Go to Post Dr. Doom becomes Dr. Awesome! - Nick Lawrence [more]
Unread 17-01-2005, 22:48
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
CMUCam not working.
My team is having difficulties using the CMUCam. We've properly powered the camera, and connected it to two different laptops and were unable to get it working. We've made sure our terminal software, and port settings are correct. When we apply power the power LED lights, along with a single status LED. We have read the documentation and think we might be missing the clock jumper, but can't locate its position on the board. Any assistance is appreciated.
P.S. The CMUCam software also does not work.
Matt Krass
Unread 17-01-2005, 22:50
Marc P. Marc P. is offline
I fix stuff.
AKA: βetamarc
Marc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond repute
Send a message via AIM to Marc P.
Re: CMUCam not working.
There's another thread about problems with the CMUcam here.
Unread 17-01-2005, 23:16
Electrical Engineer
Rookie Year: 1995
Matt,
I followed the directions in the "start here" pdf documentation and it worked fine. I know you to be a very competent technical individual so I will skip the normal #$%^%& and ask which Java did you install?
Mike Betts
As easy as 355/113...
Unread 18-01-2005, 08:23
In the "CMU Cam Assembly.pdf" diagram there is:
  • A jumper on the "Oscillator Connect"
  • A jumper on the "Internal Power to Servos" (although this won't affect your inital tests).
Make sure it's not connected to the TTL port on the RC controller.
If you continue to have trouble, want to take a drive to Hauppauge?
Unread 18-01-2005, 14:08
SeanCassidy's Avatar
SeanCassidy SeanCassidy is offline
Antiregistered User
#0263 (Aftershock)
SeanCassidy is an unknown quantity at this point
Originally Posted by Mike Betts
Matt,
Hello. (I'm on matt's team) I installed the latest JVM from www.java.com. My serial port works fine for everything except this.
CMUcam setup Ryan Collings Programming 26 13-01-2006 01:00
EDU-RC, USART2 (TTL), CMUCAM ChrisHomer44 Programming 2 30-04-2004 21:38
IR Beacon/reciever not working... still... Ferazel2001 Programming 23 04-02-2004 23:30
INT2 and INT3 interrupts not working Mercutio Programming 4 01-02-2004 13:27
I'm working :) Jack FIRST Scouting Network 2 03-01-2004 01:26
