Go to Post An annoyed inspector is a thorough inspector! - Jon Stratis [more]
Unread 16-01-2005, 17:24
Gabriel Mendez's Avatar
Gabriel Mendez Gabriel Mendez is offline
GaBrIeL MeNdez
FRC #0369
Gabriel Mendez is an unknown quantity at this point
Thumbs up Re: What does your team use to make the clovers for tetras?
We used 1/8 lexan it flexed pretty well, no need for heat gun nor propane torch.
Cyberguy34000's Avatar
Cyberguy34000 Cyberguy34000 is offline
Scout-Master
AKA: Chris
Team Role: Scout
Cyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond repute
Send a message via AIM to Cyberguy34000
We tried making the center Tetra by using only the clover leaves included with the kit. We wanted to see if we could save some time by not machining out the parts in the manual. Wow was that was flimsy . So then we thought that aluminum might be stronger, so we rebuilt everything with the plastic clover leaves doubled up with a aluminum cloverleaf cutout. It helped a bit but not enough, so then we added aluminum braces and the thing was fine .
But anyways... Aluminum is an excellent substitute, just make sure to round off the edges or duct tape them so they aren't too sharp
I love deadlines, I love the wooshing sound they make as they fly by. - Douglas Adams
They who would give up an essential liberty for temporary security, deserve neither liberty or security. - Benjamin Franklin
Unread 16-01-2005, 18:25
DaSpyder's Avatar
DaSpyder DaSpyder is offline
Dat $@#$@#$@#$@# Tall Kid is Back
AKA: Dan
#0999 (C.R.A.S.H. (Cheshire Robotics And Sikorsky Helicopters))
Team Role: Student
DaSpyder is an unknown quantity at this point
Send a message via AIM to DaSpyder Send a message via Yahoo to DaSpyder
we used three button backs and pop riveted them together into a trianglular shape. works pretty good and bends pretty good.
From East Coast to West Coast, F.I.R.S.T. is becoming increasing popular by the minute.....
Unread 16-01-2005, 19:34
Bcahn836's Avatar
Bcahn836 Bcahn836 is offline
Iraq is fun.
AKA: Brad Cahn
no team (Robobees 836)
Bcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond repute
Send a message via AIM to Bcahn836 Send a message via Yahoo to Bcahn836
We also did ours out of vinyl siding but we didn't have enough so we used the linoleum flooring stuff, works very well and is easy to manipulate
Unread 16-01-2005, 21:43
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
1/8 inch clear lexan works for us too!!
Faridodin "Fredi" Lajvardi KD7WKD
Unread 16-01-2005, 21:53
dvd_hawk dvd_hawk is offline
dvd_hawk is an unknown quantity at this point
Originally Posted by Tigerlily-87
I'm just curious...we only got a few of the clover connecters in our kit, so we needed to make some more. We made some temporary ones out of cardboard and duct-tape , but only until we could find something better.
Does anyone have any other ideas for what we can effectively make them out of?
our team has used aluminum an thick lexan
Unread 16-01-2005, 23:24
Damian Manda's Avatar
Damian Manda Damian Manda is offline
The Damian
Damian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud of
Send a message via AIM to Damian Manda
We used LDPE cut with out laser engraver/cutter. This only works marginally though, as the plastic likes to remelt behind the area that had just been cut. It also warped a lot when making a large sheet of them, so we could not do the second pass to make them actually cut out, and then had to break them out like an ice cube tray. Still, we were able to make about 40 of them in about an hour (most of which was taken up by the cutting process). If you dont have a laser cutter, this is irrelevant though.
I want to try lexan, as that cuts much more cleanly, but I think we have enough until some break.
I am interested to know if anyone has cut them with a water jet, as that might work better than the laser.
FRC Volunteer, FLL regional planning committee member for Colorado
Former Programmer, Web Designer, Communications Director of Alpine Robotics Team 159.
Add your team to the FIRST Teams Google Map
Unread 16-01-2005, 23:34
Bharat Nain's Avatar
Double Cardboard.. it worked fine.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 17-01-2005, 00:23
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
Thick rubber. Bends easily, maintains it's shape, and it's durable!
Unread 17-01-2005, 00:36
Collmandoman Collmandoman is offline
Post-A-Holic
Collmandoman has a spectacular aura aboutCollmandoman has a spectacular aura aboutCollmandoman has a spectacular aura about
We used the highway robbery $15 sets from Innovation First. scamed =/
but they are nice
Unread 17-01-2005, 00:57
Tsom467 Tsom467 is offline
FRC #0467 (Shrewsbury Colonials)
Tsom467 will become famous soon enoughTsom467 will become famous soon enough
We used 1/4" Lexan. We had one of our students draw the clover in Autocad, then used our (new) CNC Milling machine to mill out the clovers. The it was lots of blood (literally!) and sweat as we bent them into tetras. Made 1 yesterday, 9 today. My and an engineer/mentor's hands are all cut up! But they're built.
Unread 17-01-2005, 01:27
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
Lexan, yeah you probably get the point by now. But I was thinking, if you happen to have a lot of hot glue sticks standing around, you could probably have your buddies hold the tetra together then you can just stick everything with lots of hot glue -- like use a propane torch and hold the sticks with metal tongs... just a thought
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 17-01-2005, 01:33
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Ive found a pretty easy way to make them cheaply.
While walking through the paint aisle at Home Depot today my eye was caught by a shelf display of bucket lids. These lids are made for buckets from like 5" to over a foot in diameter. The larger ones are 1/4" HDPE and the smaller ones are 1/8" LDPE. The nice thing is i was able to just trace more or less the whole clover on the lid and cut it out with scissors. Since it is a little flimsy i decided to do two clovers per corner. The lids i used were for 8" diameter buckets and were 48 cents each. Hope this helps you out.
-Michael Dessingue
Unread 17-01-2005, 14:17
dhitchco's Avatar
dhitchco dhitchco is offline
Awards/Photo/Video "wizard"
AKA: Doug Hitchcock
FRC #1511 (Rolling Thunder)
dhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant future
Re: use tie-wraps to make the clovers for tetras?
Elsewhere in this forum was a discussion about using plastic tie-wraps as the corner connectors especially for the goals; not the movable tetras.
Just drill holes through the ends of the goal pieces, thread a long nylon tie-wrap strap but leave them loose. Once the entire goal is put together, you can "cinch-up" the nylon tie wraps to make the structure rigid.
That way, you save the cost of the PVC end caps (which seem to be in short supply) plus you have less labor to assemble and a lot less time to dis-assemble when done.
Unread 17-01-2005, 16:48
Whiteviper Whiteviper is offline
Whiteviper is an unknown quantity at this point
lexan works great, but make sure when you buy the caps you get flat ones, we just got some rounded ones they still work but not nearly as nice as flat ones in the kit.
Kettering Kickoff Matt Attallah Off-Season Events 19 27-09-2004 22:40
Renovating a Team av11d Team Organization 2 18-04-2004 20:06
Representing your team? LauraN General Forum 10 18-04-2004 15:59
UTC Scrimmage Info? Andy Grady General Forum 13 21-02-2004 08:30
How do u deal with excess people? archiver 2000 1 23-06-2002 22:55
