Go to Post I have photos of students working the lathe dressed for a concert! Makes me wish for a formal dress night at robotics. - Mark McLeod [more]
Unread 16-01-2005, 09:38
SmokeyLP SmokeyLP is offline
SmokeyLP is an unknown quantity at this point
Front wheel steering VS. 4WD
My team cannot decide on a drive train. We are either going with the four-wheel drive that FIRST provided or with a rear wheel drive and front wheel steering.
These are our arguments:
4WD:
Simpler design
Turning in one spot
Using 2 transmissions
Steering:
No chains to break
Easier control (programmed with steering wheel or 1 joystick)
So what should we do?, are there any other pros and cons to this?
My team members need some convincing!
Unread 16-01-2005, 09:56
Pshyco's Avatar
Pshyco Pshyco is offline
Bulider
AKA: Phecda Louie
#1241 (Theory6)
Team Role: Student
Pshyco is on a distinguished road
Send a message via MSN to Pshyco
Re: Front wheel steering VS. 4WD
It depends what you feel is need for the startegy you are going for...
if your strategy needs lots of pushing with other robots and protecting goals then 4wd is good...
but stearing has its good points too...
Unread 16-01-2005, 11:54
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
With 6 robots on the field and a lot of tight corners to get stuck in, I would go for the spin-in-place 4WD, but that is just my opinion.
Unread 16-01-2005, 11:56
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I would not go with a steering robot. I've seen many robots go that route for the good theoretical reasons, but in reality I have never seen it work too well on a FIRST robot. It is less maneuverable and actually harder to control. As far as chains go, for 4 wheels drive you could buy two more gearboxes then have a separate one for each wheel I suppose.
Unread 16-01-2005, 12:02
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Car like steering = Hard to maneuver!
I would go with 4 wheel drive.
A steering robot is like driving a car in a crowded parking lot... Except you do not have to stop to shift into reverse!
Instead of 4wd you could have a 4 wheel drive to 2 wheel drive conversion by simply lowering casters that pick up the 2 front or 2 back wheels.
We have done this the past 2 years and we have used both Pneumatics and a Globe motor.
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 16-01-2005, 12:03
jrocket567 jrocket567 is offline
FRC #0617
jrocket567 will become famous soon enoughjrocket567 will become famous soon enough
its a small field with 6 robots buzzin around on it.. the steering better have a heck of a turning radius.. also for the steering, im assuming you are thinking about how a car turns, more or less.. hope you have a heck of an idea on how to do that easily and efficiently at ALL speeds.. its not as easy as it looks.. with 4wd, if you tension the chains correctly, and align the wheels and sprockets right, the chain will never break.. the problem with 4wd is the differential in turning.. the outside wheel needs to go faster than the inside wheel.. find someone with a 4wd truck and ask them to go drive it in tight circles in a dry parking lot in 4wd..its not pretty.. a robot will not have the drastic effects that the truck did, but you better make sure that it is well built and aligned properly.. unless you have a proven method for the front wheel steering, I would go with the proven 4wd.
j
Unread 16-01-2005, 12:31
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
yup one more for 4wd here. The only year the steering made sense was for Stack Attack because it just made sense for going around the wall and up the ramp into the pile of boxes. You're just going to be weaving between too many robots and tetras in this game to make it worth while. On the other hand, it will be a blast to drive.
Team Website
Unread 16-01-2005, 13:58
wmcjhi's Avatar
wmcjhi wmcjhi is offline
Dukes
None #0123
wmcjhi is an unknown quantity at this point
Yet another vote for 4wd...You won't have room for even a tight turning radius and defense will be important this year, so you'll need the 4WD's power.
If you need any help with/info about overclocking, drop me a PM. I have an AMD Athlon XP 2000+ running at 3300+.
wmcjhi = white man can't jump high
Want an overpriced, underpowered processor? Pick up a P4 Today!
Have to build a trebuchet for class? I just built one, let me know if you'd like assistance!
2 GMail Invites available. PM me with your email address to receive one!
Unread 16-01-2005, 14:41
Brandon Holley's Avatar
Ditto on the 4WD, its been said. Car steering on a crowded field is simply just too difficult to control. 4 wheels does have its cons, but if you do go car steering, im sure you will quickly discover that it is very difficult to maneuver. In my past years I've seen teams with that kind of drive struggling.
...(this post not meant to slander the steering drive name)...
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 19-01-2005, 22:12
Jeffel Jeffel is offline
AKA: Jeff Ellis
#0269 (Cooney Tech Robotics)
Jeffel can only hope to improve
Send a message via Yahoo to Jeffel
i'd have to stick with our drivetrain and go with 4 wheel drive. We use it every year now and it just works the best. It also has the most control especially when driving at your top speed
Plus... i dont get your argument against 4WD about the breaking chains?
Jeff
Unread 19-01-2005, 23:00
elknise's Avatar
elknise elknise is offline
AKA: Erik Knise
FRC #1318 (Issaquah Robotics)
elknise will become famous soon enoughelknise will become famous soon enough
4WD, i could see you getting stuck with front wheel steering. Also, try driving a remote control car in a scaled down field fron about 20 to 50 feet away, hard isn't it.
Elknise
Issaquah Robotics
Unread 20-01-2005, 10:40
Denman's Avatar
Denman Denman is offline
Tie Wrap-Not Cable Tie or Zip tie
AKA: Stephen Denman
FRC #0759 (Systemetric)
Denman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud of
Send a message via ICQ to Denman Send a message via AIM to Denman Send a message via MSN to Denman Send a message via Yahoo to Denman
the only problem with 4 wheel drive is your more likely to get stuck against a wall or something straight...
Steering is hard to program / control i would say. You need to find a good method of controlling with the joysticks for that. ..
I am an ex-member of team 759.
759: regional winners with 522 and 233 NYC (2004)
FIRSTWiki.org - Contribute, learn, inspire.
"Teach the way of the GP and the way of the GP shall teach you" - Me
Unread 20-01-2005, 12:15
abeD's Avatar
abeD abeD is offline
FRC #4707 (Mentor FRC#4707 Alumni FRC#710)
abeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to behold
If you have the weight you could play with a 4wd and 2 wheel steering system. People have used this in the past with some success. Change the non-steered wheels to omni-wheels and you can now strafe (aka Wildstang 2004 w/o the pnematics to go up and down). If you want simplicity 4wd tank is the way to go.
http://www.wildstang.org/gallery/vie...&id= P2201799
Penn Class 08
Unread 21-01-2005, 01:54
elknise's Avatar
AKA: Erik Knise
I didn't know you can get stuck, wouldn't your robot just spin out of it?
Elknise
Issaquah Robotics
Unread 21-01-2005, 02:08
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Or howabout 6WD...Even more maneuverable than 4WD, i think i spelld that wrong. Oh well. Because the turning radius would be around which ever side has the more weight because the middle wheel is slightly lowered. This may add some more weight though, but you could just have two gearboxes, one for each side, and then have the gearbox placed in the middle of the robot and attach the middle wheel to that and use two sprockets, one for the front and the other for the back. That's a basic 6WD drivetrain. If you're using the gearboxes from the KOP, you are going to have to machine wheel hubs because the wheels they provide do not fit onto the shaft. Also you may have to purchase new sprockets to fit onto the shaft coming out of the gearbox because I don't believe that the two sprockets including the wheel can all fit on the gearbox. I dunno, that's just what I gotta say. Good luck on your robot.
Steering wheel problems jgannon Programming 4 16-01-2005 14:25
Steering wheel issues jgannon Programming 5 15-12-2004 10:14
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
need glp programing steering with a steering wheel Matchew Programming 2 10-02-2003 14:20
4 wheel steering/ Crab Huey_Da_X-cat Technical Discussion 3 11-02-2002 22:49
