon...sorry.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 18-01-2005, 17:05
[527]phil's Avatar
[527]phil [527]phil is offline
Alumni
AKA: Phil
FRC #0527 (red dragons)
[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light
Send a message via AIM to [527]phil
we'll at home depot it went like this:
Steve: "do you have any 1 and 1/4 inch PVC end caps"
salesman: "your from robotics aren't you?"
Steve: "uhhh, yeah"
salesman: "nope no more end caps, the last team cleared me out"
i don't know how our mentor got some but the next day we had 2 boxes of them lying on the workbench
Whats the difference between mechanical engineers and civil engineers?
Mechanical engineers build weapons, civil engineers build targets
Gracious Professionalism of 498, 696, & 80 Penny Thanks and/or Congrats 7 22-03-2004 01:27
Loss of Gracious Professionalism Among First Teams Melissa Nute General Forum 82 31-03-2003 19:34
What is gracious professionalism really? A. Snodgrass General Forum 9 20-03-2003 05:53
Gracious Professionalism Award Redhead Jokes Regional Competitions 3 10-03-2003 14:53
An abundance of gracious professionalism.... archiver 2000 0 23-06-2002 22:36
