Go to Post FIRST, grant me the serenity to accept the things I cannot drill, Courage to drill the things I can, And wisdom to know the difference. - Bill_B [more]
Unread 16-01-2005, 12:46
Jim Zondag's Avatar
Happy Birthday! Jim Zondag Jim Zondag is offline
Team Leader
FRC #0033 (Killer Bees)
Jim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond repute
Re: Kitbot/cims/transmissions running too slow?
For the past several years, Team 33 has been able to get our robots to reach over 90% of the theoretical free speed. If you are only getting 60%, something is wrong. Easiest way to find it: remove the chip motors and check for friction. Without the motors in the system, everything should spin freely when you turn the wheels by hand. If it doesn't, figure out why.
"To learn what is possible, we must attempt the impossible." Arthur C. Clarke
Unread 16-01-2005, 13:17
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
6" skyway wheel chair wheels (usual kit stuff). Chain had appropriate slack. Also the bot didn't drift to either side when full power - it went straight. Indicating the fact that if there were something wrong it would have had to happen in both gearboxes, or at least one motor in each box. So I'm almost certain there wasn't a mechanical problem. I also don't think we happened to receive (4) defective cims. So if everyone is positive these cims perform 5300 rpm free speed. Then it really only leaves one conclusion, that the RC wasn't providing full power. We also had the old victors (883's?). Anyhow, I'll measure the voltage tomorrow and let you know.
Dan
www.179swampthing.org
Unread 16-01-2005, 17:13
Swampdude's Avatar
AKA: Dan Quiggle
Well I couldn't get there today, but I had Amanda check the voltage on the output speed controllers, she told me they were reading 12v on the output at full power. I also had her spin the drive wheels - spun freely. Gearbox is in good shape. So I'm out of ideas... I prefer my dew cold please...
I'll have to make a little video to prove it all, since I doubt anyone will believe me now. I guess I'll try a different method of testing the speed, but the last was pretty good, and the chassis is visibly slow.
sirbleedsalot's Avatar
sirbleedsalot sirbleedsalot is offline
FRC #0939
Team Role: Student
sirbleedsalot has a spectacular aura aboutsirbleedsalot has a spectacular aura aboutsirbleedsalot has a spectacular aura about
You say that you used the 6 inch kit wheels, but aren't they 8 inch. At least that is what our team got.
our web site
Unread 16-01-2005, 17:26
Swampdude's Avatar
AKA: Dan Quiggle
We've got 6" from years past kits. We also purchased a dozen from this past yard sale.
Unread 16-01-2005, 17:28
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
I'm stumped too.
Try switching the Chips... see what happens.
I'll bring you your dew in Atlanta.
JV
Unread 19-01-2005, 17:32
Steve P Steve P is offline
#0521 (L33t Cr3w)
Team Role: Driver
Steve P is infamous around these parts
Send a message via AIM to Steve P
Originally Posted by jimfortytwo
2003: two 1/2" drill motors in high
38% 10.5ft/s real, 27ft/sec projected
(resulted in intermittent breaker and controller resets!! )
Dear god, you wanted 27 feet a second? I thought 11fps was absolutely insane.
Unread 19-01-2005, 18:50
Evan Austin Evan Austin is offline
out of my mind, be back later
Evan Austin is an unknown quantity at this point
Talking Re: Kitbot/cims/transmissions running too slow?
What is the gear reduction ratio of the kit transmission for the chippewa motors? Are you running four chippewa motors for drive or just two? I don't have any numbers for it but our 2004 bot with two chippewa motor drive, 12 inch wheelchair wheels and about 29:1 final drive ratio would absolutely FLY!
I will agree with you, your problem has me stumped too. Since your driveline feels smooth and you have already ruled out voltage problems, I don't see why it would give you problems. As for having defective motors, it is highly unlikely that you would wind up with two lemons in the same kit. Good luck, Swampdude!
Unread 19-01-2005, 19:19
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
You might try taking off one CIM from each side. Since the interest is in top speed, a single motor should provide the answer. Also try the single in both positions, by trial and error (well somewhat scientific) you should be able to narrow it down to which motor(s) or gears are causing the problem. A burr or slight clash from the CIM gear can also reduce your speed.
I know you checked but any interferences?
Andy Brockway
Team 716, The Who'sCTEKS
Unread 19-01-2005, 20:16
Dan,
There are several threads discussing using a voltmeter on the output of the controllers. Don't believe them. The true indicator is the LED on the controller. If it isn't at full red or full green then you are not at full output. Both motors are connected and wired to run in the same direction? Are you sure of your wiring? Four Chalupas in trouble are going to draw a lot of current and therefore voltage drop in the wiring. Do the robot wheels turn faster when you lift the robot off the floor? Might be some misalignment in the wheel bearings. Try raising the robot and bypassing the speed controller, running breaker out to motor direct. Do they spin faster?
Unread 19-01-2005, 21:34
Swampdude's Avatar
AKA: Dan Quiggle
First let me preface this by saying it's now going 8.5'/s
OK last night I got some answers, but it's still not clear. The original setup had the 2005 motors in it, and transmissions assembled such that they made a little noise but not bad. They weren't greased yet. Just a student slapped together out of the box kit. But from a distance it all looked right. So we performed the tests and it ran slow - 5'/s.
Over the last few days we removed the 2005 cims. Milled and faced off some gears and Also added a gear to mate with the FP's Then installed cims from 2003 and 2004. They now weigh 8.5 lbs with motors.
Last night I tested the output voltage to be 12v
then we put a zip tie on the wheel letting it whack a piece of plastic so it was loud and ran it for 20 seconds (up on blocks) with a stop watch. I counted in 4-4 timing marking on a sheet while keeping the beat (I gots rhythm). I counted 108 revolutions/20 seconds x 3 = 324 rpm at the wheel (and I got the same results twice). Which on a 6" wheel works out to be 8.5'/s
So what happened?
I did notice the students had the gearbox assembled incorrectly "After" the mods. So it's possible they we're incorrectly assembled prior to this and during the original testing. Also I saw that the cables were all hastily crimped loose and the connectors were not screwed tightly on the controllers.
Analysis:
1. Either our 2005 kit cims are bad.... Nah...
2. Our transmissions were assembled incorrectly.
3. Teenagers in a hurry wired it up.
Answer:
SLOW DOWN YOU CRAZY KIDS!!!!
Why are teens always in such a big hurry? Where's the fire? Why does everything always have to be done in a nanomicrosecond?
ok off my soapbox
After all this, we don't plan to use these on our competition bot. But it's turning out to be a great sparring/practice system.
Unread 20-01-2005, 14:16
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Ghetto!
Unread 22-01-2005, 23:27
Projectchon's Avatar
Projectchon Projectchon is offline
AKA: William Lei
FRC #1009 (Vainer Robotic)
Projectchon can only hope to improve
i'm not a pro, but this is what i'm going to say:
Temperature maybe is a small facter, but i think is the Voltage.
Did you change the pin inside the gearbox?
Team 1009
Unread 23-01-2005, 11:17
Kit Gerhart's Avatar
Mentor, coach, whatever--
FRC #0233 ("The Pink Team")
We had our kitbot running today and did a speed test.
Our configuration was using 6" wheels.
also used the 21 tooth for the counter shaft
and the 28 tooth for the wheels
we measured it's speed to be 5'/sec
If you figure those cims are running at 5300 free speed
reduced 12.75:1 (gear) and 1.333:1 (sprocket)
we should have been moving 8.15'/sec
I assume you've check this, but make sure you're getting full power. The led's on the speed controls should be green in full "forward" and red in full "reverse." If they're not, recalibrate your speed controls.
Team 1062, The Storm, 2003
Could FIRST be updating there website it is running extremely slow. Mr.G Chit-Chat 3 01-01-2005 21:22
Running OSX 10.3 on a Macintosh Centris Joe Matt Chit-Chat 4 27-10-2004 00:37
How slow is too slow? Joe Ross Rules/Strategy 23 12-10-2004 20:23
Dual sites on home server running apache? Mike AA IT / Communications 7 28-08-2004 02:02
A vampire running for office MissInformation Chit-Chat 2 30-08-2003 14:36
