Go to Post ..the way we see it FIRST isn't about winning a robot contest, its about trying your best to complete a really really hard task in a really really short amount of time. - Stuart [more]
Unread 17-01-2005, 14:32
RbtGal1351's Avatar
RbtGal1351 RbtGal1351 is offline
~La Reina de los Robots~
AKA: Stephanie
FRC #1351 (TKO)
RbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to behold
Send a message via AIM to RbtGal1351 Send a message via MSN to RbtGal1351
Angry Error in header file p18f8520.h !!!
Ok i know that this is a strange build error... but when i compiled/ built the default code (not the camera version) i got this error:
Clean: Deleting intermediary and output files.
Clean: Done.
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 "main.c" -fo="main.o" /i"C:\mcc18\Compiler Stuff\h" -D_FRC_BOARD -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 "user_SerialDrv.c" -fo="user_SerialDrv.o" /i"C:\mcc18\Compiler Stuff\h" -D_FRC_BOARD -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
c:\mcc18\h\p18f8520.h:169:Error [1109] type mismatch in redeclaration of 'PORTBbits'
c:\mcc18\h\p18f8520.h:201:Error [1109] type mismatch in redeclaration of 'PORTCbits'
Halting build on first failure as requested.
BUILD FAILED: Mon Jan 17 11:25:20 2005
does any body please know how to fix this???
THANK YOU IN ADVANCE!!
~Stephanie
Team 1351
2004 Founding member and Arm leader, 2005 Lead programmer, 2006 Controls leader, 2007 Project Manager/President
Thanks for making FIRST such a great experience for me. I'm no longer on 1351, and I'm not currently planning to mentor team 97, but FIRST has meant so much in getting me to where I am now, in life and at MIT, class of 2011.
I met Billfred! He recognized me!
SVR 04: 11th seed - Highest Rookie Seed - Semifinalists w/ 1120 and 568 - GM Industrial Design Award
SVR 05: Semifinalists w/ 8 and 766
SVR 06: 6th seed - Quarterfinalists w/ 368 and 1072
Davis 06: 1st seed - Quarterfinalists w/ 649 and 100 - KPCB Entrepreneurship Award
SVR 07: 36th seed
David 07: 4th seed - Semifinalists w/ 1280 and 692 - Johnson and Johnson Sportsmanship Award
Unread 17-01-2005, 15:00
Electrical Engineer
Rookie Year: 1995
Re: Error in header file p18f8520.h !!!
Stephanie,
When I compile the default code dated 1-7-2005, this is what I get:
Clean: Deleted file "C:\C_RC_Bot\FRC_DEFAULT_1_7_2005\main.o".
Clean: Deleted file "C:\C_RC_Bot\FRC_DEFAULT_1_7_2005\user_SerialDrv.o".
Clean: Deleted file "C:\C_RC_Bot\FRC_DEFAULT_1_7_2005\user_routines.o".
Clean: Deleted file "C:\C_RC_Bot\FRC_DEFAULT_1_7_2005\user_routines_fast.o".
Clean: Deleted file "C:\C_RC_Bot\FRC_DEFAULT_1_7_2005\printf_lib.o".
Clean: Deleted file "C:\C_RC_Bot\FRC_DEFAULT_1_7_2005\ifi_utilities.o".
Clean: Deleted file "C:\C_RC_Bot\FRC_DEFAULT_1_7_2005\ifi_startup.o".
Clean: Deleted file "FrcCode.cof".
Clean: Deleted file "FrcCode.cod".
Clean: Deleted file "FrcCode.hex".
Clean: Deleted file "FrcCode.lst".
Clean: Deleted file "C:\C_RC_Bot\FRC_DEFAULT_1_7_2005\FrcCode.mcs".
Clean: Done.
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 "main.c" -fo="main.o" -D_FRC_BOARD -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 "user_SerialDrv.c" -fo="user_SerialDrv.o" -D_FRC_BOARD -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 "user_routines.c" -fo="user_routines.o" -D_FRC_BOARD -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 "user_routines_fast.c" -fo="user_routines_fast.o" -D_FRC_BOARD -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 "printf_lib.c" -fo="printf_lib.o" -D_FRC_BOARD -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 "ifi_utilities.c" -fo="ifi_utilities.o" -D_FRC_BOARD -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 "ifi_startup.c" -fo="ifi_startup.o" -D_FRC_BOARD -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mplink.exe" /l"C:\mcc18\lib" "18f8520user.lkr" "C:\C_RC_Bot\FRC_DEFAULT_1_7_2005\main.o" "C:\C_RC_Bot\FRC_DEFAULT_1_7_2005\user_SerialDrv.o" "C:\C_RC_Bot\FRC_DEFAULT_1_7_2005\user_routines.o" "C:\C_RC_Bot\FRC_DEFAULT_1_7_2005\user_routines_fast.o" "C:\C_RC_Bot\FRC_DEFAULT_1_7_2005\printf_lib.o" "C:\C_RC_Bot\FRC_DEFAULT_1_7_2005\ifi_utilities.o" "C:\C_RC_Bot\FRC_DEFAULT_1_7_2005\ifi_startup.o" "C:\C_RC_Bot\FRC_DEFAULT_1_7_2005\FRC_library.lib" /o"FrcCode.cof"
MPLINK 3.90, Linker
Copyright (c) 2004 Microchip Technology Inc.
Errors	: 0
MP2COD 3.90, COFF to COD File Converter
Errors	: 0
You have a strange include path (not the default).
Mike Betts
As easy as 355/113...
Unread 17-01-2005, 15:27
CJO's Avatar
CJO CJO is offline
Emeritus Pain in the $@#$@#$@#
AKA: Christopher J. O'Connell
None #1097 (Site 3 Engineering)
CJO will become famous soon enoughCJO will become famous soon enough
To further Mr. Betts comment, installing C18 in the default directory "C:\mcc18" seems to solve about 95% of compile errors.
Team 1097 -- Site 3 Engineering
2003 Sacramento Rookie All Star
2003 Silicon Valley Rookie All Star
2004 Sacramento Engineering Inspiration Award
2004 Sacramento Visualization Award
2004 Outstanding Volunteer Award (G. Glasser)
2004 Silicon Valley Sportsmanship Award
2004 National Visualization Runner Up
2004 Cal Games Finalist
2005 Sacramento Sportsmanship Award
2005 Sacramento #1 seed
2005 Sacramento Finalist
2005 Silicon Valley Sportsmanship Award
2005 Silicon Valley #1 Seed
2005 Silicon Valley Finalist
Unread 17-01-2005, 16:03
RbtGal1351's Avatar
AKA: Stephanie
FRC #1351 (TKO)
thanks guys
i got it working... i had previously reorganized the mcc18 folder, and it didnt like it...
thanks again and happy programming
~Stephanie
Team 1351
SVR 07: 36th seed
error - Invalid 18f8520 header file! vtrehan Programming 2 16-11-2004 08:31
Header File error message Mike Yan Programming 2 09-02-2004 11:31
Needing A header file jweric Programming 19 23-01-2004 10:25
File Sharing and Revision Tracking Madison FIRST-related Organizations 14 04-06-2003 18:01
