#23
Re: use tie-wraps to make the clovers for tetras?
Elsewhere in this forum was a discussion about using plastic tie-wraps as the corner connectors especially for the goals; not the movable tetras.
Just drill holes through the ends of the goal pieces, thread a long nylon tie-wrap strap but leave them loose. Once the entire goal is put together, you can "cinch-up" the nylon tie wraps to make the structure rigid. That way, you save the cost of the PVC end caps (which seem to be in short supply) plus you have less labor to assemble and a lot less time to dis-assemble when done. |
| Kettering Kickoff | Matt Attallah | Off-Season Events | 19 | 27-09-2004 22:40 |
| Renovating a Team | av11d | Team Organization | 2 | 18-04-2004 20:06 |
| Representing your team? | LauraN | General Forum | 10 | 18-04-2004 15:59 |
| UTC Scrimmage Info? | Andy Grady | General Forum | 13 | 21-02-2004 08:30 |
| How do u deal with excess people? | archiver | 2000 | 1 | 23-06-2002 22:55 |
