Go to Post Come on, Dave! We need more lyrics! (I'll bring you fresh KK doughnuts at VCU's regional! :D ) - Squirrelrock [more]
Unread 17-01-2005, 22:07
Hieb Hieb is offline
Hieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to behold
IFI Loader problems
I'm having trouble loading new programs onto the RC. I successfully updated the Master Code, but when I uploaded our program it installed but showed a code error on the OI. I then installed the default code successfully. After that my problems began. Since that time I have tried reloading our current code and also several other code packages, but each time it begins (erasing the old code) then abruptly stops with the status line reading "Not connected..." I get the same result when trying to load to the mini-RC. I'm not aware of any system changes between the successful and unsuccessful attempts, but my have a feeling it has something to do with the settings of the COM port. Any ideas? Thank you.
Unread 17-01-2005, 22:26
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Re: IFI Loader problems
Try holding the PROG button until the state goes to yellow before you download?
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
What lights are on on the RC? We ran into a problem somewhat like this before, and it was an easy fix (After we spent like an hour trying, it was in the doc's all the time). If the battery light is flashing, and the program light is red/orange then check out the doc's for the RC, it tells you how to fix it.
Unread 18-01-2005, 13:45
Thanks for the help, but I'm still unable to download the program code. The program button has been pushed. Currently the RC lights are: Battery Power-green, Program-orange, radio modem-green, RC Hardware-green. For the RC Mode, it is either flashing green very faintly, or there is no light for RC Mode. I've read and reread the documentation for the RC, the OI, and Programming, but have been unable to find a solution. Thanks for any help.
Does the new IFI Loader work with the old Firmware? gnormhurst Programming 2 17-01-2005 20:11
IFI Loader problems billstu Programming 22 23-03-2004 11:39
IFI Loader Problems BrendaB Programming 3 24-01-2004 22:45
IFI Loader Doc's Raven_Writer Programming 0 21-01-2004 17:53
Bug in IFI Loader rwaliany Programming 2 06-01-2004 21:26
