Go to Post When I saw the title of this thread ("Reverse Robotics"), I thought "what, you get six weeks to take apart a robot or something??" - Katie Reynolds [more]
Unread 18-01-2005, 21:29
Back after 4 years off
FRC #5279
Help with code single joystick
The default code for single joy stick drive is
pwm01 = Limit_Mix(2000 + p1_y + p1_x - 127);
pwm02 = Limit_Mix(2000 + p1_y - p1_x + 127);
however with this code our robot turns right when joystick is forward , and goes forward when the joy stick is pushed to the left.
Mathematically
pwm02 = 254-Limit_Mix(2000 + p1_y + p1_x - 127);
would solve the problem, assuming 254 is the maximum value for the PWM since I dont have the robot with me I can not tell if this will work. Could you please tell me if this will work, if not could you please tell me why or point me in the right direction.
Thank you
James
Single joystick control problem Mr. Van Programming 7 23-11-2004 09:10
Changing 1 joystick code to 2 (rookie team) Brawler006 Programming 5 20-02-2004 17:00
single joystick programming Bill Bonsky OCCRA 2 04-10-2003 09:47
robot goes haywire with the one joystick default code Miles Programming 7 24-01-2003 14:58
