Go to Post Yes, an expanded FIRST will look far different than it does today. - GaryVoshol [more]
Unread 16-01-2005, 20:49
Zalumaskov's Avatar
Zalumaskov Zalumaskov is offline
Premier
Zalumaskov is on a distinguished road
Navigating with only a Cam
I would just like some opinions on how hard it would be to get my camera to stop the robot once it is close to the target.
I know the other solution is to add touch or gyro sensors but it shouldn't be that hard to get the camera to stop the robot once it detects a large area of color right?
Unread 16-01-2005, 21:10
neilsonster's Avatar
neilsonster neilsonster is offline
AKA: Andrew Neilson
FRC #0772 (Sabre Bytes)
neilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to all
Send a message via MSN to neilsonster
Re: Navigating with only a Cam
You could probably use the tilt position of the y-axis servo to determine how close you are. When you start getting closer to the vision tetra or goal or whatever, the camera *might* have to tilt down to target it (it depends on where the camera is on your robot).
pic: (447) Our CMU CAM BOX rufu5 Extra Discussion 2 17-01-2005 19:10
G-Codes vs. CAM / CNC Forums indieFan Technical Discussion 19 16-06-2004 22:51
Helmet Cam?? archiver 2001 5 23-06-2002 22:58
To Team 025, Nu-Trons Wayne Doenges Chit-Chat 6 18-01-2002 18:04
