Go to Post You mean nobody else has picked up on the hint about next year's game being called "Whack the Billfred"? - EricH [more]
Unread 17-01-2005, 11:23
Eko's Avatar
Eko Eko is offline
Eko is an unknown quantity at this point
Re: Programming Problem: Extremely Frustrating
Originally Posted by Tom Bottiglieri
Unplug all radios and tether.
Download the latest firmware.
Download the default code.
Plug in the OI via Tether.
Reset
Try downloading your code.
You have to have the OI and the RC connected to download the master code.
Unread 18-01-2005, 11:27
chantilly_team chantilly_team is offline
chantilly_team is an unknown quantity at this point
The problem is not going away. I tried installing new compiler and master code. But still it does not respond to any other downloaded program except "FRC_default.hex"
Its very frustrating...
chantilly team member.
Unread 12-02-2005, 18:54
HPA_Robotics_13 HPA_Robotics_13 is offline
#833 Team Captain
AKA: Ben Honey
#0833 (HPA Robotics)
HPA_Robotics_13 will become famous soon enoughHPA_Robotics_13 will become famous soon enough
Send a message via AIM to HPA_Robotics_13 Send a message via MSN to HPA_Robotics_13
For what it is worth, we have had a very similar problem. Compiling the code out of the box doesn't work. We spent a long time verifying all the hardware (FRC, serial ports, camera) was ok (it was).
We were able to get stripped down versions of the code to work, then slowly added back the missing pieces. Eventually it failed when we included enough code - even though that code was not being invoked. We verified that we are nowhere near the memory limit when this happened - we are using around 30% of available memory. We've checked all the settings in MPLAB - right processor, compiler and linker options, starting address to download and linker file. We've scoured the map file, to no avail.
Now we'll try the unistall/reinstall route - we've pretty much run out of other options.
Hilton
Unread 12-02-2005, 22:07
psquared psquared is offline
psquared is an unknown quantity at this point
Chantilly Team Here, it turned out we had done everything right, except for one problem, our computer was too old. It wasn't even a P1, so I guess it couldn't handle this years code with the camera in it. After struggling to get a new computer, the school finally gave us a windows xp laptop, P4 i think, and everything is working fine. Im not sure how old your computer is, but if it is somewhat old, or not the best computer, try reinstalling everything on a newer computer and working from there. Hope this helps.
Unread 12-02-2005, 23:00
#833 Team Captain
AKA: Ben Honey
Nothing like coming to the end of your rope to find the solution. We reinstalled MPLAB, the compiler and the loader, and everything works fine. Too bad we lost 10 days of programming time. On the other hand, we really understand a lot about the tools now!
Hilton
Programming - Getting Started Mark McLeod Programming 80 16-04-2008 23:37
Banner Sensor Programming Problem 2Crisis Programming 4 24-02-2004 13:40
C programming problem... wasabi824 Programming 5 08-02-2004 01:04
multi-bank programming problem GregC Programming 3 14-02-2003 16:13
programming problem gthakore Programming 16 20-04-2002 12:21
