Go to Post I remember going to Houston in 1998 and seeing a bot that could move sideways. Talk about inspiring... - Ken Patton [more]
Unread 16-01-2005, 13:57
n0cturnalxb n0cturnalxb is offline
AKA: Shirley
#1159 (Ramona Rampage)
n0cturnalxb will become famous soon enoughn0cturnalxb will become famous soon enough
Send a message via AIM to n0cturnalxb Send a message via MSN to n0cturnalxb
Arm design - rotation mechanism?
I was discussing a design I came up with with a mentor on my team and he mentioned that getting a part of the arm (eg the manipulator) the rotate the way I wanted it to would be difficult/complex. Annd.. since I'm no engineer (yet! HA -cough-), I wanted to ask..
Just how complex is it to get a part of your arm to rotate? Preferably 180 degrees..
For example, something like this:
Before rotation:
After rotation:
It'd just be the horizontal part that would be rotating, I guess.
If it's mechanically feasible and not overly complex, how weak would the rotating horizontal part become? Would it be able to sustain a good amount of vertical force without falling apart (breaking) or malfunctioning?
If there is any information related to this outside of ChiefDelphi, please point me there I'd greatly appreciate it.
Thanks!
PS: I'd imagine the rotation would have to depend on a motor or something, but I'm not completely sure how difficult/complex it would be to build something that works smoothly/consistently like that.
[edit] SteveO brought up a point I failed to address.. the horizontal bar would be rotating up and over (vertically), not right to left/left to right (horizontally).
zip ties and duct tape: the answer to all of life's problems
Unread 16-01-2005, 14:03
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
Re: Arm design - rotation mechanism?
Rotation isn't very hard to do. simple gear reduction or usage of sprocket and chain can let you do rotations easily. Use a turret or lazy susan.
-Arefin.
Unread 16-01-2005, 14:50
SteveO SteveO is offline
SteveO will become famous soon enoughSteveO will become famous soon enough
That bar you have, is it rotating from left to right or up and over? Rotating it from left to right like Arefin says with a turret is mechanically feasible and pretty easy to set up.
You can make an arm pretty beefy depending on what access you have to materials and machines. Usually for us its more difficult to stay under weight than have things tough enough.
Unread 16-01-2005, 17:41
AKA: Shirley
Oops.. it should be rotating up and over. Editing post now, sorry about that.
Unread 16-01-2005, 17:48
It's definitely feasible, and its what we plan to do as well. Your main obstacle is getting enough torque out of whatever you are using to rotate it. You can do this with gear/pulley reduction and a strong enough motor. We're thinking the Fisher Price...
Unread 16-01-2005, 18:10
AKA: Shirley
But would implementing rotation weaken the device? As in.. with rotation, would it still be able to hold as much weight as it could without rotation?
My team's main concern, as far as I know, is complexity.. would it be easy to break but difficult to fix, for example?
Sorry for the incessant questions, and thanks for your quick responses
Unread 16-01-2005, 18:28
Well, yes it would weaken it, but then you would only have a solid non-maneuverable bar . It shouldn't be too complex to replace if it breaks or malfunctions; we made a bar that rotated like you are describing last year out of modified 2" aluminum square tubing. It was light and durable and really easy to make replacements. Just remember that the arm is going to be most vulnerable at that joint that it rotates, so try to reinforce that as best you can. Also, torquing that arm in a direction perpendicular to its rotation is whats going to be your biggest concern with all these robots crashing into each other and entangling arms (at least thats what our problem was last year).
Arm Design Input -- Four Bar Linkages Sachiel7 Technical Discussion 4 18-01-2005 01:29
Telescopic Arm and grabber design help M. Hicken Technical Discussion 13 17-01-2005 12:56
Interrupts and rotation sensors kor Programming 3 12-02-2004 11:05
How do you design your robot? Gui Cavalcanti General Forum 23 16-11-2003 18:33
Reflected Inertia? archiver 2001 9 24-06-2002 03:50
