Go to Post please....Mr. Needel is my father :rolleyes: - Greg Needel [more]
Unread 17-01-2005, 19:18
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: CMUcam autonomous programming
I have thought that this would probably be the easiest way to tackle autonomous also. I have not cracked into the vision system yet, but the biggest problem I can fore see is that from either of the two side locations of the field, several tetra positions are very nearly inline. Taking into account the size of the tetras may help to determine which is further, but it still may be difficult.
My plan was to have the camera pan (or have the robot rotate) until the target was found. Then, you would compare the value for size and pan of the camera with a stored table of values for each tetra position finding the closest match. You would need a different table for each of the 3 starting positiosn the robot could have. (the left and right positions might share a table and just mirror the tetra positions). After the match has been selected, you would just run the correct dead reckoning code and get on your way.
Team 1257
White Paper Discuss: C Programming and Autonomous Modes for Newbies cbolin Extra Discussion 3 09-01-2008 19:32
Autonomous Programming Guide cbolin Programming 2 16-12-2004 15:13
Autonomous Programming Competition Signup List SilverStar Programming 36 13-05-2004 15:09
How do you do the autonomous programming? Ryan Collings Programming 11 07-02-2003 19:38
