When you're around my motors redline.
Unread 18-01-2005, 14:51
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
weird motor noises
when i turned on all of the CIM motors in the transmission they make a really loud noise. is it ok? is it a problem with the chain or the motors or the transmission ?
or is it normal?
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 18-01-2005, 14:59
Re: weird motor noises
This has been answered in several posts and is also in the transmission manual. You must grease the transmission with white lithium grease.
Unread 18-01-2005, 15:00
Leav's Avatar
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
sorry for not RTM thanks!
does it HAVE to be "white lithium Grease" ?
-Paraphrasing JFK
Unread 18-01-2005, 15:02
RogerR's Avatar
RogerR RogerR is online now
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
or is it normal?
i suspect you might be having a problem similar to the one described here. we had a similar problem with one of our gearboxes, and decided that rather than disassemble them, remove the retainer ring, find the wayward set screws, and re-assemble them, we'd just live with it. Paul Copioli (who designed them) mentioned in this post that the scoring caused by the retainer rings shouldn't have any adverse effects.
[edit] i also assumed that you removed/replaced the original setscrews on the CIM gears. if this is not the case, then these would cause problems too.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 18-01-2005, 16:20
rswsmay's Avatar
rswsmay rswsmay is offline
AKA: Robert
FRC #1177 (Mecha-Jags)
rswsmay is a jewel in the roughrswsmay is a jewel in the roughrswsmay is a jewel in the roughrswsmay is a jewel in the rough
We also had this problem with one of the gear boxes in that the retainer began riding against the outside of the gear teeth. We only ran it for a minute or so before breaking it back down and finding the problem.
As suggested here, replace the retainers with the shorter set screws shipped with the gear box and you should be fine. Don't forget to use the loctite and grease the gears.
or is it normal?
Knowledge is only strength.... Knowledge and Wisdom, thats true power.
Unread 12-02-2005, 23:48
the_short1's Avatar
the_short1 the_short1 is offline
Head of Electronics
AKA: Kevin F.
FRC #1596 (Twin Saults International Instigators)
Team Role: Electrical
the_short1 is a name known to allthe_short1 is a name known to allthe_short1 is a name known to allthe_short1 is a name known to allthe_short1 is a name known to allthe_short1 is a name known to all
Send a message via MSN to the_short1
thanks for the info guys!! ! that really helps.. cuz ours was sounding really rough.. we had greased it well but our first set of transmissions they did not change set screws (for practice bot).. for our competition worthy robot.. we are going to change that..
Unread 12-02-2005, 23:59
geeknerd99's Avatar
geeknerd99 geeknerd99 is offline
Fire Hazard
AKA: Daniel Lin
FRC #0401 (Hokie Guard)
geeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud of
Send a message via AIM to geeknerd99 Send a message via MSN to geeknerd99 Send a message via Yahoo to geeknerd99
OOOOOOHH..... bad call
We used rifle grease......
Unread 14-02-2005, 11:11
Dick Linn's Avatar
no team (Synergy)
I found that our gearbox/motor plate didn't seat fully, probably because of one of the plastic washers in the gearbox. If the allenhead screws were tightened, it would bend the motor mounting plate, which resulted in the motors being bent outwards from each other. I put some shims under the mounting plate, then added some large hose clamps to make sure the motors were parallel. Now the noise doesn't leak out
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Weird Al? George A. Chit-Chat 6 13-07-2004 07:22
Really weird... Alaina Chit-Chat 7 17-08-2003 21:23
Weird Al MattK Chit-Chat 7 10-11-2002 00:33
the weird feeling.. archiver 2000 3 23-06-2002 23:08
Is it weird to see an atwood motor floating in mid air? mnkysp6353 Chit-Chat 6 19-02-2002 21:38
