Go to Post "The secret to success is to acknowledge that you have limits, but to never acknowledge that you have reached those limits." - lady_raidan [more]
Unread 15-01-2005, 12:59
hedgehogger hedgehogger is offline
hedgehogger can only hope to improve
Are u allower to take motors apart???
hey all
are you allowed to take motors apart and use parts from them???
thanks
-hedgehogger
Unread 15-01-2005, 13:06
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Are u allower to take motors apart???
No. The only thing you can do involving "taking apart" a motor is removing the black gearbox on the globe motor
2001-2004: Team 100
2006-Present: Team 254
Unread 15-01-2005, 14:19
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
I think it depends on what you are going to DO with the parts.
If you want to use the wire to conduct electricity, I think you are out of luck, but if you want to use the alxe and bearings, I think you'd be within the rules.
Basically, you can't modify them and still use them as motors, nor can you use any of the parts ways that voilate other rules (for example you could not seal up the body of the CIM and use it as a pneumatic air tank in place or addition to of the clippards), but I think that if you have other ideas, you many be allowed to do it (I am thinking that I may use a the insides of a Chiaphaua Motor as a fishing reel type affair; a place to wind up my Spectra cable -- NOT! ;-)
Joe J.
Team #88, TJ2
Unread 18-01-2005, 16:16
james james is offline
james is an unknown quantity at this point
you should NEVER takt the rotor out of the stator housing unless you have a metal sleeve called a KEEPER.It retains the magnetics flux otherwise the magnetics will be degraded and the motor will produce less power. Jim
Drill Motors Removed? Illegal this year? Chris_Elston Motors 12 12-01-2005 09:04
Suppose you want seat motors... archiver 2000 0 23-06-2002 22:50
