Go to Post Yes indeed... ten years ago tomorrow, those famous words "water game" were first mentioned on Chief Delphi! Oh, how things have and have not changed... - bduddy [more]
Unread 16-01-2005, 19:10
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Camera fails to output anything on serial lines
I've wired up the camera - I'm using the 2002 mini RC for power, and I then hooked up the camera and serial lines. Upon powering up, all three status LEDs turn on and the servo twitches. Very quickly, the green status LED (the one to the left) turns off, leaving the green power LED and the red status LED on. Nothing appears on my terminal. I tried typing 'gv' as was suggested by the directions to no avail. The GUI fails on any command, often crashing in the process. I'm providing about 7V of power, more than the minimum 6. I have no clue where to go from here - how else can I go about debugging the camera? Thanks,
Steven
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 16-01-2005, 19:13
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Camera fails to output anything on serial lines
Lots of people (myself included) have had trouble running the GUI on slower computers, as has been noted in other threads. I tried a number of the school's computers (1.0GHz Celeron, I think) with no success. I brought in my own 1.8GHz computer for our programming team, and it worked fine. Make sure that your serial port is configured properly first. If it is, try setting the camera up on a faster computer, and see if it works there.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 16-01-2005, 21:15
I saw those, and figured that it's not the problem because nothing at all appears on the serial port - the documentation says that the firmware should spit out a version string (and I'm fairly positive I have the settings right, although minicom isn't my favorite interface) and nothing appears (and even if it was the wrong speed or something, at least some sort of garbage would appear)
Unread 16-01-2005, 22:15
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
On the school computers I was using, I couldn't even get the version string out of the camera. Try it on a faster computer; then you can see if that's the problem, or if your hardware is malfunctioning.
_
Unread 17-01-2005, 01:19
That's very strange - why would a 366MHz computer be unable to read ten bytes off of a serial port? They existed long before such fast computers did...
I don't think I have a faster computer readily available. I'll check out the clockspeed tomorrow and look around, however...
Unread 17-01-2005, 01:44
I haven't changed the jumpers from the default settings (all open). Should any be closed for normal operation?
Unread 17-01-2005, 01:50
Omni L Omni L is offline
AKA: Eric M.
FRC #0698 (Hamilton/Microchip Microbots)
Omni L is an unknown quantity at this point
Send a message via ICQ to Omni L Send a message via MSN to Omni L Send a message via Yahoo to Omni L
Honestly, I don't remember at the moment, I'll try and remember to check. (I think I closed the one that ships open, and opened the one that ships closed.. but I don't rememeber)
"its like bling bling for the brain" -Dr. Woodie Flowers
"Imagination is more important than knowledge" -Albert Einstein
"The secret to creativity is knowing how to hide your sources"
Unread 17-01-2005, 02:35
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
Honestly, I have no idea. I don't know why the 1.0GHz computers at my school couldn't even do it. However, between you, me, and some of the other threads around here, it appears to be a fairly consistent problem. Peculiar indeed.
_
Unread 17-01-2005, 20:41
AKA: Eric M.
oh joy.. I can see it now, another drill motor repeat...
If anyone has gotten these cameras to work, please post computer specs and settings, along with any modification done to the camera.
Unread 17-01-2005, 21:19
Electrical Engineer
Rookie Year: 1995
PIII, 1.0 GHz, Bafo BF-810 USB-Serial adapter, comm settings as per documentation in "start here".
Mike Betts
As easy as 355/113...
Unread 18-01-2005, 16:12
I just got it to work - apparently 1.6GHz is not enough but 1.8 is. This is very strange, and somewhat disappointing - I can see no reason why the system requirements would be that high and there is no way we'll be able to bring such a fast computer to our competitions, seriously affecting how well we'll be able to debug problems...
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Kevin Watson's Kick-off Demo Code! Mr. Lim Programming 27 22-01-2005 03:38
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
New Serial Port Driver Kevin Watson Programming 16 09-01-2005 01:56
