Go to Post Mentor: How is that held in place? CAD Lead: Go to the hardware store and buy a bag of constraints and put the constraints on the robot. - Kenyow [more]
Unread 16-01-2005, 18:38
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: How to Make MS joystick work/has anyone used it in past?
Originally Posted by russell
Its doable (assuming the RC is fast enough) but you are going to need a serious software genius.
The OI will only send the button values to the RC 40 times per second, so it's not doable. The data coming from the joystick over the button inputs will be changing much faster than that.
Unread 16-01-2005, 18:50
KVermilion's Avatar
KVermilion KVermilion is offline
... clearly ...
#0649
KVermilion is infamous around these parts
It's Definatly doable... in hardware!
Allot of DAC work
Unread 16-01-2005, 19:04
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Can you legally put that stuff on the OI end? What are the restrictions on whats inputting to the OI?
Team 1257
Unread 16-01-2005, 19:35
KVermilion's Avatar
... clearly ...
#0649
AFAIK as long as you don't use any external power sources, or emmit any light... it's ok
Unread 16-01-2005, 21:08
<R69> says that any device connected to the joystick port must be only powered through the joystick port.
Unread 16-01-2005, 22:29
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Originally Posted by KVermilion
AFAIK as long as you don't [...] emmit any light
Actually, there are pins set aside on the controller ports specifically for hooking up LEDs. It's all documented in the OI guide.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 17-01-2005, 00:45
KVermilion's Avatar
... clearly ...
#0649
Well.... those are specificly exempt, right? or are you saying... "you can use a 20 million candle power spotlight"?
Oh yeah, hooking up a "computer" to the joystick ports is also not allowed.
Unread 17-01-2005, 00:59
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
If you read the Operator Interface manual, it says that the LED pins provide 5V at 10mA. The rules don't appear to say what you can and can't connect there (except for a computer), but the current restrictions seem to limit you to LEDs. (Well, unless you have a 20mil candela lamp that only draws 10mA... I'd buy one. )
_
Unread 17-01-2005, 01:16
KVermilion's Avatar
... clearly ...
#0649
Well... technically, if it runs on the computer's battery....
Unread 17-01-2005, 07:14
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
Write a Windows application to collect user inputs from your interface device. Format the data and push it to the mini-RC via the serial port. Use the 8 PWM outputs on the mini-RC to drive servos coupled to 100k pots via gears. Connect the pots to OI inputs. Pots are not electrically connected to the OI and would have their own power supply. But is it legal?
Unread 17-01-2005, 10:34
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
AFAIK there is no specific rule prohibiting this. But the spirit of the rule that prohibits the connecting of laptops to the joystick ports is that a PC or PDA is not allowed to control the robot. So, judging by the spirit of the rule, it is definitely not legal.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Joystick questioin, FIRST response Justin Stiltner Electrical 0 20-01-2003 14:03
Please help make the Nationals in Houston AWESOME ... You be the Tournament Director Natchez General Forum 42 13-12-2002 18:50
Does anyone have an idea on how to make a joystick program for an operating board? necroprime Programming 8 09-11-2002 19:04
Programming the second joystick in PBASIC archiver 2001 2 24-06-2002 00:25
How do you make objects shine??? Ydnar 3D Animation and Competition 7 07-01-2002 21:13
