Go to Post The point of FIRST is to get a wide range of kids together and have them work as a TEAM. - Firewolf [more]
Unread 17-01-2005, 22:40
reilly reilly is offline
reilly is an unknown quantity at this point
"arena field switches"
How exactly do the field switches work?
I'm not clear on exactly three things regarding the field switches: 1) how long does a robot need to remain on the colored switch;2)When-does the robot need to be on the switch( in what mode )? and 3) subsequently- how long after the robot has just left the switch can the robot roam?
Moreover, must we account for this when programming? If so is there default code available...
Cheers!
Unread 17-01-2005, 22:43
REVving up for a new season
FRC #2848 (All-sparks)
Re: "arena field switches"
i believe you are interpreting the rules incorrectly, the only "switches" that deal with real time play on the field are the human player mats in which case when a human player walks off of them their robot is disabled. the other zones for receiving tetras are just colored triangles on the field but don;t deactivate your robot or anything they are just the zone you have to be in to get a tetra. i hope this helps.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 17-01-2005, 22:59
So, the robot meets the human player in the non-autonomous mode. Then..
--how do the human player switches operate with respect to the robot?
I do not understand the purpose of the colored tetras on the floor-are you saying that they are zones for receiving tetras--receiving from humans?
Thanks for your reply.
Unread 17-01-2005, 23:21
Ryan Foley Ryan Foley is offline
FRC #5687 (The Outliers)
Ryan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond repute
When a human player steps off of the pressure-sensitive mat they are standing on, that human player's robot is disabled until the human player steps back onto the mat.
The colored triangles are there so that the robot's vision system can find them during autonomous or during regular play. The triangles at the manual loading zones are there also so the human players can see that a robot wants a tetra (by being on the colored triangle). When the robot enters one of these triangles, the human player picks up a tetra, steps off the pad (disabling the robot) and gives the tetra to the robot, and goes back to the pad so the robot can be re-enabled and deliver the tetra to a goal.
Ryan
FRC #5687: The Outliers [2015-?]
FRC #1995: Fatal Error [2007-2009]
FRC #350: Timberlane Robotics [2001-2004]
FRC/FLL volunteer since 2005
Unread 18-01-2005, 00:21
Thank you Ryan and Greg for clearing things up a bit.
Also I would like to know the 'engineering aspect' of how it this is done: when a human player steps off of the pressure-sensitive mat they are standing on, that human player's robot is disabled until the human player steps back onto the mat.
Is there programming that should be done by the teams to accommodate the pressure sensitive switches?
I guess it should be obvious by now that I am not clear about how the robot is controlled by the pressure sensitive mat.
Unread 18-01-2005, 00:30
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
When the human player steps off the pressure switch, the field control software (not the software on your robot) will automatically cut communications between the operator control and the corresponding robot, and disable the robot. You don't need to do anything to the software on your robot.
-dave
Vetting and Idea: Modular Field Design... Justin General Forum 19 16-06-2004 15:46
What is the true field infrared emitter? scottm87 Programming 4 20-04-2004 18:22
Mobile/immobile objects on field Steve782 Rumor Mill 12 08-01-2004 04:15
Could the field be ice? dez250 Rumor Mill 15 03-01-2004 18:54
What happens / why do motors stall? DanL Technical Discussion 19 21-11-2002 07:19
