Go to Post Attempted to like Andrew's comment and then realized this wasn't Facebook :P - afowl [more]
Unread 11-01-2005, 10:02
Accelerometer data sheet
Has anybody been able to find a data sheet for the provided accelerometer? (besides the one page spec sheet FIRST posted, http://www2.usfirst.org/2005comp/Spe...elerometer.pdf). I've tried searching TI's site and google to no avail so far.
Unread 11-01-2005, 11:10
Zanella BR's Avatar
Zanella BR Zanella BR is offline
Brazillian FIRST Team Member
AKA: Leandro Zanella S. Campos
None #1382 (Tribotec)
Zanella BR will become famous soon enoughZanella BR will become famous soon enough
Send a message via ICQ to Zanella BR Send a message via AIM to Zanella BR Send a message via MSN to Zanella BR
Re: Accelerometer data sheet
That's strange, I couldn't even find the datasheet in the Texas Instruments website, using both code numbers (from the guidelines or the section 5 doc).
The Lightning Hunter
#1382
2004 - NJ Regional -3rd place (Rookie year)
2005 - NJ General Motors Industrial Design Award
2005 - NJ Website Excellence Award
2005 - NJ Safety Award
[<o>]
Brazil's 3rd Team
Unread 11-01-2005, 11:14
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
I might have found some information here. Specifically, this data sheet.
Unread 11-01-2005, 11:16
Zanella BR's Avatar
There's this one too: http://www2.usfirst.org/2005comp/Spe...elerometer.pdf
#1382
[<o>]
Brazil's 3rd Team
Unread 11-01-2005, 11:52
Michael Desch Michael Desch is offline
Physicist
#0053 (Team Illusion)
Michael Desch is an unknown quantity at this point
The accelerometer data sheet mentions a 'cross axis sensitivity error' of 3%, which suggests it must be more than single axis. One single axis accelerometer would be next to useless for nav purposes, unless your robot is going to move in 1D only.
Unread 11-01-2005, 15:31
Just because the accelerometer has a sensitivity to acceleration in another axis doesn't mean it measures that other axis. Most likely it is a byproduct of the way the sensor is designed. There is only one signal pin, which leads me to beleive it is only a single axis.
Thanks for the sheet Mike. It's not nearly as detailed as I'd had hoped, and I still have hope there is a more detailed one floating around somewhere, but this is certainly better then the single sheet FIRST had.
Unread 11-01-2005, 17:26
lupjohn's Avatar
lupjohn lupjohn is offline
AKA: Larry Upjohn
FRC #0692 (FemBots)
lupjohn is an unknown quantity at this point
Check out www.klixon.com. This is the actual manufacturer of the device and has more info. There is also a document titled " Accelerometers and How They Work". It is a good tutorial and gives some clues as to use of this device. My estimate is that the two Hall Sensors giving rotational data from the BOT directional movement along with the data from the accelerometer could be used for BOT navigation. Dave Lavery mentioned PID in the kickoff presentation while he was demoing the robots. Do a search on the term or acronym PID relating it to robotics and you will find some links for connecting these sensors. I have just glanced at the software listed in the manual (has lots of nav stuff imbedded). There is a specific module named "PID.C". So take it from there. Best wishes for the season! Larry U.
Unread 13-01-2005, 11:01
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
I have a TI sensors and controls rep coming in this morning. I will ask him about any more info he can get me.
I would like to point out however drawing posted at FIRST is typical of what I get from them normally for pressure transducers and pressure switches.
Pete
Unread 13-01-2005, 12:25
Electrical Engineer
Rookie Year: 1995
Pete
The drawing is a mechanical layout only. We need electrical specifications, pinout information, et cetera.
Mike Betts
As easy as 355/113...
Unread 13-01-2005, 16:11
There is a minimal amount of electrical information on the drawing. The pinout is shown on the drawing in the upper left hand corner. A bit of electrical characteristics are on the far right.
With that data, one has enough information to hook it up and start using it. I would like a full datasheet, though.
Unread 13-01-2005, 16:17
Spoke with the TI sensors rep this morning. Showed him what we had. He said he would get some one in touch with me by close of business tommorrow.
Unread 13-01-2005, 16:25
That's great!
Unread 15-01-2005, 22:34
Pete, did the representative contact you?
Has anyone figured out where to buy some more?
Unread 16-01-2005, 14:54
Joe the rep didn't get back to me yet. I'll be out of town on business until Saturday. Don't know when I can bug him about the info prior to the 24th. Hopefully the info is sitting in my Inbox when I get back.
Pete
Unread 17-01-2005, 21:45
FreakyAntelope's Avatar
FreakyAntelope FreakyAntelope is offline
Unregistered User
AKA: Toby Waite
#0246 (Overclocked)
Team Role: Electrical
FreakyAntelope will become famous soon enough
Send a message via AIM to FreakyAntelope
When we were putting together our accelerometer, we noticed that the positive line was BLACK, while the negative was RED. Did other people notice this? Or was ours just assembled wrong? If you didn't check, then do so, so as not to risk breaking something.
Again, did anyone else see this, or are we *all* crazy, or did TI do ours wrong?
Toby
Competition Scouting pauluffel Scouting 31 09-01-2003 00:34
Robot Scouting Database archiver 2001 10 24-06-2002 03:00
Limiting PWM in pbasic archiver 2001 4 24-06-2002 00:38
