Go to Post Everyone's bored, what else do we have to do in the off season? - StephLee [more]
Unread 18-01-2005, 16:36
Flynn Flynn is offline
Flynn is an unknown quantity at this point
Elevation of the Tetras?
Are there any ideas other than an arm, or a fork-lift type design that can possibly be used to lift the tetras. We're trying to decide which design to go with.
Unread 18-01-2005, 20:28
Haldir 122690's Avatar
Haldir 122690 Haldir 122690 is offline
Haldir 122690 is an unknown quantity at this point
Re: Elevation of the Tetras?
I guess you can use a claw or a crane.
Unread 18-01-2005, 20:40
Spikey's Avatar
Spikey Spikey is offline
Its NOT a Camera
AKA: College Advisor
FRC #0293 (SPIKE)
Spikey is just really niceSpikey is just really niceSpikey is just really niceSpikey is just really nice
You could make an extendable conveyor belt, it would be hard to make but awesome if it worked.
It's not a bug it's a feature!
"No, you may not drill holes in the air tanks to lighten them." -FIRST Q&A Repsonse to a question about lightening air tanks.
I'm the Not a Camera Kid at the New Jersey Regional But Not This Year, I am at Syracuse University Class of 2009
Uncrowned Champions of the 2005 Philadelphia Regional
SPIKE X NJ Xerox Creativity Award. Chesapeake Regional CHAMPIONS, and Motorola Quality Award
2006 Semi-Finalist at NJ Regional & Semi-Finalist at Chesapeake Regional, winners of the 2006 Xerox Creativity Award, and Judges Award
"Looks like SPIKE is doing its Batman thing again, that team looked like it was going to score, but SPIKE was not going to allow that to happen" -Play by play call at the Chesapeake Regional
Unread 18-01-2005, 20:46
Kelvin Ng Kelvin Ng is offline
None #1558 (ACCIDENT Robotics (Albert Campbell Collegiate Institute stuD)
Kelvin Ng is on a distinguished road
you could try using a crane...like those tall cranes used to carry huge boxes at shipyards and stuff. but of course that thing would have to raise up and your centre of gravity would be insanely high.
Unread 19-01-2005, 10:08
DrShadowSML's Avatar
DrShadowSML DrShadowSML is offline
Salmon River HS Student
AKA: Steven Lauzon
#0229
Team Role: Student
DrShadowSML will become famous soon enough
Send a message via AIM to DrShadowSML
Lightbulb Re: Elevation of the Tetras?
Instead of having a claw to grip tetras, you could simply have an extendable pole-like object to get under the top of the tetra and lift it on the goal. It's an arm without a hand basically.
Unread 20-01-2005, 15:25
dhitchco's Avatar
dhitchco dhitchco is offline
Awards/Photo/Video "wizard"
AKA: Doug Hitchcock
FRC #1511 (Rolling Thunder)
dhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant future
I like the "conveyor belt" idea. Just think of a chameleon's tongue and the number of ways you could grab onto a tetra!
But, back to reality and the ways to grab a tetra?
1) Forklift it from underneath
2) Grab it fromthe top of the apex (ala a crane)
3) Spear it inside and lift from UNDER the apex
4) Suction the tetra on one side (perimiter only)
Just remember that the tetras won't always be aligned exactly the same even if you approach it in a parallel fashion:
a) tetras on the field floor will angle away from your robot
b) tetras in the auto-loader wil be perpendicular to the front plane of your robot
c) positioning a tetra on a goal can be done at a variety of angles
d) tetras UNDER a goal can be any which-way
e) manually-loaded tetras will be very unpredictable
BUT, there are ONLY three vertical elivations you need to worry about: floor height, loader-height, and goal-top stacking height. Anything in between these three is not a critical dimension.
The THUNDER just keeps getting LOUDER in 2008....
Team 1511 now supports over 15 FLL teams
RollingThunder....Winner of the 2007 Chairman's Award at Finger Lakes Regional and Spirit Award at Boston.....Winner of 2006 Finger Lakes Regional Engineering Inspriation and Boston Imagery awards.......Winner of 2005 World Championship Rookie All-Star (plus FLR Rookie All-Star, Buckeye Top-Seeded Rookie, GTR Champion, Spirit, and Inspiration)
"Gracious Professionalism is a WAY of life".....
Unread 20-01-2005, 20:22
chocolateluvrlr chocolateluvrlr is offline
#1389 (Team Robit)
chocolateluvrlr is on a distinguished road
Goal-top stacking height varies. For one thing, the center goal and other goals are different heights. Also, as more tetras are added, the height changes. Plus, if a robot is putting tetras into the goals, the arm must reach different verticle elevations.
Unread 21-01-2005, 09:12
dhitchco's Avatar
AKA: Doug Hitchcock
To chocolateluvr (et al),
Yes, you're somewhat correct. What I meant to say is that the robot arm doesn't really need to have "infinite" positions vertically, and only needs to have TWO positions horizontally. Let me explain further:
1) Horizontally, the robot "arm" only needs to be "close" to the robot for a pick-up and only at the 2.5' extended positionto do a drop-off. There's no need to extend any further than the 2.5-3' range.
2) Vertically. One correction from your post. You do NOT get points for stacking tetras INSIDE (contained) within a goal. The ayy count one point, just shove them in there. You also get no extra points for "owning" the stack inside the tetra. That only happens for the stack of tetras that's on TOP of the goal.
Yes, there are multiple goal-top positions in order to "clear" the goal or to "clear" the stack of tetras. The center goal needs 7' off the floor to clear the goal and about 6" more to "top" each stacked tetra.
Unread 24-01-2005, 18:56
Eria4044 Eria4044 is offline
None #0935 (Railerobotics)
Team Role: Webmaster
Eria4044 is on a distinguished road
Send a message via Yahoo to Eria4044
Someone on my team wants to use a fish hook design.
Q/A questions so far.. AmyPrib Rules/Strategy 49 28-01-2005 08:39
Question: Missing Tetras in Human Loading Zone? tribotec_ca88 Rules/Strategy 7 15-01-2005 15:26
How to Stack Tetras in Inventor petek Inventor 0 13-01-2005 11:47
Just where are vision "bonus" tetras placed? David Brinza Rules/Strategy 17 10-01-2005 20:50
Manipulating tetras from the ground. Petey Rules/Strategy 4 08-01-2005 23:19
