Go to Post When we got it tuned to the point where we were (reasonably) confident it wouldn't slam into Dave's ankle, we quit for the evening. - Kevin Watson [more]
Unread 15-01-2005, 22:33
Ryan Collings Ryan Collings is offline
None #0313 (Bionic Zebras)
Ryan Collings is an unknown quantity at this point
CMUcam setup
I can not get the CMUcam to do what the instructions say it can.
I got my CMUcam hooked to an AT powersupply for a steady supply of power. it turns on and when I use Hyperterminal I get the string from the camera that says "CMUcam2 v1.01 c7". my port settings are
Port: COM2
Bits per second: 115200
Data bits: 8
Parity: none
Stop bits: 1
Flow control: None
I do not know how to send the "gv" to the CMUcam. but I assume it works and I start the CMUcam2 program and it just says "Looking for Camera...". If I press any buttons on the GUI it freezes up. I appreciate any help anyone can give me. and I encourage other who have the same problem or something similar to post here with me, or if there is already a post on this, let me know, I did not find one in the search though.
Unread 16-01-2005, 01:01
emusteve's Avatar
emusteve emusteve is offline
AKA: Steve Martin
#0470 (Alpha Omega)
emusteve is just really niceemusteve is just really niceemusteve is just really niceemusteve is just really nice
Smile Re: CMUcam setup
Port: COM2
Data bits: 8
Parity: none
Stop bits: 1
Flow control: None
What leg of the AT power supply are you using? If it's the +5 leg, then you don't have enough voltage to overcome the drop in the internal regulator. The specs say it wants at least 6V, but I've fond that to be marginal as well. It does work, however, when powered directly from one of the 7.2V backup batteries. Also, remember that most switchers like the AT supplies require a minimum load to work properly, so this could be tripping you up as well.
Now if I could get the GUI to run properly, we might be able to make a go of it. If you want to get together on this, I'm down the street at EMU. Give me a shout at smartin@emich.edu. Two heads are better than one, and we'll all benefit if we can make it work.
Steve
Unread 16-01-2005, 02:20
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: CMUcam setup
Lots of people (myself included) have had trouble running the GUI on slower computers, as has been noted in other threads. I tried a number of the school's computers (1.0GHz Celeron, I think) with no success. I brought in my own 1.8GHz computer for our programming team, and it worked fine. Since you are getting feedback in Hyperterminal, but not in the GUI, it's safe to assume that your camera hardware is okay, and that the serial port is correctly configured. I don't know the specs of the computer you're working on, but try setting it up on a faster computer, and see if it works there.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 16-01-2005, 04:02
SpaceOsc's Avatar
SpaceOsc SpaceOsc is offline
16 Years of FIRST!
AKA: Oscar Vasquez
FRC #4501 (Humans)
SpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant future
Send a message via AIM to SpaceOsc Send a message via Yahoo to SpaceOsc
Re: CMUcam setup
remeber that the ttl cable should not be conneced at the same time as the serial cable to the pc,we had that problem for viewng the cam
it still should get power from the pwm port tho.
i could be wrong about which cables goes out, i didnt do it but i did watch
2014-2017: Team 4501 Coach/Lead Mentor
2002-2011: Team 702, Mentor
2001-2002: Team 702 Captain
Unread 16-01-2005, 10:06
Re: CMUcam setup
All symptoms of an incorrect Serial Port setup or you have the two serial lines hooked up at once. You can only have either the serial line to your PC or the TTL port on the RC hooked up, not both at the same time.
We had trouble using HyperTerminal to set the serial port and making it stick, so we did it using the Device Manager.
Check the serial port settings from the Device Manager.
I get there under W2K by
right clicking Properties for My Computer or under Control Panels click System,
then Hardware tab,
then Device Manager
select Ports (COM ...
double-click Communications Port
then Port Settings
and you know the rest.
Unread 16-01-2005, 11:51
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Re: CMUcam setup
Hi all,
Sorry if this is a stupid question, but what is HyperTerminal, and what are its uses?
Sorry to bother you,
Dan
Unread 16-01-2005, 12:30
Re: CMUcam setup
Originally Posted by dhoizner
Hi all,
Dan
Hyperterminal comes standard with Windows and can be found at:
Start -> Programs -> Accessories -> Communications
It can use the serial port on your PC and change the port settings. Typically, Hyperterminal is used as a substitute for the IFI_Loader terminal window for displaying debug output from the RC. It has several advantages, not the least of which is the capability to save debug output. There are some more notes here:
http://www.chiefdelphi.com/forums/sh...032#post279032
You can't usually have more than one program running that uses the same serial port, so you can't run the IFI_Loader terminal window while either the Hyperterminal or the CMU programs are running.
Unread 16-01-2005, 20:59
DanDon's Avatar
ohhh MY god
AKA: Dan Hoizner
Re: CMUcam setup
Thanks for the help Mark, I will have to experiment. Something to do tomorrow. Yay!
Thanks again,
Dan
Unread 17-01-2005, 16:17
tckma's Avatar
tckma tckma is offline
AKA: Tom C.
FRC #2199 (Robo-Lions)
tckma has a spectacular aura abouttckma has a spectacular aura abouttckma has a spectacular aura about
Send a message via ICQ to tckma Send a message via AIM to tckma Send a message via Yahoo to tckma
Re: CMUcam setup
Steve
What problems are you having with the GUI? I've seen it work with the latest version of the JRE installed. It seems to be very picky about lighting conditions for calibration, though.
Tom C.
Software and Controls Mentor
Team 2849
Prior team associations: 1418 ('08-'09), 1100 ('05-'08), 811 ('02, '04-'05), 246 ('03)
Unread 17-01-2005, 17:20
CJO's Avatar
CJO CJO is offline
Emeritus Pain in the $@#$@#$@#
AKA: Christopher J. O'Connell
None #1097 (Site 3 Engineering)
CJO will become famous soon enoughCJO will become famous soon enough
Re: CMUcam setup
I am not a big fan of hyperterminal. I once turned an iPaq into an unbootable brick while installing linux due to a hyperterminal crash. I reccomend something else. I personally use linux, but for windows, there is a program "puTTY?" which is reputed to be better than hyperterminal.
Team 1097 -- Site 3 Engineering
2003 Sacramento Rookie All Star
2003 Silicon Valley Rookie All Star
2004 Sacramento Engineering Inspiration Award
2004 Sacramento Visualization Award
2004 Outstanding Volunteer Award (G. Glasser)
2004 Silicon Valley Sportsmanship Award
2004 National Visualization Runner Up
2004 Cal Games Finalist
2005 Sacramento Sportsmanship Award
2005 Sacramento #1 seed
2005 Sacramento Finalist
2005 Silicon Valley Sportsmanship Award
2005 Silicon Valley #1 Seed
2005 Silicon Valley Finalist
Unread 17-01-2005, 19:38
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: CMUcam setup
PuTTY is generally used for SSH, SSL, RSH, and other remoting stuff. It can't be used on a serial port (to my knowledge).
Unread 17-01-2005, 22:33
sudeepr71 sudeepr71 is offline
FRC #0503 (Frog Force)
sudeepr71 is an unknown quantity at this point
Send a message via AIM to sudeepr71
Re: CMUcam setup
Hi
I am also having trouble with the camera. I have the camera connected to the TTL-232 adapter, and it pulged into a pwm01. Next we opened the GUI with our hopes high and waited awhile. All that happened was that the camera lights blinked. On the gui it said looking for camera...We have the back-up battery pluged in.
Sudeep
Unread 17-01-2005, 22:57
Damian Manda's Avatar
Damian Manda Damian Manda is offline
The Damian
Damian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud of
Send a message via AIM to Damian Manda
Re: CMUcam setup
You cannot have the camera plugged into the robot controller via the TTL port at the same time as it is hooked to the computer via the RS-232 DB9 port. Unhook the robot controller connection and hook it up directly to the computer and see if this solves the problem.
If the GUI can still not access the camera connect to it with the listed settings in the manual:
• 115,200 Baud
• 8 Data bits
• 1 Stop bit
• No Parity
• No Flow Control (Not Xon/Xoff or Hardware)
through hyperterminal and type GV followed by enter. This should return a CMUcam2 version string. If this happens, you are connected and the GUI is the problem.
FRC Volunteer, FLL regional planning committee member for Colorado
Former Programmer, Web Designer, Communications Director of Alpine Robotics Team 159.
Add your team to the FIRST Teams Google Map
Unread 18-01-2005, 16:17
Re: CMUcam setup
One more thing, rumor has it that First removed the camera code becuase it wasn't working correctly. Have they put it back up and where can I get it from?
Unread 18-01-2005, 19:54
scifi3018 scifi3018 is offline
scifi3018 is an unknown quantity at this point
Re: CMUcam setup
Tonight we experimented with the cmu camers, and suprisinlgy got it wokring. we started with the robot, and hooked everything up par to the instructions. no luck. then i realized one of the foolish chassis people decided to unplug the backup battery instead of pressing the reset button
so battery hooked up, check. it worked, we had to change the port settings, but it didnt seem to make a difference. we were able to grab frames, but the servo control is still puzzling. once we get the project enclosure, and assemble it, we will try to calibrate it, then who knows what the result will be.
More later when we can get it fixed, and its time to wrap up for tonight
CMUCam for drivers patTeam241 Technical Discussion 22 16-01-2005 01:21
Dual monitor Display setup.... BrianJennings Inventor 6 12-01-2005 20:35
Problems with Autonomous due to motor setup xxlshortys Programming 10 16-03-2004 14:38
Competition IR Beacon - how does its physical setup compare to our beacons? DanL Electrical 2 25-01-2004 18:05
Official California Robot Games announcement! Ken Leung Off-Season Events 9 01-10-2003 03:37
