Go to Post More teams will want to join, peers who are not on the team will understand the program better, television will become interested in FIRST again, sponsors will be easier to get, cancer will be cured, the Israelis and Palestineians will live in harmony, and we will have world peace. - Andy Baker [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 17-01-2005, 11:54
robot180's Avatar
robot180 robot180 is offline
Webmaster, spamrobotics.com
AKA: Jon
FRC #0180 (S.P.A.M.)
robot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to all
Send a message via AIM to robot180
return line commands in PHP
I could use some help. I am using the mail() function to send an email in a "helpdesk" like program. I have the person's name and email address attach to the message, however I want to put a few blank lines in between. I used the \n, \r, and \t commands in between them, but they don't do anything.
Another thing I need help with is that the mail function allows you to put other headers in. Do I need to enter anything in those?
-Jon
Computer Science Major
Georgia Tech
Former Team Leader
FRC Team 180
Unread 17-01-2005, 12:26
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: return line commands in PHP
If it was an HTML e-mail you could just toss in a couple <br>'s...
Unread 17-01-2005, 19:05
evulish's Avatar
evulish evulish is offline
1010100
AKA: Grant Harding
#0084 (WATTNESS (bot: Chuck))
evulish is just really niceevulish is just really niceevulish is just really niceevulish is just really nice
Send a message via AIM to evulish
No, it's not necessary to add any other headers to mail(). There are some you may want, such as the From, Reply-To, Content-Type, MIME-Version, To, CC, BCC. It should work just fine with none, though. Using \n in the body should also work unless you've specified a different Content-Type (like HTML, which doesn't care about new-lines). If you're checking it on a Windows client, you may need to use \r\n, but I'm not positive.
I'm a professional web developer. I'm good with PHP, Perl, Java/JSP, some RoR, XML, Javascript (AJAX as well), (x)HTML, CSS, etc.. Validated code is good; fully cross-browser code is better (you comply to your users and the software they use, not the other way around. Sorry!)
Unread 17-01-2005, 19:37
Jack's Avatar
Jack Jack is offline
FIRST Scouting Network
AKA: Andrew Schenk
FRC #0201 (The FEDS)
Jack is a jewel in the roughJack is a jewel in the roughJack is a jewel in the rough
Send a message via AIM to Jack
99% sure on this.. if you use single quotes 'text\ntest'.. the new line doesn't happen. you need to use double quotes "text\ntest" instead.
jack
Team 201 - 2003 Great Lakes Semifinalists & 2003 Archimedes Division Finalists :|: Webmaster of www.feds201.com -> FBI Scouting
Winner of The 2003 ChiefDelphi Web Award for: User That Started The Most Non Chit Chat Threads
Winner of: 2003 FIRST Ventures with 5451.68 End Points
All about me: http://knehcsa.vze.com
**Check out the New FIRST Scouting Network**
Unread 18-01-2005, 21:31
AIBob's Avatar
AIBob AIBob is offline
AI Programmer
AKA: Bob Frank DOT org
FRC #0358 (Hauppauge Robotic Eagles)
AIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to behold
Send a message via ICQ to AIBob Send a message via AIM to AIBob Send a message via MSN to AIBob Send a message via Yahoo to AIBob
You do not need to put any other headers in it for many webhosts... It really depends on what the webhost has it set as..
Usually webhosts require you to put the From: header.... but that is not always the case.
- from B B frank
Unread 19-01-2005, 00:47
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
I believe the standard requires \r\n between header lines. At least that's what I use for my PHP mails and it works great...
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 19-01-2005, 02:22
HFWang's Avatar
HFWang HFWang is offline
AKA: DarkWulf
#0115
Team Role: Webmaster
HFWang will become famous soon enough
Send a message via ICQ to HFWang Send a message via AIM to HFWang
I could use some help...
We've all guessed... but did it work?
I feel like I'm reading a mystery novel but can't find the last chapter.
rawr
Unread 19-01-2005, 10:26
http://cr.yp.to/docs/smtplf.html
Unread 20-01-2005, 14:59
robot180's Avatar
AKA: Jon
jack
I put it in single quotes. Sorry it took so long to answer. I always use single quotes unless I use nested quotes. Thanks.
-Jon
Georgia Tech
Former Team Leader
FRC Team 180
openFIRST PHP 5 Compatibility Timothy D. Ginn FIRST-related Organizations 0 30-07-2004 13:45
Sprockets and Roller Chain Models Madison Inventor 3 04-02-2003 11:51
iParts on firstcadlibrary.com Ed Sparks Inventor 3 08-01-2003 23:30
emulationFIRST v0.04 Matt Leese Programming 7 09-07-2002 08:54
What's better, PERL/cgi or PHP/my_sql? mikefrei Programming 10 27-05-2002 22:50
