Go to Post Chief Delphi isn't for making enemies...it's for making friends. - Alex Pelan [more]
Unread 19-01-2005, 10:00
nwbutterfly nwbutterfly is offline
SparX
AKA: Nicole
#1126 (SparX)
nwbutterfly is an unknown quantity at this point
Send a message via AIM to nwbutterfly
Question questions on window motors!!!!! need help!
[color=Blue]We are wanting to use window motors for our arm. We have been researching how to mount them but are having a little trouble, can someone please respond. We would like to know how to mount or use the window motors!!!!
Unread 19-01-2005, 10:15
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: questions on window motors!!!!! need help!
There are three convenient threaded holes in a circle around the shaft. You just need three of the right sized bolts and three holes in a plate of something to bolt the motor to.
Team 1257
Unread 19-01-2005, 10:19
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
One of the window motors has a stud that sicks out from the center of the gear. This stud does not rotate with the gear. You can make a hole in a plate to stick this stud into that will hold the window motor a set distance from the gear you are trying to drive. Then you just need to use the mounting holes to keep the motor from rotating.
Unread 19-01-2005, 10:42
Squeje250's Avatar
Squeje250 Squeje250 is offline
BIG RED
AKA: BJ Boville
#1259 (Paradigm Shift)
Squeje250 is on a distinguished road
Send a message via AIM to Squeje250 Send a message via Yahoo to Squeje250
There should be some holes in it so that you can bolt it into where ever you need to. if not the it could be possible to drill your own by taking the motor appart and goin though the shell making sure that you can get a bolt or 2 through.
Squeje250
Unread 19-01-2005, 18:01
SparX
AKA: Nicole
#1126 (SparX)
Thank you for your help, I know how to mount the motor. Do you know what size gears is on the motor and where I could get a mating gear? Any suggestions to how I can bolt a sprocket to the gear?
Complete Drill, Seat, and Window motors for trade archiver 2000 0 23-06-2002 22:16
