Go to Post Blowing out the transmission on your mini-van while hauling a trailer 700 miles from home is not fun. Trust me on this. - dlavery [more]
Unread 17-01-2005, 16:12
magical hands magical hands is offline
Jigar Patel
AKA: Jigar Patel
FRC #2185 (Etobicoke CI)
magical hands is on a distinguished road
Exclamation Hallow-Shaft encoders
Hi Guys! I found this website that has Hallow-shaft Optical Encoders with quadrature output. Do you guys think its appropriate to use this sensor with our 2005 navigation FRC code. The code that Kevin provided. The link to the encoder site is http://www.quantumdev.com/products/o...87_hollow.html
Please Reply. Thanks for your time
-:::-::-Jigar Patel-::-:::-
Unread 17-01-2005, 18:23
Electrical Engineer
Rookie Year: 1995
Re: Hallow-Shaft encoders
Originally Posted by magical hands
Do you guys think its appropriate to use this sensor with our 2005 navigation FRC code. The code that Kevin provided...
If it passes the FIRST flowchart, you can use it.
Honestly? Yes, you could use it. But I'd have to ask why... It has an incredible resolution which (if the processor can keep up at all) would seem way too high for any application I can think of for a FIRST robot. It also looks expensive.
Last, I'd like to point out that Kevin's code is an example for you to follow. It's still your responsibility to write and test what goes in your robot... There is no plug-and-play here.
Mike Betts
As easy as 355/113...
Using Digi-Key Shaft Encoders D.Viddy Programming 45 02-01-2005 20:11
Shaft Encoders wun Programming 3 12-10-2004 16:40
Problem with 5/8 in. shaft in this years kit echos Kit & Additional Hardware 5 14-01-2004 21:21
Who used wheel encoders CyberWolf_22 Technical Discussion 12 04-05-2003 15:37
Where to get shaft encoders D.Viddy Programming 12 17-01-2003 09:38
