Go to Post It's rather simple: you start with a block of solid and remove material until you just have the robot left. Kind of like making a sandcastle. Only harder. - petek [more]
Unread 18-01-2005, 07:50
Re: Voltage Regulator
Robby,
In reality there is an internal regulator built into the controller. If you are drawing significant currents and drawing the voltage down so far that the backup battery takes over, you have some other problems to correct. The controller switch is just a symptom of a bigger problem. It might be as simple as a loose connector on the battery or a poorly made crimp on the wires feeding the controller. But it could be something wrong in you mechanical systems. Find the cause and fix it.
Victors Non-linear!!! Rickertsen2 Control System 63 08-01-2005 00:42
voltage regulators vs. speed controlers Greg Needel Electrical 8 06-08-2004 23:31
Voltage on Frame Greg Electrical 31 02-03-2004 13:49
RC Circuits Melissa Nute Math and Science 3 25-01-2004 05:02
Output voltage in PBASIC diego25 Programming 7 31-01-2002 22:50
