Go to Post If we can figure out how to make a robot in six weeks, a little thing like personality conflict should be easy to overcome. - Al Skierkiewicz [more]
Unread 17-01-2005, 13:44
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
Winch
Is there anyway to make a simple winch this year
using any motor besides van dor and cim
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Unread 17-01-2005, 13:50
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
Re: Winch
Yes there are motors that you can use for the winch in the kit of parts, you can use the globe motor or window motor or even fisher price motor with the gearbox. It really depends on how much weight are you pulling up with the winch. good luck...
-Arefin.
Unread 17-01-2005, 13:57
AKA: Jon
Re: Winch
any details would be appreciated
Unread 17-01-2005, 14:03
Billfred's Avatar
Billfred Billfred is offline
Re: Winch
I'll give an example, although I don't have pics (well, there may be some in the galleries on www.d5robotics.com if you're lucky).
Last year, 1293 built this winch of an arm to handle the 2X ball. Overall, the design was...lacking. But the method seemed sound--we used a van door motor with a drum attached to it to winch this cable with green plastic coating on it (someone who knows, feel free to add the details) that went over a pulley and moved our arm up and down.
The van door motor still would do the job today...if we had the arm attached, that is.
Unread 17-01-2005, 14:14
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: Winch
They don't seem to be in the kit this year, but last year, we used the Fisher Price gearbox couplers directly as a winch. (http://www.magnetrobotics.com/module...e w_photo.php) Just make sure your rope is well guided and free from potential jams.
Team 1257
Unread 17-01-2005, 14:42
AKA: Jon
Re: Winch
i thought that in the past they gave a components to make one out of FP motors however, does anyone know where to get the components this year
Unread 17-01-2005, 14:52
Stephen P's Avatar
Stephen P Stephen P is offline
Stephen P has a spectacular aura aboutStephen P has a spectacular aura about
Re: Winch
Last year my team fasioned a winch out of 2 window motors attached together. We put those little black plastic fittings on the motor shafts and used a 4 in. section of aluminum pipe fitted over them to attach the two motor shafts together. It was basically a simple spool, but capable of lifting our robot easily. I'm guessing your making a telescoping arm?
You know you are an electrical engineer when you can determine voltage relative to pain with a 5% error.
Unread 17-01-2005, 14:56
Cyberguy34000's Avatar
Cyberguy34000 Cyberguy34000 is offline
Scout-Master
AKA: Chris
Team Role: Scout
Cyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond repute
Send a message via AIM to Cyberguy34000
Re: Winch
Check out the winch arm we had on 662's robot last year! The entire arm was powered by the winch, and once the hook as on, we just winched ourselves up off the ground, match, after match, after match... We got those hang points almost every single match.
http://www.rockymountainrobotics.com/index.php?module=photoshare&func=showimages&fid=8& viewkey=&template=slideshow&iid=125
Just click on the forward arrow at the top to see the next frame.
I love deadlines, I love the wooshing sound they make as they fly by. - Douglas Adams
They who would give up an essential liberty for temporary security, deserve neither liberty or security. - Benjamin Franklin
Unread 03-02-2005, 22:10
ClicheCow ClicheCow is offline
AKA: Jordan Bentley
ClicheCow is an unknown quantity at this point
Send a message via AIM to ClicheCow
Re: Winch
i'd use two window motors. take the plastic fittings for them and mill off the part that connects to the shaft. then, just bolt the big plastic flanges to your winch and it should work pretty well, without even needing a shaft.
Unread 03-02-2005, 23:25
MasonMM's Avatar
MasonMM MasonMM is offline
AKA: Mason Markee
FRC #0118 (Robonauts)
MasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond repute
Re: Winch
last year and this year we are using 2 FP motors coupled together for our winch. It made for a pretty long winch off the groud last year, but this year we increased our spool size and it works nice and quick for what we use it for.
We put a keyed shaft right through the 2 motors, which were positioned opposite of each other, and then put a spool in the middle. A key point was to put some hose clamps over the end hexagonal shapes of the gear box, becuase that plastic has a tendency not to hold up.
Unread 04-02-2005, 00:42
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
Re: Winch
Somehow, this looks veery familliar... (Pic 5/20)
http://www.rockymountainrobotics.com...deshow&iid=125
Anyway, I had a few ideas last year (after competition ) and they all involved 2 motors. I think that's one thing you want to highly consider in your design.
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Globe motor backdrive!! Srkasner Motors 19 08-03-2004 00:10
pic: Fixing the Winch on the field CD47-Bot Extra Discussion 9 07-03-2004 21:04
pic: team 60 winch CD47-Bot Robot Showcase 3 01-03-2004 10:36
Variable Speed Transmission Knowledge (Search Tried!) Jeff D. Technical Discussion 4 14-01-2004 22:00
Work Safe, Play Safe, Pick Safe archiver 2000 8 23-06-2002 22:37
