Go to Post That little voice in your head is not Ari telling you to keep going. It is your guardian angel telling you to stop! - Al Skierkiewicz [more]
Unread 18-01-2005, 02:21
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Where to get lightweight flexible coupling?
I know there are two or three threads on these couplings out there already but they are old and closed.
I need a flexible coupling that can withstand in the range of 500 in-lbs of torque. Something like McMaster #6408K17 but not made out of iron, maybe aluminum. I found McMaster #59985K5 which is aluminum but I have two concerns. Is a slotted disc type a good type to use? And it has no keyway and no through hole, do we mill a rounded keyway or do we bore through and broach?
This coupling needs to have a 1/2" bore in both sides, and needs to come keyed or be able to be keyed 1/8" Lightweight is a big priority. I looked in the LoveJoy PDF catalog for their jaw couplings and I see they make some aluminum ones but I have no idea where to get them. I checked all the usual places and even some not so usual places.
I see from the old threads that teams 968 and 45 have used CEC couplings but I can't find anything about them on MSCs online catalog or anywhere else.
Does what I need exist, or do we have to CNC out some aluminum ones?
Also, as far as the torque rating goes, how far over their rated torque can you push these things in a FIRST robot situation?
We need to order these really soon but I can't find what I need anywhere. Thanks in advance.
Unread 18-01-2005, 02:52
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Re: Where to get lightweight flexible coupling?
http://www.fenner.com/btlhome.nsf/00...2568b2004df9eb
http://www.pennaircatalogs.com/Supplier%20Catalogs/Vescor/CEC_Cplg.pdf#search='cec%20coupling
Not sure where you can still get them, but it looks like you need the C100 hub style. We used the Nitrile (Buna-N?) spyders in the past since they are the softest and offer the most misalignment error.
You would need to make a sleeve to make the bore smaller as Andy has described in the past. Simply broach a hex in the coupling and make a corresponding insert out of aluminum or steel with the 1/2" keyed bore you require.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 20-01-2005, 00:32
Gui Cavalcanti's Avatar
Gui Cavalcanti Gui Cavalcanti is offline
Robogeek
Gui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to all
Send a message via AIM to Gui Cavalcanti
You could always use previous year's black plastic couplings, if you want the ultimate light-weight coupling. You'd have to buy the hex shaft that fits in them, and bore/broach it to 1/2" with keyway.
Gui Cavalcanti
All-Purpose College Mentor with a Mechanical Specialty
Franklin W. Olin College of Engineering, Class of 2008
Unread 20-01-2005, 01:22
First off, the above is an excellent idea. I believe we have the parts, so we will consider it.
As for what I was originally looking for I believe I have found it. Not super light but better than iron, Applied Industrial sells aluminum LoveJoy couplings.
Shorten The Flexible Drive Shafts? milesdf Motors 2 08-02-2004 12:27
coupling Bosch & Atwood motors caffel Motors 10 28-05-2003 16:00
SPI Wheel coupling cracking like crazy! archiver 2001 4 24-06-2002 00:56
Motor coupling archiver 2001 19 23-06-2002 23:35
3.5x3.5 coupling? ahecht Technical Discussion 1 05-01-2002 23:36
