Go to Post This thread is a reminder to myself that I have 29 more days to sleep. :) - Seth Mallory [more]
Unread 18-01-2005, 21:18
Karma Karma is offline
AKA: Daniel Takamori
FRC #0955 (Raiderbot)
Team Role: Electrical
Karma is an unknown quantity at this point
Send a message via AIM to Karma Send a message via MSN to Karma
Wiring two cameras
The newest team update stated that we could use two cameras, our team is considering a use for both of the cameras. None of our Electronics team or other members can figure out how to wire the two cameras though. So how would you wire two cameras up to the TTL Serial Port on the RC?
Unread 18-01-2005, 21:21
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: Wiring two cameras
You'll probably want to hook one camera to the TTL port and the other to the programming port. It will be very difficult to multiplex the TTL port for two cameras, requiring both electronics to switch between the cameras AND a good deal of software development to deal with both. You can't talk to two cameras at the same time over one serial port.
Unread 18-01-2005, 21:22
KVermilion's Avatar
KVermilion KVermilion is offline
... clearly ...
#0649
KVermilion is infamous around these parts
Are you sure they said you can? I mean, I remember a team update that said you can't...
Nevermind... thats odd...
Unread 18-01-2005, 21:36
kjohnson's Avatar
kjohnson kjohnson is offline
Insert Clever Title Here
AKA: Kyle J.
FRC #1610 (BOT)
kjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond repute
It was changed in Team Update #3.
http://www2.usfirst.org/2005comp/Upd..._Update_03.pdf
Unread 18-01-2005, 21:38
Rule # 1007, 'You may use a 2nd vision camera with your robot.'
I think that this rule being in place, there should be a semi-simplistic solution to have two cameras. I appreciate your help Dave, but I still think there might be another way to wire them both.
Unread 18-01-2005, 21:43
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
We get TWO?!
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 18-01-2005, 21:50
kjohnson's Avatar
AKA: Kyle J.
FRC #1610 (BOT)
Originally Posted by phrontist
We get TWO?!
No, you get one in the Kit of Parts, but FIRST is allowing you to use two on the robot. You would have to order another one from Innovation First at http://www.ifirobotics.com
Unread 18-01-2005, 22:12
KVermilion's Avatar
... clearly ...
#0649
I know... read the whole post....
Unread 18-01-2005, 23:40
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
To the first team that successfully enables two CMUcamIIs on their robot and uses the PIC microprocessor in the IFI robot controller to compute the stereo correlation from the two camera images to determine range to the designated target, within the time limits of the autonomous period, I will personally award six dozen Krispy Kreme donuts.
Yes, it is physically and electrically possible to connect multiple CMUcams to the RC. But once you do, what are you going to do with the data?
-dave
(OK, now that I have said this, just watch someone like Kevin Watson have a working solution by this Friday... )
Unread 18-01-2005, 23:46
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
-dave
Me any my friend used two old CMU cameras (the current release in the summer of 2003) to do that, although the Acroname GP boards weren't powerful enough to do it very well. In short we had our trikebot find a target, aim, and fire a paintball gun at it (all done on a 2d plane though, 3d wasn't possible, processor too slow). The theory sounded cool, never did get it to perfectly work though... But hey, with the new CMUII cams and PIC processors, shouldn't be too hard .
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 19-01-2005, 00:24
Kevin Watson's Avatar
La Caņada High School
FRC #2429
-dave
Dave,
I just happen to be working on getting the camera code to work with my serial port driver. And now that you mention it, it wouldn't be too hard to have a second instance of the camera code running... Does your offer include those really tasty glazed, raspberry filled gems?
-Kevin
Kevin Watson
http://kevin.org
Unread 19-01-2005, 00:43
dlavery's Avatar
Curmudgeon
Originally Posted by Kevin Watson
Dave,
-Kevin
I knew almost as fast as I typed that message that it would be a mistake. Yes, if you get a stereo correlation algorithm working on the PIC with two CMUcamIIs that runs fast enough to provide a solution within the 15 seconds of the autonomous period, then the award will include 72 delectable morsels of your choice. And I already know where all the Krispy Kreme stores in LA are located (actually, the Burbank store may be closer).
OK, so is anyone else going to give Kevin a challenge for the donuts?
-dave
Unread 19-01-2005, 00:50
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
program our robot and you will recieve two dozen doughnuts.....that'd be cool just to say NASA programmed our robot
Unread 19-01-2005, 01:39
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
I'll tell you what, Dave. Mail me another CMU cam, and I'll gladly demonstrate two-camera code for you in Atlanta.
Conceptually, it's not that difficult. Get them both operational (with a little help from Kevin), and mount them on opposite corners of the front your robot. You know the width of your robot (likely 28"), and you can get the two angles from the values of the pan servos. You have angle-side-angle, and there's only one solution to the triangle. Now you know how far away you are. Pivot until the two base angles are congruent, and charge forward until you're the proper distance from the vision tetra. Use the same theory with the yellow triangle to the goal. It's very doable, and I'd love to pull it off. I can't think of a more incredible nerd feat attainable at this age than to meet Dave Lavery's personal challenge.
That being said, I don't think my team is interested in spending $200 on 72 donuts. Thanks for the offer, though, Dave.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 19-01-2005, 07:48
-dave
You know he was just waiting for someone to raise the stakes high enough! 72 is too rich for my blood, I fold.
Electronics Board Construction/Design zdeswarte Electrical 10 28-01-2005 00:09
Neat & Organised Electric Wiring thoughtful Electrical 30 13-12-2004 22:46
Digital Cameras Ian W. Chit-Chat 15 08-09-2004 17:48
Lost cameras at Georgia Dome Aidan F. Browne Championship Event 7 19-04-2004 11:53
Help wiring Line sensors magical hands Electrical 1 18-02-2004 10:17
