Go to Post Real coaches dont use "strategy assistants" during matches. - Rick [more]
Unread 16-01-2005, 22:20
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
need Computer power supply trick
I am in need of 12v and i have an atx computer power supply lieing on my floor. ive been looking at this diagram
and making sparks for a while and i havent gotten it to power up yet does anyone know the trick?
Unread 16-01-2005, 22:28
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: need Computer power supply trick
Actually, connect the green one to any black with a paper clip (or something similar), then power it up.
Yes, I've tried this; it works.
Unread 16-01-2005, 22:34
Halon Halon is offline
#0662 (Rocky Mountain Robotics)
Team Role: Driver
Halon is an unknown quantity at this point
Send a message via AIM to Halon
Yep. Put a paper clip between the green and any black. I have a PSU that's shorted this way to power my battery charger.
---Tyler Nicely---
Team 662
2004 Colorado Regional Winners
2003 Sacramento Regional Winners
2003 Sacramento Entrepreneurship Award Winners
Unread 17-01-2005, 01:18
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Just a quick word of warning - from what I've seen few power supplies designed for computers have internal breakers. So, whenever hooking stuff up to it (even if it's like this) I try to add fuses/breakers in - the last time I didn't I ended up melting a few wires... it wasn't pleasant.
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 17-01-2005, 08:15
Tytus,
Several websites suggest the connections outlined above. Please be careful, the five volt supply is a high current device. Short the wrong wire to ground and the jumper may get very hot. These power supplies have internal fuses but generally only on the mains input. Also, without a load on the five volt power supply, the 12 volt power may not regulate very well. It depends on the supply design. Don't open the supply if you are not familiar with switching power supply design. A large portion of the power supply and circuit board is at line potential, 120 VAC.
Unread 17-01-2005, 13:12
Don Reid Don Reid is offline
Don Reid will become famous soon enough
You should also be aware that many PC power supplies require some minimum load to turn on and to maintain regulation.
Don Reid
Unread 17-01-2005, 15:53
CJO's Avatar
CJO CJO is offline
Emeritus Pain in the $@#$@#$@#
AKA: Christopher J. O'Connell
None #1097 (Site 3 Engineering)
CJO will become famous soon enoughCJO will become famous soon enough
I have a similar problem, except, I have a board with only six pins in the molex connector, they are labeled +12v, -12v, gnd, gnd, +5v, +5v (yes, two +5v). I have tried an ATX and an AT power supply to no avail, bench supplies will get a warning beep (wrong power), I think that the bench supplies are to low an amperage. Any thoughts?
Team 1097 -- Site 3 Engineering
2003 Sacramento Rookie All Star
2003 Silicon Valley Rookie All Star
2004 Sacramento Engineering Inspiration Award
2004 Sacramento Visualization Award
2004 Outstanding Volunteer Award (G. Glasser)
2004 Silicon Valley Sportsmanship Award
2004 National Visualization Runner Up
2004 Cal Games Finalist
2005 Sacramento Sportsmanship Award
2005 Sacramento #1 seed
2005 Sacramento Finalist
2005 Silicon Valley Sportsmanship Award
2005 Silicon Valley #1 Seed
2005 Silicon Valley Finalist
Unread 20-01-2005, 11:25
team1307 team1307 is offline
team1307 is an unknown quantity at this point
Send a message via AIM to team1307
this doesnt work on power supplies that come with computers like dells, HPs, Compaqs, ETC.. This will work if you use a power supply that you can pick up at a local store.
12V Power Supply Feeds My Robot MikeDubreuil Electrical 17 31-03-2004 12:06
operator interface power supply hi_im_sean General Forum 1 05-02-2003 14:50
Full list of teams & competitions archiver 2001 14 24-06-2002 00:52
power supply of control system archiver 2000 5 24-06-2002 00:14
Max mechanical power of motors, how is it useful? Ken Leung Motors 1 09-11-2001 14:15
