Go to Post It is great to be proud of the way you do things, but to imply that everyone should match your way of thinking, is ludicrous. - JVN [more]
Unread 17-01-2005, 13:16
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
Are 100k Ohm pots necessary?
I'm trying to find high quality single turn potentiometers and having a difficult time finding them at the 100K ohm requirement. I understand that the Robot Controller's manual indicates you should always use 100K potentiometers. But is it really necessary? What could be the disastrous result of using for instance a 5K potentiometer?
Unread 17-01-2005, 13:44
Re: Are 100k Ohm pots necessary?
Mike,
I have the input equivalent circuit around here someplace. I will continue to try and find it so it will help understanding the circuit. In the mean time, the 100K pot is selected to work with the input circuitry on the RC and the OI. The pot is connected to an A to D convertor through some input protection circuitry in each of the devices. Note that the wiring is different for the RC and OI analog inputs. Additionally, joysticks use the 100K pots.
Unread 17-01-2005, 14:32
Carpe diem
It was my understanding that the A to D converter simply compares the voltage on the signal line to it's 5 volt reference. What would happen if you were to use a 5K pot?
Unread 17-01-2005, 14:49
KVermilion's Avatar
KVermilion KVermilion is offline
... clearly ...
#0649
KVermilion is infamous around these parts
If you really want "high quality" use a stepped attenuator...
Any <100k> pot should do, as long as it's controlable... if you are worried about bad tracking, noise, etc thats a fact of life. If you want a really high qaulity pot you might be able to find a pana evj or alps blue velvet in 100k varieties...
Unread 17-01-2005, 14:50
Electrical Engineer
Rookie Year: 1995
Mike,
You would probably get away with it...
Let me extend your line of reasoning:
Q: What would happen if I use a 10 ohm pot?
A: I doubt if the 5V internal power supply in the RC can provide 5V/10ohm=0.5A of current.
I would think that 100K is probably a value such that a team could use 100K pots on all analog inputs simultaneously and it would work.
For a definitive answer, I would post on the IFI Technical Forum.
Regards,
Mike Betts
As easy as 355/113...
Unread 17-01-2005, 15:05
Originally Posted by Al Skierkiewicz
Mike,
IFI sent me the input circuitry for the RC this morning. They said they would post it, but I haven't seen it show up yet. I've attached it in the meantime.
The input circuitry for the microprocessor is on page 217 of the datasheet.
Unread 17-01-2005, 15:35
Carpe diem
In the IFI Forum it says the Robot Controller is capable of sourcing 1 Amp of current on the 5V I/O headers.
I obviously don't want to draw more current than I have to, but I have been having difficulty finding 100K precision single turn pots.
After looking at the schematic it seems impossible to draw more than 5mA of current due to the 1K Ohm resistor in series with the load.
I'll submit this as a question to the IFI Forum.
Unread 17-01-2005, 15:41
Thanks, Joe.
Mike, if you take a look at the input circuit you will see the series resistor and capacitor. This circuit does a little low pass filter. (about 3kHz) Since this is a simplified drawing, you can guess that the A/D that follows is selected (optimized) for a particular input current/frequency in order to track and remain linear. The 100K value allows that, but a 10K would not. It is not a matter of possible damage, just not predictable results or noise immunity.
Unread 18-01-2005, 10:52
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Here is a high quality 100kohm pot we have used before:
http://www.digikey.com/scripts/DkSea...423225&Site=US
They arn't cheap, but its practically impossible to break the stops on them. That particular model is the long shaft version, they are also avilable in a short shaft version (but its far easier to shorten a shaft than lengthen a shaft, so we usually buy long shaft versions and cut them down to whatever we need).
Unread 18-01-2005, 11:57
Carpe diem
IFI has updated the 2005 Robot Controller Reference Guide. The new potentiometer requirement is:
Originally Posted by IFI RC Reference Guide; page 8
Always use 250 – 100KΩ potentiometers.
Unread 18-01-2005, 12:06
Cool!
Thanks.
Unread 18-01-2005, 14:58
I would assume that means 250Ω - 100KΩ, since they show a 10KΩ pot below it. My first reading was 250KΩ - 100KΩ.
Unread 18-01-2005, 17:02
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Just wanted to point out that
only applies to the Robot Controller, not to the potentiometers used on the Operator Interface (unless IFI changed the circuitry in the OI, but I doubt they have). The OI has a different circuit than the one Joe posted such that if you use anything but a 100K pot you will not get the full 0-5V range.
For those who are interested, this is done so that if there is no joystick plugged in, the analog inputs get pulled down to 0V and the OI can detect this and in turn send 127 to the robot (instead of 0). It's a safety feature so that if your joysticks get unplugged your robot doesn't start driving backwards at full speed.
Unread 19-01-2005, 22:09
DonRotolo's Avatar
Back to humble
FRC #0832
Originally Posted by BrianBSL
Here is a high quality 100kohm pot we have used before: <snip>
Can you provide the DigiKey part number? The URL doesn't bring up a link to the part. Thanks in advance!
Don
Unread 19-01-2005, 22:24
FRC #0190
Sorry about that. The part # is RV4NJ104C-ND. It is made by Precision Electronics Components or something like that.
LED's, resistors, computers... ohm my! DanL Electrical 3 01-07-2003 09:37
10 turn 100k pots rust710 Electrical 5 02-04-2003 15:10
Multi-turn pots? MikeDubreuil Electrical 14 02-03-2003 22:47
100k Slide Pot archiver 2001 4 24-06-2002 02:53
3-turn pots archiver 2001 2 24-06-2002 01:24
